Results 1 to 8 of 8
Thread: GPS for A7r II
    Mar 2013
    70
    Question GPS for A7r II
    I assume that Sony have yet to produce a GPS add-on for the A7 series cameras.
    What is the App du jour for tagging fran iPhone / iPad and tagging in Lightroom, say?
    Jan 2013
    Minnesota, USA
    933
    Re: GPS for A7r II
    I currently use Geotag Photos Pro, which works well. It records tracks of your location, then automatically uploads them to Dropbox for easy access from within Lightroom. Info here - https://itunes.apple.com/us/app/geot...355503746?mt=8
    I've also used and liked GPX Master+. https://itunes.apple.com/us/app/gpx-...414297402?mt=8
    I only switched because Geotag Photos has an app for the Apple Watch, which lets me start and stop tracking from the watch.
    Apr 2014
    Marin County, CA
    593
    Re: GPS for A7r II
    I've used MyTracks since my first A7, and it has worked flawlessly.
    https://itunes.apple.com/us/app/mytr...358697908?mt=8
    Keep in mind that these apps tend to use a lot of the phones battery. MyTracks (and some others) let you adjust the frequency of the gps loggings. Unless you are a moving vehicle, you really don't need it to record a location every second.
    Jan 2013
    Minnesota, USA
    933
    Re: GPS for A7r II
    Quote Originally Posted by dandrewk View Post
    Good point. Both of the apps I mentioned can adjust the track frequency. I keep Geotag Photos set to log every 30 seconds. I've often run it all day and still have plenty of power left at the end.
    Mar 2013
    70
    Re: GPS for A7r II
    Any comments on the accuracy of the trail, particularly where the GPS signal is intermittent.
    Jan 2013
    Minnesota, USA
    933
    Re: GPS for A7r II
    Quote Originally Posted by jrp View Post
    When I'm outside, it's great. Inside big buildings it can get a little weird, but even then it usually works fine.
    Here's an image showing what I mean. The log points within the red oval were when I was walking inside some big buildings. But even with that jumpiness, Lightroom would still tag the locations pretty well.
    (this image is from a Mac app called GPX Editor, which I sometimes use to view and edit the tracks.)
    Apr 2014
    Marin County, CA
    593
    Re: GPS for A7r II
    Yeah, it's totally dependent on the GPS on your phone.
    The good news - most cell phones with GPS are very robust and MUCH better than any in-camera GPS I've used, including the ones that attach to the flash shoe.
    Mar 2013
    70
    Re: GPS for A7r II
    Indeed, but I have read some old reviews that suggested that the trails produced by different apps running in parallel were quite different, particularly when the signal was lost intermittently.
