Page 1 of 2 1 2 LastLast
Results 1 to 50 of 92
Thread: 25mm E-mount lens for $15 (it's a Holga!)
    Jan 2013
    Minnesota, USA
    933
    I was looking at pinhole offerings and stumbled across this on eBay. I think I'll invest the fifteen dollars to see what it can do.
    Dec 2012
    Portland, Maine
    94
    Re: 25mm E-mount lens for $15 (it's a Holga!)
    Post up some examples. I am not too hopeful, but I usually lose a lot more money on my ideas.
    Los Altos, CA
    10,486
    1031
    Hard to go wrong for $15
    (I bought one !)
    home: www.getdpi.com
    Jan 2013
    Minnesota, USA
    933
    Indeed! I've had lens caps that cost significantly more than that.
    Dec 2012
    Portland, Maine
    94
    Had a look at his listing. He sells in many categories. Radios, fashion and sex toys to name a few. Too bad you already spent all your money on that expensive lens.
    Jan 2013
    Minnesota, USA
    933
    I bought one
    Now that you're getting this amazing lens, I imagine you're ready to part with that Mitakon lens, cheap!
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,926
    One of those in mFT mount came with the Olympus E-PL1 I bought for about a hundred dollars the year before last. My only problem with it is that it's too sharp... !
    Godfrey - GDGPhoto Flickr Stream
    Los Altos, CA
    10,486
    1031
    So a Sony body cap is cheaper by $10: http://www.bhphotovideo.com/c/produc...Body_Lens.html
    But I figure this is at least a $10 more useful body cap One upside for us on the lens above is it's designed for M4/3 sensor E mount, not the full-frame. So it will prolly have significant falloff and loss of resolution, and being a decent wide focal should crop nicely to square for a vintage vignette look
    And no way I'm getting rid of the Mitakon. It performs SUPERBLY well on the Sony wide open in the typical light and shooting distances I will be using it at thank you very much!!! Taking the thread a bit off topic, but not all lenses work well when adapted to the Sony -- some M lenses come to mind, ahem -- but this one is designed for it, and works very well!
    Godfrey's Avatar
    Jan 2009
    7,926
    Some examples of the Holga 25mm toy/pinhole lens, taken with E-PL1 (no cropping, no alterations, straight from JPEGs, all at ISO 1600, etc):
    Above photo flipped right to left for correct orientation...
    A fun little thing.
    Los Altos, CA
    10,486
    1031
    Godfrey, that is the same lens we ordered, but I don't think we can call it a "pinhole" if it has glass But regardless, I do like the look (and your images!), and imagine the look on full frame cropped square -- to your full width in both directions -- and I think it could be cool!
    And then I just bought some other weird stuff to mount to the A7r too, cost a little bit more than the Holga lenscap though -- stay tuned
    Jan 2013
    Minnesota, USA
    933
    ...I don't think we can call it a "pinhole" if it has glass
    If by 'glass', you mean plastic!
    Godfrey's Avatar
    Jan 2009
    7,926
    Absolutely true ... It's essentially a zone plate with a large diameter central pinhole behind a single element, plastic lens. Pretty clever way to make a "fast" lens that performs remarkably well for almost nothing. :-)
    It's fun, but don't expect top notch quality on the mount... !
    Los Altos, CA
    10,486
    1031
    LOL, no big expectations here, other than a digital Lomo look
    Jan 2013
    Minnesota, USA
    933
    The super-elastic-bubble-plastic Holga 25mm lens arrived today. It's everything you might expect for US $15.
    These are from the A7R, set to APS-C crop mode. (maximum vignette correction applied in LR, but it didn't help much.)
    Jan 2013
    Minnesota, USA
    933
    Here's a 100% center crop from that last shot.
    Godfrey's Avatar
    Jan 2009
    7,926
    Yup. As I said, it's too sharp...
    enjoy it! :-)
    Los Altos, CA
    10,486
    1031
    Godfrey's right -- it's too sharp. We need to figure out how to decenter the lens and add some light leaks
    Maybe a very slight Scotchbright scrub pass on the plastic element? Or a spritz of hairspray?? Or maybe a dab from Q-tip soaked with acetone???
    4,333
    Oh crap - now you have me thinking of getting one. May as well before the price goes up to $20.00....
