Results 1 to 5 of 5
Thread: L Bracket for Sony A7R and A7RII
    Feb 2009
    793
    Do the Sony A7r and A7RII use the same arca style L bracket or is each body distinctly different requiring different L brackets?
    Jan 2013
    Minnesota, USA
    933
    Re: L Bracket for Sony A7R and A7RII
    They are different.
    Feb 2009
    793
    Thanks I figured as much
    Aug 2015
    munich, bavaria, germany
    20
    don't know if you already have/had an A7*-Camera with an l-bracket or not. Assuming you don't have one, just one remark about L-Brackets on the A7-series: most of them block any kind of cable release when used in portrait mode (which imo defeats the purpose of an L-bracket). Some don't bother as they're triggering the camera via IR-shutter or smartphone.
    If you want to use a cable release in portrait mode you'll either have to buy a riser (about 100 $, losing a little bit of stability) or a more expensive l-bracket (like the RRS, which can be extended)
    Subscriber Member mwalker's Avatar
    Kentucky
    924
    74
    Yes they are different....I have a RRS L Bracket for a A7r if someone wants to make a offer, message me.
    Mike
    website under construction
