Sony A7R with Nikon PB6 Bellows
mjm6
Should be a normal Nikon to FE mount adapter.
https://support.nikonusa.com/app/an...-pb-6-bellows-with-a-nikon-digital-slr-camera
Some of the Nikon cameras would interfere with the bellows and couldn't mount without an extender installed, but I doubt that will be the case with the mirrorless cameras. The interference had to do with either a protruding pentaprism housing or the hand grip, which the Sony has neither of (or at least they are small to non-existent, especially considering the adapter you will be using).
I don't have a PB6, but I do use an Olympus bellows with the a7r, so things may be slightly different, but I suspect that you will have no problems.
