Results 1 to 14 of 14
Thread: A900: issue with the remote?
    8,498
    44
    When I finally got around to trying the Infrared Remote that came with the A900, it didn't work. (yes, I DID remove the plastic tab.)
    I called Sony and they had me remove the battery and then press each button twice to reset the unit, then reinstall the battery. That didn't work. I was then told to send it in to be looked at by a tech person. I was sure it was a dead battery, but got the run around from them about sending me a new battery.
    So, while ordering a few items from the Sony store, I just ordered a second remote for $29. since I wanted a back-up anyway. That arrived DOA also.
    Thinking that Sony was shipping remotes with dead batteries, I ordered 4 new batteries from B&H (they are cheap.) That also didn't help.
    Does your remote work? If so, when you press a button, does the little diode bulb in the front light up?
    Also, does anyone know if you can use a hardwire type electronic release? The ones I can find are for the smaller Sony's. If the remote is unreliable, I just as soon use a regular release anyway.
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,778
    Re: A900: issue with the remote?
    Hi Marc
    I'm ashamed to say I didn't even know that there WAS an IR remote
    I'll have a look this evening and see if it's in the box . . . and if it works.
    Just this guy you know
    nautilus
    Asking never hurts
    Do you know that the sensor is in front of the camera and that it will probably never work despite of what battery you use if you use the remote from the back side of the camera?
    There are two electronic cable releases, a short one and a longer one that work since Minolta times - with Sony cameras as well. You should find the socket mentioned in your manual.
    Senior Member Braeside's Avatar
    Jan 2009
    Fife, Scotland (UK)
    1,171
    Hi Marc,
    I just went to test mine for the first time (I have used this type of remote on my previous Sony A700). It didn't work - but the problem was the insulation sheet had snapped off and was still blocking the battery.
    After a few minutes of forcing to try and open the battery cover on the remote, I opted for reading the instructions to find I had to press the tab first and then try and open the battery lid.
    The LED on the front of the remote does not light up as it is infrared, however if you have a webcam you can see the IR light on that (my webcam in the iMac works for that).
    I presume that you are first putting the A900 into the Remote commander mode from the Drive button first? Then you hit shutter button on the remote and you should see the red light on the front of the camera flash.
    Note the 2 sec button on the IR remote does not do MLU unlike when you use the camera 2 sec timer which does. (If you need a remote and 2 sec timer with MLU then you have to use a wired remote, there are eBay items that work as well as the Sony wired remote).
    Hope that helps
    David Anderson
    8,498
    44
    Quote Originally Posted by nautilus View Post
    Asking never hurts
    Yes I know ... no luck.
    Does the little light on the front of the remote light up is the question. Mine doesn't on either unit with new batteries and all.
    I'll look into the hardwire release, but couldn't find any info in the A900 manual ... but I'll look again.
    Jan 2009
    Fife, Scotland (UK)
    1,171
    No the light on the front is INFRA-RED so you cannot see it (unless you use a camera that is IR sensitive like most video webcams).
    David Anderson
    Jan 2009
    Fife, Scotland (UK)
    1,171
    David Anderson
    Jan 2009
    Fife, Scotland (UK)
    1,171
    Remote terminal Page 40 Item 6 in the manual
    David Anderson
    LargeFormat
    Not wishing to teach anyone to suck eggs but you are aware that the camera has to be set to receive the signal from the remote control. By the way I find it a huge advance over the ordinary delayed action.
    8,498
    44
    Quote Originally Posted by LargeFormat View Post
    I suspected as much. But I'll be darned if I can find how to set it to recieve the signal in the manual ... can you please share the secret?
    Thanks, -Marc
    FOUND IT >>> PG 83 ... sets with the Drive selector ... Dunce cap for me.
    Why the Sony tech folks didn't mention that amazes me
    Member picman's Avatar
    139
    Really?
    Jan 2009
    Fife, Scotland (UK)
    1,171
    I did mention it in post #4
    David Anderson
    LargeFormat
    It's not very obvious.
    Jan 2009
    Fife, Scotland (UK)
    1,171
    What's not obvious? - my post or the Sony instructions in the manual?
    I said in Post #4
    David Anderson
