Results 1 to 4 of 4
Thread: 21mm Color Skopar Real Talk
    Feb 2015
    311
    I know the 21/4 is not a great performer on the Sony's w/o sensor modification. Can anybody show an example of this lenses performance with and without the mod? I would use it creatively so ultimate corner sharpness is not super important to me. It just needs to be useable for a traveling handheld landscape.
    So far I use the 40/1.4 SC Nokton and a CY 50/1.4 Planar and the're fantastic.
    Thanks!
    Jul 2010
    495
    Re: 21mm Color Skopar Real Talk
    Have you checked the olympus 21mm? Friendlier on the A7.
    Nov 2010
    590
    Unfortuneately the handheld landscapes are what suffer the most. Infinity shots bring out the sensor issues and landscape detail suffers heavily outside the center on the stock cameras. Very few consider the CV 21/4 usable without a mod.
    On the Mod it is just usable, for me, but Nico at FM has some pretty decent architecture with the Mod.
    here is the CV21 at f/8 with Kolari sensor mod:
    a7M_CV21_8 by unoh7, on Flickr
    and f/11:
    a7M_CV21_11 by unoh7, on Flickr
    looks like f/11 is pretty acceptable really:
    the lens is so tiny, nothing to carry.
    BTW all mods are delayed due to a fire at Schott.
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,928
    Quote Originally Posted by Speedgraphic View Post
    Thanks!
    Personally, I found the amount of color shifting with the Color Skopar 21/4 on the A7 too much to deal with unless you're going to use image processing tools to reduce/remove it. The combination works ok for B&W if corners and edges don't need to be critically sharp. Using Lightroom and the Adobe Flat Field plugin to process raw files, you can get nearly perfect results from it.
