Results 1 to 31 of 31
Thread: A couple of questions about the 5 axis satibilization
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Sony offer 5 axis stabilization in their A7 II. This can only be achieved when there is OSS in a lens.
    1. This rules out any possibility of using a fast lens (only slow zooms). Correct?
    2. Can the IS offered by the Canon lenses be used to achieve 5 axis stabilization (thus offering possibilities to use fast lenses- prime or zoom)?
    TIA!
    23,623
    2555
    Re: A couple of questions about the 5 axis satibilization
    Ibis is in the body but I think it must be a Sony FE or A mount lens with adapter to achieve all 5 axis. I think 3rd party are 3 axis only but we need to double check my memory here .
    www.guymancusophotography.com
    23,623
    2555
    I can tell you this it works really nice with my Minolta 200mm with adapter . I can squeeze about 1/30 th out of it if I'm having a good day. Lol
    That's damn good
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    That's damn good
    Guy, That (IBIS) will work similarly with my Tamron adaptall 200/3.5 as well. Still, that is not 5 axis.
    Mar 2010
    Lindenberg im Allgäu
    1,294
    12
    I am looking forward to use this 3 axis stabilization with my 1,2/55 and 1,2/85 FD-L lenses. Open aperture with some tilt in near darkness...... rrrrrrrrrrrr
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Quote Originally Posted by Stefan Steib View Post
    Of course, the orphaned system lenses get a new lease.
    Stefan have you tried any of your Canon IS lenses on the A7 III, do you get 5 axis?
    Nov 2009
    11
    Five axis stabilization is available with select non-OSS lenses. From a blog by Brian Smith:
    "Only those lenses without OSS, such as non-OSS E-mount lenses, and 8-pin A-mount lenses when used with LA-EA series adapters, that can also communicate focal length and focal distance enjoy 5-axis IS from the camera. Sony E mount lenses with OSS get 3-axis compensation from the camera, and the other 2-axis pitch and yaw compensation from the lens."
    I don't think that he stated the above very clearly but - a non-OSS lens that transmits focal length and focus distance to the body will result in five axis stabilization. The lenses that do that have 8 pin connectors.
    Later,
    Johnny
    Apr 2008
    1,446
    Vivek, according to Metabones website, with the latest firmware update for the Smart adapter iv canon EF to Fe mount is meant to supply correct data to the a7ii so it can use 5 axis stabilization with both Canon IS and non IS lens. What is most interesting is it states that with IS canon lenses the lens IS will be used in combination with IBIS, similar to how native FE OSS lenses use the 5 axis stabilization.
    Senior Member pegelli's Avatar
    Dec 2010
    Belgium
    2,119
    Interesting question and I think reading between the lines of what Johnny provides in his post gives a very logical answer.
    Question I have is how you would be able to show if with a certain lens you get 3 or 5 axis stabilization? Other than that it should (or could) work when the lens transmits focal length and focal distance is there any way to find out if it did (from the exif, the camera or the picture) ?
    My Pics
    23,623
    2555
    It does I'm using the Lae4 Sony adapter and its a A mount. I'm pretty sure the Minokta is getting 5 but I could be wrong.
    Nov 2009
    11
    But isn't the 200/2.8 a five contact lens? If so it's only getting three axis.
    Later,
    Johnny
    Dec 2010
    Belgium
    2,119
    As far as I know the 200/2.8 (in both the standard and HS configuration) only has 5 pins and does not transmit focal distance to the camera. So my suspicion is that it gets 3 axis stabilization and not 5.
    However if you look on this blog (and following the links in the first paragraph) by Jim Kasson he doesn't measure a lot of difference in IBIS effectiveness between cases of 5 axis (E55/1.8) and 3 Axis (180 mm Apo Telyt and 28 mm Elmarit R). So while there is a theoretical difference, in actual practice the differences might be negligible.
    My Pics
    23,623
    2555
    Interesting . I could not tell between 3 and 5 if it yelled at me. LOL
    I do get EXIF data for the 200 and it does show in C1
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Johnny and Mazor, Thanks! That IS new information.