    Don Libby
    Iron Creek Photography
    Blog
    Tucson AZ
  19. #19
    4,333
    Yup! Just placed my order. Lets see what it does to IR...
    Don Libby
    Blog
    Tucson AZ
  20. #20
    Los Altos, CA
    10,486
    1031
    GEAR SLUT!
  21. #21
    4,333
    I just need to break it to Sandy that I brought another lens. The good news it's under $20.00 and is a 179 expense....
    Don Libby
    Blog
    Tucson AZ
  22. #22
    belgļe
    1,492
    2
    Stop, stop, stop!!! I can't believe I'm even thinking about this
    more pics, please!
    my flickr
  23. #23
    4,333
    Quote Originally Posted by cam View Post
    more pics, please!
    I feel your pain! Then I thought how bad could it be? It's less than $20 and I just spent that at lunch. So I broke down and ordered one; still don't have the guts to tell Sandy
    Don Libby
    Blog
    Tucson AZ
  24. #24
    belgļe
    1,492
    2
    Tell Sandy you took me out for lunch
    my flickr
  25. #25
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Quote Originally Posted by MikeEvangelist View Post
    I bought one. It was a bit too late to realise that it was for APS-C (NEX). No harm done, I will give it to my son for his NEX-5N.
    While being awestruck by this (and the mistake with the formats), I discovered that none other than Nikon has a fantastic product that will turn any lens into a Holga, namely the D750.
    [Google D750 spits out fantastic Holgaish images]
    A bit pricey (2099 Euros) but I am going to get one soon (they are threatening a fix, so I need hurry before they mess it up), seriously!
  26. #26
    Mar 2014
    235
    31
    Aren't you the guy who, just three days ago in the 'A9: Coming Soon to You' thread, posted that you were going to take a break from the forum for a few months because of all the troll posts?
    Just curious.
  27. #27
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    A quote from elsewhere about the D750 flare from a Nikonista changed my perspective:
    In the past, consumers simply learned the limitations of the goods that they bought and devised ways to get around them – now we seem to see an increasing bunch of litigious cry-babies!
    My Nikon user friends are wise!
  28. #28
    Mar 2014
    235
    31
    I'm just happy to see you back after your long exile!
  29. #29
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    When the NEX-5 came out, I fashioned this "thing". Fixed aperture and can be focused from infinity to ~10cm. Vignetting and color drift are plenty (it got spoiled with the later generation NEX', unfortunately). FWIW, it does very well in IR.
    Untitled by Vivek Iyer, on Flickr
    NEX-C3 ("full spectrum") with 23/2.8 Tessar (from a Rollei 110)
    A camera bag from an old Olympus pen D is a bit too big for this outfit!
  30. #30
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    At its closest focus distance (NEX-6)
  31. #31
    Jan 2013
    Minnesota, USA
    933
    What did that little Rollei lens come from, originally?
  32. #32
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Mike, From a Rollei 110 (Rollei 110 Variations).
    [The bits needed: A NEX to C-mount adapter, a C mount extension ring, a C-mount to M10 adapter.]
  33. #33
    Jan 2013
    Minnesota, USA
    933
    Makes me wonder how the 40mm Tessar from my old Rollei 35 would work on the a7 - (if some sort of Frankenstein mount could be cobbled together.)
  34. #34
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    That will cover the whole frame.
    35mm and up (for a Tessar) would cover the FF. I have a prewar, uncoated 3cm f/2.8 Tessar (from a Robot camera) that almost covers at infinity.
  35. #35
    Jan 2013
    Minnesota, USA
    933
    Have you ever tried any of the Pentax 110 lenses? I'm curious what size image circle they have.
  36. #36
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    I mounted an 18/2.8 in C mount (for tiny format, G1) a while ago and have posted about it there. That one illuminates APS-C. The 50/2.8 might also do that. There is even an adapter available for them now!
    My Robot Tessar 3cm f/2.8 with a proper adapter:
    Actually illuminates the whole frame at infinity, wide open and covers it when stopped down.
  37. #37
    Jan 2013
    Minnesota, USA
    933
    That sounds like a fun little diversion. I'll have to get one of those adapters. (I've got a couple of the Pentax 110 lenses in the 'museum'.)
  38. #38
    Jan 2013
    Minnesota, USA
    933
    Thanks for the idea! I picked up the Fotasy adapter. Frankly amazed at how good these minuscule lenses are.
