Results 1 to 24 of 24
Thread: Possible issues using EVF for manual focus on A7r ll ?
    Feb 2010
    Nashville, TN
    172
    Question Possible issues using EVF for manual focus on A7r ll ?
    I read on the Digital Lloyd blog that a user of the A7r ll reports that using the EVF for manual focus on the A7r ll is vastly inferior to the original A7r. Can anyone confirm or deny that this is an issue. This is a huge concern as I have the A7r ll on order. This would be a deal killer for me.
    Regards,
    J. Paul
    23,623
    2555
    Re: Possible issues using EVF for manual focus on A7r ll ?
    I'm going to check this today. Will report
    www.guymancusophotography.com
    Knorp's Avatar
    3,988
    vastly inferior ? no way !
    Bart ...
    Jul 2015
    22
    Quote Originally Posted by Knorp View Post
    I read that there are two settings and that it is possible that some reports are from people not realizing this and they have been using the lower quality one for the view finder. A person that has used the A7RII and set it to the high quality view, said it works great.
    23,623
    2555
    That's what it is starting to sound like and my bet the default is the lower setting and people are not setting up there cameras prior to using.
    Feb 2010
    Nashville, TN
    172
    Hello all, I am hoping your are right. The person went on to say that they had tried different settings, but I am not quite clear what they are and what the person tried. It very well could be user error. If anyone hears or has any other information or experience with this first hand please let me (and others) know.
    Thanks,
    J. Paul
    Knorp's Avatar
    3,988
    Quote Originally Posted by jamato8 View Post
    I even doubt the low quality view as vastly inferior.
    Bart ...
    Aug 2009
    Socorro, NM
    404
    Quote Originally Posted by jpaulmoore View Post
    Thanks,
    J. Paul
    I guess no one reads the manual nowadays . Personally, I didn't know that there is a setting for high and low quality for the EVF. There is no such thing on my A7s.
    Mar 2009
    Massachusetts and Vermont
    947
    Guy, if you go to Menu/"Setup" group of settings/Tab 2, there is a setting called "Display Quality." The default for the A7RII is "Standard", but you can set it to "High." This does impact the Live View for manual focusing. Interestingly, the A7R used "high" as the default, and the A7 used "Standard." Sony advises that the "High" setting can affect battery life and autofocus performance.
    23,623
    2555
    Camera just showed up. Heading there now. One cool thing the EVF size is certainly bigger
    23,623
    2555
    Im not seeing any issue whatsoever. Going from the 35 1.4 Zeiss /Sony to the CV 15 which maybe the hardest lens to focus manually since it has such large DOF. At 5x it looks very good and at 12.5 it looks very good. And yes the default is set to standard so make that change to high quality in the last top tab on your right than tab 2 than display quality. Im going to run outside and see if its the same in low light
    Aug 2009
    Socorro, NM
    404
    Guy, is there a huge difference between standard vs. high quality at 5x mag.?
    23,623
    2555
    Not really I see a little jump in quality on the high mode. I would certainly put it into high mode though
    You know folks as hard as the VC 15mm is to focus anyway even outside at 300 yards I'm nailing the house behind me at 12.5 and even 5x is not bad. Now I am slightly underexposing on the 15 but thats a little normal anyway.
    Now someone picking this up for the first time with a extreme wide than sure its a little tough compared to like the 35mm 1.4. There slower lensers and far more DOF.
    In all honesty its a non issue but I will keep my eye on things
    Sep 2013
    New York
    564
    Guy, this is great news. And thanks for the immediate feedback. Waiting to hear more. Don't know when mine is arriving, soon hopefully.
    Too much to list, let's just say I have a bad case of GAS.........
    Feb 2010
    Nashville, TN
    172
    Guy, thanks for clearing this up. I can breathe now
    J. Paul
    Senior Member ggibson's Avatar
    Oct 2009
    SF Bay Area
    743
    What's the difference between the two modes?
    23,623
    2555
    Quote Originally Posted by ggibson View Post
    It may have to do with refresh rate is what I am thinking. The difference is pretty minor but we need to look at that some more. I just finished setting up the camera and there are some new things like release priority. Need to look into that one for sure
    23,623
    2555
    If I maybe so bold to say this . I waited over a year for a body like this that operational was far better than the A7r than the A7II came along with a lot of good things well this one maybe just the freaking ticket we have been waiting for. So going forward its big positive for new owners and of course we will tear it apart and figure out some of those pesky little workarounds. But so far big thumbs up for Sony
  19. #19
    23,623
    2555
    Okay the standard setting I see things as pretty sharp but far more detail in the high setting. Mount camera on tripod and get a good focus on something than toggle the settings and you will see high just has more detail in the image. So if your set to standard focusing would be harder to do.
  20. #20
    Apr 2014
    Marin County, CA
    593
    On my A7ii the difference between high and standard is the noise. I see lots more noise bouncing around in standard mode which disappears in high mode.
  21. #21
    23,623
    2555
    Nice pickup Dan was not looking for that so much. Was concentrating on detail
    Noise would make sense to if it is designed for higher refresh rates and lower quality. Im thinking its for video.
  22. #22
    Feb 2011
    Eads, Tennessee
    1,032
    Guy...... all of us, me especially, appreciate the early feedback from you regarding this hopefully great submission from Sony. Can't wait for further updates but really appreciate it all so far......
    Victor
  23. #23
    23,623
    2555
    Thank you Victor that is very kind of you.
  24. #24
    Senior Member Ario Arioldi's Avatar
    Mar 2009
    Milano, Italy
    784
    Higher refresh rate probably means also faster AF.
