Results 1 to 23 of 23
Thread: Mysterious A7r Rear screen damage
    Jul 2012
    Liverpool, UK
    57
    Recently picked up a tidy used A7r and took it away to Spain with me the other week.
    I took it out of its bag one day and noticed these marks on the rear screen, they weren't there when I received it or earlier in the holiday. I haven't dropped or knocked it, they aren't cracks. Kept it away from moisture as much as possible, put it down on tables gently and put it in the bag when I didn't want it out.
    The only thing I can think is that it sat exposed to the sun one afternoon when I was out on the veranda. Was only 10-15mins exposure, I think, and I moved it as soon as I realized. I didn't notice any marks then and it wasn't hot, I remember checking. It was the next day I noticed them so thats what makes me think that the sun has maybe done something to the glue.
    Any thoughts??
    Senior Member mjm6's Avatar
    Jul 2009
    Sacramento, CA
    526
    15
    Re: Mysterious A7r Rear screen damage
    Does it have a screen protector on it? That's what it looks like to me...
    See if there is a plastic film screen protector on the screen. Go to the corner that has the bubbling and see if you can roll up a plastic layer with your fingernail. It shouldn't bee too strongly adhered. Don't force anything!
    If it's under the glass layer, then it appears to be some delamination, and there is probably nothing economically viable to do about it, other than the do your best to ignore it.
    ---Michael
    a7r, a7rII, FE 16-35, FE 24-70GM, FE 70-200, Loxia 21mm, 35mm, 50mm
    Jul 2012
    Liverpool, UK
    57
    No screen protector that I can see/feel, can't catch an edge.
    So guessing its delamination. Would the sun have caused it? Happened quite suddenly it seems.
    Senior Member JMaher's Avatar
    Sarasota
    942
    16
    I live in Florida and the camera is in the hot sun anytime I am outside. I have never experienced a similar problem.
    Jim
    Feb 2015
    Brooklyn, NY
    100
    Mine has the same issue, but it wasn't from one day to the next, it happened slowly over time. Not sure what caused it, i'm in Miami and use it constantly in many different environments.
    It's definitely some sort of delamination from the tint of the glass, but it's on the inner part, there's nothing we can do about it unfortunately.
    Jan 2013
    Minnesota, USA
    933
    Mine has a bit of that as well. Not as noticeable as yours. No idea what caused it.
    Jul 2012
    Liverpool, UK
    57
    I had seen one on ebay where most of the bottom and sides of the screen where like this, so was conscious when I bought the camera not to get one with any signs of it.
    I also thought I might have got something in the coating on the glass so tried sensor cleaning fluid on it but it didn't help.
    Definitely quite a sudden change, I was playing with the camera the day before I noticed it, so would have seen something then.
    Place I bought it from have a 6month warranty so might see what they say.
    Senior Member Joe Colson's Avatar
    Oct 2010
    North Carolina, USA
    1,908
    36
    Here's a post on my experience with a similar problem:
    http://www.getdpi.com/forum/584484-post4.html
    Camera was repaired in less time than estimated and LCD was replaced. No problems noticed since.
    Joe
    _________________________________
    Joe Colson Photography
    Jan 2008
    86
    I think you will find that the A7, A7II and A7R do in fact have a factory installed screen protector with anti-reflection coating. If you look carefully at the edge of the screen using a magnifier you can see the edge of the protector inset from the screen edge by a fraction of a mm. I asked Sony about this and was told there wasn't a protector but ....
    on my A7r and A7II you can clearly see it.
    I'd suggest it's this which has become delaminated. I haven't tried removing it from my cameras, I just put a Giottos glass protector on top of the "existing" protector.
    Bob.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Quote Originally Posted by craigosh View Post
    Not a good idea at all! It is plastic. Mild soap and a drop of water (avoiding the edges) would have been better.
    Jul 2009
    Swiss Alps
    1,444
    3
    I have the same problem. But I'm accustomed to it and don't see it anymore. For me it isn't a problem as long as it just stay so. The marks are there since a few months. They don't seem to get worse. I have decided to keep the camera as is.
    My camera fell once. But that isn't when the marks appeared; that was several weeks later. I noticed it once, but can't say whether it has been a sudden apparition, or whether it grew progressively.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Not only their value depreciate but they also self destruct?
    Senior Member pegelli's Avatar
    Dec 2010
    Belgium
    2,116
    My NEX5 and a friend's NEX7 also have the same problem, even a lot worse then your example. Never seen it on a a7x though. No idea what caused it either.
    Jul 2012
    Liverpool, UK
    57
    I'll live with it, just annoying as I've not had it a month yet?
    Camera's been fab so far, really enjoying using some borrowed Leica glass on it.
    Senior Member Slingers's Avatar
    Feb 2013
    Sydney, Australia
    457
    My NEX-7 has this, I believe it's the anti reflective coating that easily wears off. Only takes a little bit of friction to wear on the older cameras. With my A7S I put a screen protector on straight away and haven't had it happen to it.
    Apr 2008
    1,446
    As Slingers said, the marks is the anti reflective coating falling off. The only way to prevent this from happening is to apply a screen protector before this occurs, or apply TLc when using the camera.
    Jul 2012
    Liverpool, UK
    57
    So could this happen from walking round with it on my shoulder? Brushing against a tshirt? I was walking around lots with it on my shoulder..... Retailers say they know its a common issue, but no indication of cause, so asked me to send it back for them to look at it. Hopefully it will be replaced and I'll stick a protector on it straight away.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Take a tooth brush, half a drop of toothpaste, a drop of water and scrub the whole thing off (it does come off). Then add a protective cover (the variety that comes with its own anti reflective coating).
  19. #19
    Sep 2010
    287
    29
    I have the same problem since October, at first I thought it was a small scuff but it's spreading though not to the extent of yours, for now. I think it's some kind of manufacturing fault and they should address it by replacing these screens free.....
  20. #20
    Jul 2009
    Swiss Alps
    1,444
    3
    I have to say that I can see these marks only when the LCD is spent and only if I look at it from an angle. So I don't find it too disturbing, as there is zero effect on the viewing of the image once the LCD is on. Of course, I would prefer if it wasn't there, especially if I want to sell it or to give it to some family folk or friend (geven the fact that I've never been good at reselling my gear). All this plead against an update to the A7rII. That plus the fact that I don't need more pixel than 36MB and don't want a heavier body (my Canon 6D is only 150gr. heavier).
  21. #21
    Jul 2012
    Liverpool, UK
    57
    Well the dealer I bought it off has kindly offered to swap it over for me with another they have in stock, so I'll do that and get a protector for the screen this time.
  22. #22
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,055
    762
    I had the same once. well it looked the same. But I had a Sony screen protector on it and those are quiet thick. You can hardly see it. Took it of, cleaned everything and put it on again. No problem since.
  23. #23
    Nov 2010
    Auckland, NZ
    230
    Same thing happened to my RX-1.
    David
    Auckland, NZ.
