Results 1 to 10 of 10
Thread: M.M Function in "manual" mode on Sony A7R?
    Apr 2014
    130
    Am just wondering if anyone is able to shed some light on what the M.M function does when the Sony A7R is set to "manual" mode?
    Would be amazing if someone could clear this up for me!
    Thanks a lot!
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,928
    Re: M.M Function in "manual" mode on Sony A7R?
    Quote Originally Posted by wallpaperviking View Post
    Thanks a lot!
    Sorry, what is the "M.M function"?
    Wisconsin
    3,581
    118
    I looked at my camera. I looked in Gary Friedman's book on A7r. I looked in the manual. I couldn't find any information on what you are seeing. Please give us more information on what you are seeing. If it is in the function menu, then what is in the block on either side of it?
    Apr 2014
    130
    The reason that neither of you could see it was probably because I did a terrible job of explaining what I meant! My apologies for that...
    So I guess the "M.M" is not even a function but maybe more of an indicator that appears on the bottom of the taking screen, to the left of the ISO and to the right of the aperture (the way my camera is setup). I think it changes in value between -2 to +2 . It only seems to be there in "M" mode and when switched to another mode (S,A,P) it is replaced by the exposure compensation wheel value.
    I hope this explains what I mean.. If not, I will attempt to take a photo of it when my camera comes off charge..
    Wisconsin
    3,581
    118
    A picture would be good. I looked at mine and don't have that. I changed a lot of settings from the default on mine, so I may not be seeing the same display.
    Apr 2014
    130
    Hope this better illustrates it, excuse the tape...
    Look forward to everyones thoughts..
    Wisconsin
    3,581
    118
    You are in manual mode. You have iso set at 100, shutter set to 1/125 and f stop at f/11. These are all fixed, so the camera is telling you that if you shoot like this, you will be underexposed by 2 stops (or more if blinking). You will notice that if you set the iso to Auto, then the iso will float up and down and you will get the correct exposure (unless you exceed the caps on iso...then it will blink).
    In manual mode, there is no exposure compensation. M.M. -2 is telling you that you are in manual mode and are two stops (or more if blinking) underexposed.
    Jun 2011
    52
    Like Cindy said. It means Metered Manual.
    Check
    https://docs.sony.com/release/ILCE-7_7R_guide_EN.pdf
    https://www.flickr.com/photos/janzander/
    Wisconsin
    3,581
    118
    Quote Originally Posted by jfzander View Post
    Check
    Yes, this explains it better than I did. Page 138 of the above document.
    "When [ISO] is set to other than [ISO AUTO], use MM (Metered Manual) to check the exposure value. Toward +: Images become brighter.
    Toward − : Images become darker.
    0: Appropriate exposure analyzed by the product"
    Thank you, jfzander!
    Apr 2014
    130
    Ah Ha! Mystery solved!
    Thanks so much, much appreciated!
