Results 1 to 5 of 5
Thread: A7RII towards a secret sauce in LR
    Subscriber Member tashley's Avatar
    Jan 2008
    South of England
    3,294
    I've been fiddling with files a lot in LR (and C1 but that's another story) and found that my usual settings for NR and clarity and sharpening, which with small tweaks I've been using for a while and for a variety of cameras, was giving me results less good than I had hoped.
    So this evening I came up with this. It's really for files in the 400/800 to 1250/4000 range depending on subject matter and exposure but with slight tweaks (less NR for lower ISO files and a touch more for higher) it seems to get me much closer to where I want to be.
    Historically I shy away from any NR unless really needed but this takes the edge off some of the characteristics of the files I'm less happy with, allows me to use some clarity, and yet still lets me get a sharp file that makes the camera look good. It has a lot more processing than I usually favour but it seems to work.
    Caveat is that I am using a 226dpi screen this evening - and to really check this I'd like to see it on a 100dpi screen at 1:1 and 1:2
    Anyone care to try it and see what they think? For me it works particularly well to stop OOF transitional areas looking grainy and lumpy. Any suggestions for improvements greatly appreciated!
    Clarity should be +10 and then as below.
    Thanks 4 Member(s) thanked for this post
    Dec 2013
    London
    590
    Re: A7RII towards a secret sauce in LR
    Initially looks good. What sort of range of Clarity are you adding?
    Also very similar to the preset I use for my RX100 at base iso though with only 15 of NR
    Jul 2015
    22
    For screen use or printing? Should work for printing.
    Jan 2008
    South of England
    3,294
    Sorry!! Clarity is +10, forgot to mention that, will put it in as an edit.
    This is for screen but I know what I want on screen in order to get me to a good print using my setup of print sharpening and this seems pretty close, though it'll be a week or more before I get to make a large print....
    Knorp's Avatar
    3,983
    Tim, can you do me a secret sauce for C1 ?
    Bart ...
