Results 1 to 6 of 6
Thread: Is there an off-camera TTL extension cable available?
    Senior Member mjm6's Avatar
    Jul 2009
    Sacramento, CA
    526
    15
    OK, so I am putting together a flash arrangement for my Sony A7R and need to be able to do some shooting with the flash off the camera. I doubt I need TTL, but let's start with that...
    I want an adapter cable to use the flash off the camera and still have TTL sync. I don't want to cobble together a cable in pieces with Sony's adapter blocks and the coiled jack. Does anyone know if anyone is making a cable to do that in a single piece?
    There's plenty for the old Sony/Minolta flash shoe, but seemingly none for the newer multi-interface shoe.
    Second, if that fails, what about just a hotshoe to hotshoe connector? Non-TTL. Do the contacts in the multi-interface shoe interfere with making that old approach viable?
    Thanks,
    ---Michael
    a7r, a7rII, FE 16-35, FE 24-70GM, FE 70-200, Loxia 21mm, 35mm, 50mm
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,604
    21
    Re: Is there an off-camera TTL extension cable available?
    Phottix has the wireless (radio) TTL trans/receivers and flashes.
    AFAIK, no cable TTL exists for the current flash shoe.
    Single point (non TTL) cable, like the old Nikon SC-17 works. The sync speeds you would get out of that is less than the maximum possible.
    Jul 2009
    Sacramento, CA
    526
    15
    Thanks Vivek, that is what I feared based on my searching around.
    I'm OK with a non-dedicated cord, so I'll go that route for the time being. Maybe put together a TTL setup later, but for my initial purpose, I really just need a reliable trigger.
    I also don't need to worry about the sync speed, because this is primarily for copy work, and I'll be tripod mounted and can work at any speed of my choosing.
    ---Michael
    Mar 2014
    Espoo, Finland
    125
    ADP-MAA and ADP-AMA adapters + old hotshoe TTL cable will give this functionality if one absolutely needs it. I actually modified a cable for old hotshoe with some RJ45-connectors so that I can extend a TTL cable with any CAT-6 cable. Worked just perfect with the longest cable I tested which was 5 meters if I remember correctly.
    Jul 2009
    Sacramento, CA
    526
    15
    tn1krr,
    I'm a little unclear on what you did. Can you show us a photo or two? I've made up cable in the past, and also wired CAT 5 & 6 so this is no problem for me to do, but I'd need to get a hold of the appropriate interface blocks from someone to do it properly.
    Thanks,
    ---Michael
    Mar 2014
    Espoo, Finland
    125
    Quote Originally Posted by mjm6 View Post
    tn1krr,
    I just cut a "Minolta" TTL cable in the middle and added RJ-45 connector to both ends just cut. After than I can use any RJ-45 cables/connectors to extend the cable to eany length needed. I'll see if I can find that cable (been a while since I used it) and take a pic if needed.
