Results 1 to 9 of 9
Thread: Sony A7R New battery question
    Feb 2009
    793
    I received my sony A7R today. Why have a battery charge in the camera rather than a seperate battery charger? how long deos it take to fully charge a new battery.
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    Re: Sony A7R New battery question
    Buy an external charger but do charge the internal battery through
    usb the first time at least.
    Jul 2009
    Swiss Alps
    1,444
    3
    Quote Originally Posted by HiredArm View Post
    ... do charge the internal battery through
    Please can you tell why and where you read about it ? Is it only true for the first original battery coming with the body (aka it has something to do with the body) ? Or is this also valid for any spare batteries bought separately (it has something to do with the batteries themselves and their coupling with the body ) ?
    Knorp's Avatar
    3,997
    Never charged any of my four batteries internally.
    And all is still well ...
    Kind regards.
    Bart ...
    May 2014
    5
    "Buy an external charger but do charge the internal battery through
    usb the first time at least."
    Simply to see if it works??
    Jul 2009
    363
    3
    As I understood it from the web fora, you need to charge the internal battery via the cord rather than simply putting in a charged up battery - first charge only apparently. Some people had camera trouble doing the latter.
    And it's best to use OEM batteries and chargers, they are both better and safer.
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    Quote Originally Posted by Annna T View Post
    The internal camera battery that maintains settings, clock, etc only gets charged by plugging the USB in and charging it when the camera comes from factory.
    It's in the manual.
    After that initial charge I recommend an external wall charger. They charge the batteries faster IMO.
    Knorp's Avatar
    3,997
    There's nothing in any manual suggesting you should charge your new battery internally (in camera) for the first time.
    However this is from the Help-guide regarding the internal battery:
    Interchangeable Lens Digital Camera
    ILCE-7/ILCE-7R
    On the internal rechargeable battery
    This camera has an internal rechargeable battery for maintaining the date and time and other settings
    regardless of whether the power is on or off, or whether the battery pack is charged or discharged. This
    rechargeable battery is continually charged as long as you are using the product. However, if you use the
    product for only short periods, it gradually discharges. If you do not use the product at all for about 2 month(s) it
    becomes completely discharged. In this case, be sure to charge this rechargeable battery before using the
    product. However, even if this rechargeable battery is not charged, you can still use the product as long as you
    do not record the date and time.
    Charging method of the internal rechargeable battery
    Insert a charged battery pack into the product, or connect the product to a wall outlet (wall socket) using the AC
    Adaptor (supplied), and leave the product for 24 hours or more with the power off.
    Bart ...
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    I have never charged my a7r via USB, not once, in the five full months I've had the camera. The internal battery works just fine.
    Bill