    Good!
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Quote Originally Posted by pegelli
    Perhaps, block those extra 3 pins and shoot a before and after picture?
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,300
    IIRC pitch, yaw and roll corrections should benefit any lens with Sony's version of IBIS.
    For X and Y corrections the distance to subject must also be communicated to the camera.
    X and Y corrections are most important for macro photography, i.e. short subject distance.
    X and Y corrections go to zero for infinity focusing.
    With best regards, K-H.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    K-H, Thanks!
    Mar 2013
    239
    I'm questioning myself about a7II...for handheld shot with non FE lenses.
    1) ibis will only work with Fe lenses, canon+metabones, sony a+ adapter? Or could it work with all lenses by manual setting the focal?
    2)Could someone give me an idea of the bénéfice of the 3axes ibis, for example with 24mm what would be the minimum shutter time to get Sharp image, or say by how many stop do You improve your handheld shot.
    3)i'm actually working with a couple of a7r, do You feel that the sensor is similary calibrated as the a7r? Do You think i could work with a7ii and a7r and get the same color and contrast out of the box? Or is it really different?
    4) could someone share a raw with the canon 24tseII? same shot with a7r would be si cool...
    Thanks a lot
  19. #19
    Dec 2010
    Belgium
    2,119
    @ daf
    1) IBIS will work with any lens (minimum 3 axis, and 5 if the lens tells the camera at which distance it's focussed) and there is a window to provide the camera with the focal length
    2) Follow the link to Jim Kasson's blog in post # 12. He did an excellent (and I think statistically relevant) test on lenses between 16 and 180 mm. Short answer is he gained 2-3 stops vs. without IBIS.
    3) & 4) No idea. I have none of the equipment to make such a comparison.
  20. #20
    Dec 2010
    Belgium
    2,119
    You need to have a very consistent tremble for that to work (or do a very large number of tests so the results become statistically relevant). However looking at the results that Jim Kasson found (see link in post 12 above) my own conclusion is that 3 axis will work fine and 5 axis is just a vernier improvement (if at all)
  21. #21
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Quote Originally Posted by pegelli View Post
    Pieter, Appreciate your link but that applies to that guy only.
  22. #22
    Dec 2010
    Belgium
    2,119
    I think that's obvious, and it's true for every IBIS test published. Only if you have some kind of machine you could test in a consistent way, but then the question will be how well this translates to humans holding the camera in real field use
  23. #23
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    The questions were very simple, Pieter. 5 vs 3 and under what conditions they work in the A7 II. Not how effective (perceived or for real).
  24. #24
    Jul 2009
    Swiss Alps
    1,444
    3
    Then look at all the tests : Kasson tested the FE 55 F1.8 but also some M lenses (180mm, 16-21mm @ 16mm and a 28mm) aka one lens supporting 5 axes and others only 3 axes.
    It is a very useful link; what is the problem with it ?
  25. #25
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Annnna, I got some useful answers that pertains to my queries from Johnny, Mazor and K-H. If you enjoy reading general stuff, read them and enjoy them!
  26. #26
    Dec 2010
    Belgium
    2,119
    Vivek, sorry for hijacking your thread with raising subjects that do not directly answer the original question you raised. I was under the assumption that it is allowed to bring up subjects related the topic raised, but apparently I should refrain from that in the future, and I will.
  27. #27
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    Pieter, It is unrelated to the topic and you knew it. Aren't you a forum moderator somewhere?
  28. #28
    Dec 2010
    Belgium
    2,119
    Sorry, I thought (and still think) the topics were related. But now I understand your perspective I will refrain from commenting further on technical questions you raise unless it's a direct answer to it. No big deal.
  29. #29
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,603
    21
    I already thanked you for the link and your thoughts but I do not like anyone ramming their views for whatever reason. Your thoughts are appreciated and well received. Thanks again, Pieter!
  30. #30
    Dec 2010
    Belgium
    2,119
  31. #31
    Apr 2014
    Marin County, CA
    593
    Why don't you two just get a room already?
