Results 1 to 14 of 14
Thread: Flash on Sony
    Nov 2009
    Berkshires, MA
    262
    Flash on Sony
    New to Sony flash. Is Sony's flash a non-standard interface on the hot shoe?
    I'm looking to pick up a hot shoe to miniphone to go to off camera flash. Will a standard hot shoe work, or do I need something from Sony?
    Camera is A7r
    Shaun O'Boyle
    new.oboylephoto.com
    Jan 2013
    Minnesota, USA
    933
    Re: Flash on Sony
    The a7 series has what's called the 'multi-interface' hotshoe. It works like a normal hotshoe for simple firing of a flash, but includes additional pins for TTL, etc when used with dedicated devices.
    So yes, a standard shoe should work as expected.
    Nov 2009
    Berkshires, MA
    262
    Re: Flash on Sony
    Great, thanks Mike. Good to hear it will not be an issue when I add pocket wizards in the future also.
    Shaun O'Boyle
    new.oboylephoto.com
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    Re: Flash on Sony
    It is an issue and the Sony hotshoe is unreliable! Check every time before firing!
    Jan 2013
    Minnesota, USA
    933
    Re: Flash on Sony
    Unreliable in what way? (I don't use flash very often, but it's worked fine for me.)
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,610
    21
    Re: Flash on Sony
    Won"t fire all the time and it varies on the fit of the transmitter/ contact.
    Moreover, the highest sync speeds are 1 stop less than advertised ( that only works with Sony or Sony compatible flashes). Sony really screwed up the flash mount.
    23,623
    2555
    Re: Flash on Sony
    I use a Sony 43 on camera and pocket wizards for my Dynalites. Both work just fine.
    www.guymancusophotography.com
    23,623
    2555
    Re: Flash on Sony
    I'm using both the A7r and A7II. I'm actually on big gig right now using both setups. The PW I use is the III
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    Re: Flash on Sony
    The Nissin i40 and PCB Einstein fired remotely both work fine with the A7 and A7r.
    Senior Member JMaher's Avatar
    Sarasota
    942
    16
    Re: Flash on Sony
    I have used Godox transmitters with no problems on studio flash. I have also used an old Nikon sb28 in auto with no misfires. A7r and A72
    Member Rollei6008i's Avatar
    Aug 2012
    HK
    106
    Re: Flash on Sony
    I also new to Sony(A99) , just a few(1 or 2) flashes can be found on the market, besides Sony brand, I choose Phottix which has sony mount & compatiable to original . Built in trigger & reciever, really good.
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    Re: Flash on Sony
    Quote Originally Posted by Rollei6008i View Post
    Agree the choices are limited if you want TTL but there are options from Phottix, Nissin, and of course Sony. The good thing is that most flashes/accessories will work in manual mode.
    Nov 2009
    Berkshires, MA
    262
    Re: Flash on Sony
    I'll be using the Lumopro 180 in manual. This flash gets a lot of recommendations, so interested to see how it works out on the A7r.
    Shaun O'Boyle
    new.oboylephoto.com
    iiiNelson's Avatar
    Sep 2008
    Kentucky
    3,187
    Re: Flash on Sony
    Quote Originally Posted by soboyle View Post
    I haven't used it myself but I'm sure all will be interested in your feedback. I heard good things about the Quantum (or Quantaray... I forget) Strobie but it was from a salesman as well.
