Results 1 to 8 of 8
Thread: 35-70 C/Y Vario-Sonnar on A7/r?
    No CA
    796
    The 28mm f2.8 Distagon and the 50 1.4 Planar in C/Y mount provide wonderful IQ on A7/r, but I wonder about the 35-70 zoom – is anybody using it?
    I've been thinking it would be handy to have a zoom for when I want to carry only one lens, and the old reviews say this zoom's IQ was almost the same as the primes. But I also read that the unusual one-ring adjustment feature might create a vacuum and drag dust into the camera/lens chamber?
    So how about IQ and dust? Any experience? I know it's a big one – does it feel clumsy, or does it handle pretty well?
    Kirk
    PS, images from the C/Y Zeiss 28 and 50 are impressive in their almost 3D quality and their fine tonal gradations – and they aren't as super-contrasty the new Sony Zeiss lenses. I'll try to find time for a longer post about them….
    Senior Member JoelM's Avatar
    Jun 2011
    San Diego, CA USA
    264
    Re: 35-70 C/Y Vario-Sonnar on A7/r?
    The 35-70/3.4 works fantastically on the A7r. I have been pleased with it. As for pumping dust, I haven't noticed any issues whatsoever. It's a short throw being a small lens so it isn't like an older 80-200 or 100-300 say. The other zoom I use with great success is the Nikon 25-50/4. That said, if the newly announced 16-35 Zeiss is good, I'll likely start using that and put the Nikon on the shelf. I'm waiting on ordering the 70-200 as well as my aging eyes are thinking that perhaps autofocus isn't such a bad thing these days and perhaps my M lenses will mostly stay with the Leica system.
    My $0.02,
    Joel
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    HI There Kirk
    I have the Carl Zeiss Vario Sonnar 28-85 f3.3-f4 lens - a little bigger, but still a fantastic lens. I used it quite a bit on the A7 (I also use it on the M).
    It's the poor man's Leica 28-90 R, and back in the day it was nearly as expensive. Now it's about 1/10th price!
    all the best
    Just this guy you know
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    I have a lot of other C/Y lenses (85, 100, 135, and 180) and they all have excellent optical quality. I bought the MM versions of all of my lenses as certain models were "upgraded." Most AE versions are great though. The main difference is more modern lens coatings and aperture blade designs.
    The 35-70 is regularly rated as the best zoom in the C/Y system along with the 100-300. Both are said to rival the primes in the focal lengths with speed being the largest difference.
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,058
    762
    I use it and it is a good lens and balances very well on the A7r, no vacuum dust problems I am aware of.
    No CA
    796
    Thank you, gentlemen, for sharing your advice. Looks like there's a consensus that it's a winner I think I'll go ahead!
    Kirk
    Jul 2009
    363
    3
    I have one and won't need an FE 24-70 because of it. Try to find a good one, they are 20 years old now. Tens of thousands were made fortunately - back then photographers knew the value of short range zooms - there are several other fine 2:1 midzooms - Leica R, Minolta, even Nikon.
    The short end needs stopping down more and is weaker than the 50mm and up FLs. And CA enters the picture slightly at 35-40mm on the a7r but in all other respects it is as good as anything similar made today, I would expect. At 50mm it is very very good indeed - right into the corners, no distortion. Lovely soft palette, low contrast with huge detailed micro-contrast - would be great for those soft English (or New England) afternoons in low light.
    It's the 'character' lens type I hoped for in FE. And it weighs less than a ZE 35mm f2, some weights:
    ZE 35/2: 570 grams
    CY 35-70: 475 grams
    FE 24-70: 426 grams
    http://www.zeiss.com/content/dam/Pho..._35-70mm_e.pdf
    Also has good macro and excellent bokeh. Flaws? Slow, optimised at f8-f11, so really a landscape lens that is surprisingly good for portraits in good light (a7r can crop plenty if needed). Some hate push-pull. Focus should be buttery, no play anywhere - I know because I bought one NIB from Ffordes - (very) old store stock.
    Nov 2009
    Berkshires, MA
    262
    Old thread but I'll add my 2 cents, the 35-70 vario-sonnar is excellent on the A7r. Much sharper than the FE 24-70. I haven't tested it directly against the FE 35 2.8, but I suspect it will give it a run for it's money. It doesn't replace the FE lenses because sometime you need the fast autofocus. Still, for slower tripod work the 35-70 is my first choice.
    I also have the C/Y 200 f/4 tele-tessar that I'm interested in testing on the A7r. And for kicks I'll pull out my first lens, a Yashica 50 1.7
    Shaun O'Boyle
    new.oboylephoto.com
