Results 1 to 2 of 2
Thread: A7II First Technical Problem? - screen flicker and blackout
    Member limbonaut's Avatar
    Dec 2010
    53
    It happened once before when I pointed the screen upwards. Now it's happening every time. The screen image will slide down and continue repeating util greying out and then blacking out. I've removed the battery and it continues to malfunction. If the screen is left in the stowed position there is no problem.
    Anyone else experience this issue?
    Mine's going back for now. Hopefully B&H will have a replacement.
    Jan 2015
    2
    Re: A7II First Technical Problem? - screen flicker and blackout
    I bought an A7II right before Xmas. After about 20 photos the camera would lock up and the screen would go black. It happened about 4 times. The only way to fix it was to remove the lens and remount it. Battery removal wouldn't even work. I ended up returning it to Sony Store USA for a refund.