    Images on the 'Old lenses' thread - http://www.getdpi.com/forum/621113-post282.html
  39. #39
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    My pleasure, Mike. . Perhaps, an A6000 is on your radar now?
  40. #40
    Jan 2013
    Minnesota, USA
    933
    No, I prefer full-frame cameras. Maybe an A9 though!?
  41. #41
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    I do as well but I also grab a NEX fot its size.
  42. #42
    Los Altos, CA
    10,486
    1031
    Okay. My lens arrived today and I just had time to play around with it. It's late, and so the only light I have is in my house, and I just took this snap in the TV room. And as you can see, I can happily say my lens is not like yours . It's not sharp, it does not have that massive vignette, and it renders a lot like I hoped it would!
    This shot is handheld at 1/8th, ISO 6400. There's more to the story that will come tomorrow after I've had time to shoot it in daylight, but I wanted to get this up tonight so all you that rise so much earlier than I do on the West coast can have time to noodle over it a bit. Here is a biggish tidbit for you:
    This image is FULL FRAME from the A7r, as shot except for converting it to monochrome since color was all squarked by artificial light:
    And here is another FULL FRAME A7r shot into a mirror. I am about 2 feet from the mirror, so net of me 4 feet from the camera. It is about a 25 or maybe a tad wider... This is an in-cam A7r jpeg, only downsized to 1200 px for web:
    Yes, it's got a wee bit of pincushion. And I love that too! Heck, I may enjoy this lens more than the Mitakon!
    Okay, one more tidbit for you -- I did do a teensy-weensy modification to the lens
  43. #43
    Los Altos, CA
    10,486
    1031
    Just for giggles, here are the above images cropped square -- which is how I planned to use it, emulating the 120 square Holga look. Well okay, 24MP of Holga-esque look I might need to actually add a bit of vignette for the final effect I'm after, but it is surprisingly close as is! I need to shoot it more in real light and situations, but I am pretty stoked on the possibilities it's showing here. More tomorrow!
  44. #44
    Godfrey's Avatar
    Jan 2009
    7,926
    It's a grand little plastic, fantastic picture machine.
    Did you excise the diffusion plate?
    I got a new el cheapo lens today too: an Olympus 9mm f/8 Fish-eye Body Cap Lens for the E-PL1 and E-PL7. But it's a wee, five-element lens with real optical glass... :-)
    Jan 2013
    Minnesota, USA
    933
    it does not have that massive vignette, and it renders a lot like I hoped it would!...
    How can there be so much difference in frame coverage? What did you do to yours? Did you take out the zone plate?
  46. #46
    Los Altos, CA
    10,486
    1031
    You guys nailed it.
    Carefully remove the little plastic aperture plate over the rear element. It is thin plastic and glued in. I used a small spring hook threaded carefully into the main aperture hole and pulled it out. A hook made from a paper-clip should do it.
    Presto, now all of the lens aberrations can get through to the sensor, as well as the full image circle. And we perhaps also gain another stop in the process.
  47. #47
    Jan 2013
    Minnesota, USA
    933
    Excellent!
  48. #48
    4,333
    Just checked the tracking on mine, looks like it could be here sometime within the next 4-days. Then I'll have to confess to the boss I bought another lens. Wish me luck.
    Don Libby
    Blog
    Tucson AZ
  49. #49
    4,333
    Jack, so you're saying to remove the plastic plate on the rear? Again, what does that do to improve the quality (I'm dense this morning). Also I guess it voids the $15.00 warranty...
    Don Libby
    Blog
    Tucson AZ
  50. #50
    Los Altos, CA
    10,486
    1031
    Don,
    If you look at Mike's pics above, you'll see a very heavy vignette and relatively sharp performance, and he posted those from APS-C format crop in his A7r. If you look at mine, they are FULL frame 35 from the A7r, show less vignette than APS-C and then a sharpness and falloff performance are visible, more gradual, and what we generally associate more with Holga/Lomo optics. The lens comes with a plastic rear aperture plate with "sink strainer" soft holes around the center aperture. The only difference in Mike's shots and mine are I removed that aperture plate to get the full image circle (and all optical aberrations) to the full frame sensor. And yes, I'm certain it voided the warranty, but OTOH I saved the aperture disc and could glue it back in at any time -- though my guess is I won't be doing that ever
    Hope that clarifies,
