Results 1 to 5 of 5
Thread: Tethering A7RII issues
    Jun 2011
    Hong Kong
    122
    I was in the believe that Capture One 8.3.2 natively supports Sony A7RII tethering (mac Version) without need for Sony's "Play Memory" software.
    Camera is set to "PC Remote" yet C1 can't connect to the Sony. What am I missing?
    thanks
    Grischa
    Jun 2015
    20
    Re: Tethering A7RII issues
    Strange. I've been using that combination for the last few days with no issues whatsoever.
    Mar 2013
    239
    Quote Originally Posted by Owen View Post
    Is the liveview function finnaly working properly with this a7rii?
    Can you zoom in for focus?
    If you are applying lens correction, can you see the image with correction applyed in the liveview?
    Jun 2015
    20
    Quote Originally Posted by daf View Post
    Yes, finally! Zooming in seemly to require doing so on the camera at which point the C1 live view follows along. Perhaps there's a way to control it through C1 but I've only used this feature briefly. I'm not applying lens correction (Canon TS-E and Pentax 645 lenses) but did check quickly just now and it doesn't seem to be applying them live. It's a serious improvement over the A7R in every way and no longer feels like a toy camera.
    Jun 2011
    Hong Kong
    122
    OK problem solved,
    C1 preferences had Sony cameras ticket off under the Capture tab, once I ticked the box I had to restart C1 and after restart I needed to acknowledge new hardware.
    That solved the problem
    Live view is available and all works like a charm
    www.rupho.com
