Results 1 to 6 of 6
Thread: A99 focus doubt
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    A99 focus doubt
    I was doing some tests and while shooting in auto focus mode if I click on the magnifier button it does magnify the image but it won't let me manually focus. If I click on the AF/MF it lets me manually focus but it won't let me magnify (unless I presse BOTH buttons at the same time, which is crazy). On my NEX/E-mount cameras my focus can be set to AF and at the click of a button I can magnify AND manually focus...and as soon as I let go of the button I'm back in AF. If this cannot be done on the A99 then the magnify button is useless, because nobody is going to be holding on to the AF/MF button and then looking to press the magnify button.
    Senior Member ryc's Avatar
    Feb 2009
    Or-Y-Gun
    548
    Re: A99 focus doubt
    try focus mode dmf. it will af then switch to manual.
    Nov 2008
    Rio de Janeiro
    2,393
    Re: A99 focus doubt
    Many thanks. I will give it a go!
    Wisconsin
    3,581
    118
    Re: A99 focus doubt
    I don't have an A99 anymore, but I have 3 Sony cameras. I take focus off of the shutter button. I assign AF hold to the AF/MF button. I keep the camera set to Manual Focus all the time.
    To focus, I hit the AF/MF button and the camera focuses. Then I hit the magnify and tweak the focus by hand. Then press shutter. If you don't take the focus off of the shutter button, the camera will try to focus again when you are ready to press the shutter.
    -Cindy
    www.cindyflood.com
    www.flickr.com/cindyflood
    Nov 2008
    Rio de Janeiro
    2,393
    Re: A99 focus doubt
    Cindy, that is exactly what I started doing as dmf doesn't work with all lenses.
    Wisconsin
    3,581
    118
    Re: A99 focus doubt
    Glad you got your problem solved, Rafael.
    -Cindy
    www.cindyflood.com
