Results 1 to 7 of 7
Thread: High ISO long exposure infinity focus with Batis 25 on A7RII
    May 2015
    596
    Following a meeting this evening I went to the museum campus in Chicago to shoot some long exposure skyline images.
    I manually focused the Batis so that it showed infinity, F8 and ISO 25600.
    Normal processing in Lightroom without any noise reduction.
    two frame pano with about 50% overlap. Lightroom says its about 10700 pixels wide by normal A7RII height.
    The thin strip of lights to the right are on Navy Pier and the sky does go black there since there are no street lights to reflect off the cloud cover. The Sodium Vapor lights have a distinct orange color reflected off the clouds.
    Dec 2013
    London
    590
    Re: High ISO long exposure infinity focus with Batis 25 on A7RII
    Thanks. I like would be great to see it at a higher resolution
    May 2015
    596
    Here is a version shot at 100 ISO, not quite as wide a view, only 8930 pixels wide, by 4082 high.
    The exposure was about 15 seconds.
    And here are links to both full sized JPGs.
    high ISO: ISO 25600 61 MB file
    low ISO: ISO 100 12.6 MB file
    (Fixed link problem)
    Apr 2008
    Mass
    306
    The links go to the same file. I looked at the 100 iso file 1st and was appalled at the noise (for 100 iso) so I assume they are both the 25.600 iso ...
    Edit : and looking at the waves I'm 100% sure they are
    Knorp's Avatar
    3,983
    Yep, the files are identical.
    Frankly, I'm already appalled by the ISO 25600 file ...
    I'm sure the ISO 100 still is pretty good.
    Kind regards.
    Bart ...
    May 2015
    596
    Thanks for catching the link error. Cut and Paste wins again. :-)
    I fixed it.
    Yes they were both the high ISO initially.
    May 2015
    596
    Aside from the High ISO comparison, here is why I wanted the night images.
    The background is another image I made last night, then took it into Topaz and processed with a crayon drawing preset.
    The Porsche Spyder image was made at the Geneva Concourse Sunday. Both shot with Batis 25/2.
    - - - Updated - - -
    Quote Originally Posted by Knorp View Post
    ...appalled...
    Can you clarify?
