Results 1 to 5 of 5
Thread: A7II / A7RII dimensions: will accessories fit A7RII?
    No CA
    795
    I just asked Really Right Stuff if the A7II L bracket would fit the A7RII, and they replied they don't know yet they don't have a camera body, nor do they know the dimensions.
    If anyone has an A7II and has already received an A7RII, could you please see if the body dimensions are the same, from the standpoint of mounting a bracket?
    (This isn't a question about A7 or A7R dimensions we already know they don't take the same bracket.)
    Thx,
    Kirk
    May 2010
    29
    Re: A7II / A7RII dimensions: will accessories fit A7RII?
    I posted the same question at dpreview and the answers are that the RRS plate and L Bracket for the A7 II also fit the A7r II.
    Mar 2009
    Massachusetts and Vermont
    948
    Quote Originally Posted by Redford01 View Post
    Yes, it does. I have mounted the RRS L Plate for the A7II on an A7RII and it fits perfectly.
    As an aside, I note that the little "door" on the side of the body that covers the mini slot where you attach a remote release is (a) difficult to access with the L Plate attached and (b) VERY flimsy. I expect it to have a short life.
    Member stephen.s1's Avatar
    May 2012
    Southern CT, USA
    79
    I just ordered the vertical grip... It's the same one that fits the earlier model. So, I'd assume the unit you're looking for will fit.
    Stephen
    Aug 2010
    933
    Yeah the a7II vertical grip is also the vertical grip for the a7rII..... I have one on mine as well as the LCD cover for the a7II works on the a7rII (used that as well)
