Results 1 to 23 of 23
Thread: Zeiss 12mm E lens on a A7r
    23,623
    2555
    Thought this was worth a try. I have the Zeiss 12mm Touit lens for my A6000 which is a 18mm on a Full Frame sensor. So on the A7r I shot it with the APC crop mode on and got the first image a 18mm FOV. It would be the same on the A6000 so no gain here shooting it on the A7r since it would be less than the A6000 24mpx but again it could be useful to the A7r as a 18mm if you are not carrying the A6000 with you or for whatever reason. Its small its really cheap right now and damn good.
    But here was more a interest to me on the A7r is with the APC crop mode off your shooting right to the image circle which by default cropped is a square cutting out the vignetting.
    So here is what I did I shot normal crop mode than shot it to the image circle processed them both out put a color mask over the APC crop image and laid it perfectly in place over the Image circle image. What you get is a touch of extra room on the sides but depending on your subject you could crop in various directions.
    This might actually be useful with interiors if your trying to get more ceiling or floor for that matter or a square may work better. Obviously not limited to interiors but still a quite interesting option if you so want to try it.
    This is the APC crop version ala 18mm equiv.
    Than this is the full image circle image with the crop overlaid on it so you can see the extra room you may want.
    www.guymancusophotography.com
    23,623
    2555
    Re: Zeiss 12mm E lens on a A7r
    Now there is a baffle surrounding the rear element that is connected with 3 screws and it comes straight out which I did do but I am not seeing anymore image circle worth removing the baffle for. So its going back in as it does cover the lens electronics.
    So IMHO not worth doing it
    Manchester/Jerusalem
    2,652
    290
    MR over at LL is using his on his A7r, he says that when shooting it FF you get a 16mm FOV. For those who got this with the half price deal, that's not a bad price for a 16mm Zeiss which is apparently very good in the corners.
    2,652
    290
    It would be cool if you could use a custom grid as you can with Canon, is there any way to use something like that on the Sony?
    23,623
    2555
    I would tend to agree its about 16mm and you could work on the extreme corners if you had too a little.
    Grid lines options
    Rule of thirds
    square grid
    Diagonal square grid. Which is pretty interesting. Need to check that out as the diagonals go right through the image circle and you can see your width really nicely. This is the one you want to use
    23,623
    2555
    Here is the diagional with square grid line option. Look at the diagonal. This was shot with the a6000 of the A7r LCD screen.
    23,623
    2555
    Cindy and I split the Zeiss package as she wanted the 30mm and I wanted the 12mm. Worked out great as we both saved a bunch of money.
    2,652
    290
    So if you join up the diagonals do you get your 2:3 crop?
    May 2011
    Paris, France
    337
    That said, Guy, why not get a cheap NEX 7 and enjoy the Touit 12 with 24Mp rather than 16 on the A7R in crop mode? BTW, FE lenses such as the 35 and the 55 work just fine on the NEX 7 as well.
    23,623
    2555
    I have a A6000 so that's what I bought it for but I was just interested to see what shooting to the image circle would do.
    23,623
    2555
    I believe it does since the diagonal run from each full frame corner.
    23,623
    2555
    I actually have the A7r, A6000 and the new A77II bodies. All my lenses work on all three except 2 the 12 and 55. I'm debating keeping the 55 and getting the Sigma 50 art as that would also work with all three. For now I'm mostly trying to stay A mount until Sony gets more FE glass out but if they do come out with a bigger Sensor body with the 50 mpx sensor sensor the A7r is history. What I'm doing right now is playing the waiting game until Photokinia and see what they throw at us. I'm not 100 percent on the FE bodies until I see what they do. Seriously they are the only ones with any options worth a damn. Nikon and canon are falling off the cliff. A updated D800 is not innovating to me.
    23,623
    2555
    I'm actually running out the door and shoot the A6000 with the 12mm and the A77II. I have yet to actually shoot them
    2,652
    290
    There is a rather large difference in size between the 55mm and the Sigma Art! Would really not like the latter hanging off my A7r.
    23,623
    2555
    Maybe just bite the bullet and sell the 55 and get the 24-70 as it just fills in a lot if gaps with the A7r and A6000. I have for the A7r the ZA 24, Sigma35 art and 85, 135 and I'm not the biggest 50 mm shooter to begin with. Gives the A6000 a 12 and a 24-70 in the process. Now I'm using LR I get the lens profiles at least.
    Senior Member dchew's Avatar
    Feb 2011
    Northeast Ohio
    971
    Guy,
    All I know is you need more camera bags in that closet. Your not living up to your reputation.
    Dave
    davechewphotography.com
    23,623
    2555
    Ah you missed two more over on the left. There all think tank bags , I buy nothing else. LOL
    Yea now with 3 bodies I need to be thinking about a fresh one. Lol
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    You'll kick yourself for giving up the 55 for the 24-70. The 55 is special and the 24-70 doesn't gain a tremendous amount of IQ over the kit lens considering the cost of the thing. It's a good lens for sure but not one I'd say was "special."
  19. #19
    23,623
    2555
    No it's not special at all. Why I have yet to pull the trigger on it
  20. #20
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    Smart man. Keep the 55 and just live with the 28-70 for the time being.
  21. #21
    Senior Member Show Performance's Avatar
    Dec 2009
    Austin, TX
    851
    5
    The 55mm is a lens that just continues to inspire confidence and satisfaction.
  22. #22
    Jul 2010
    495
    Can someone measure the outside diameter of the hood? I need a neoprene cap for it. Thanks.
  23. #23
    23,623
    2555
    Quote Originally Posted by ken_vs_ryu View Post
    3.5 inches
