Guy Mancuso
Administrator, Instructor
I shot these identical. So here is the process the A7r shot with the ZA 24mm F2 lens at F8 BUT IN CROP MODE. Than switched bodies with the A6000 shot it identical. Now i processed them both exactly the same in ACR since thats all I can use with the A6000. I gave them both equal shadow recovery and highlights. Im processing for the best image but I did everything the same. Now I figured out the dang sharpening in this program. I also found the secret don't use detail over 10 or either files gets bad artifacts. So sharpening at 100 radius at .7 detail at 10 and clarity at 8. Now they look nice and sharp but IMHO its a perfect combination of drawing the most out of the file without going overboard which a lot of people do. Maybe not so much here but i do see a lot of over sharpened images on the web, people get crazy. I want to get just above slightly soft but with detail. Im a little anal on sharpening and never take it too far. Anyway if you look at both these files I can't tell the dang difference. Now obviously I am in crop mode and would not normally do that with a A7r but what I was after is how good is this A6000 and no crop mode with 24mpx which for me is a big interest since I am trying to get longer on some lenses.
Anyway too long a paragraph there sorry . But I shot a bunch of these and Im pretty dang impressed with the A6000. BTW I did test my 24mm F2 since I just bought it used and its a good copy in my mind at 5.6 the corners look very good at F2.8 the center is a razor and stopping down anymore does nothing more. Boarders look very good at 5.6 as well and I am not going to bore you with showing all that in images just trust me the ZA 24mm can produce at F8 no one would every complain about the corners even to the picky pixel peeper that I am it would make stunning images. It may even be slightly better than my Zeiss 25mm F2. Ill take that anyday of the week
Okay to the two images . If you can guess them apart immediately than good on you. Its tough
