Results 1 to 36 of 36
Thread: Sony lenses on Roger's optical bench...compared.
    Nov 2010
    590
    Extremely interesting post here:
    LensRentals.com - Sony E Mount Lens Optical Bench Tests
    What stunned me was the copy variation.......of the Otus!! And other lenses also. FE 90/2.8 is not quite the dragonslayer I thought, and has huge copy variation.
    Also of note is the Sony lenses need optical glass in the path to work right......
    I hope to see something besides WO, or am I missing a link?
    Apr 2014
    Marin County, CA
    593
    Re: Sony lenses on Roger's optical bench...compared.
    Lens manufacturers design and produce lenses for their own camera, or at least for specific cameras.
    IMHO, removing the camera and sensor from lens tests negates any real value from those tests. Is it any wonder that LR's results differ significantly from just about every other test?
    And how are we to interpret having the necessary optical glass for Sony's lenses? I understand the necessity, but how is it then fair to compare results with other systems?
    Jan 2010
    523
    If we ignore the fact that the 90mm Macro tested did not perform as well with Lensrentals as elsewhere, I can only agree on the variance issue. Removing the camera and sensor has no bearing on the fact that with some of Sony's lenses on the optical bench, the various sides and corners are very different.
    Inconsistency in performance (and symmetry) with some FE lenses is frankly staggering. It took me five lenses to get a very good 55mm (second copy great, the first showing the worst decentering I have ever seen in a lens) and one 35mm FE (third copy, the first two having soft sides) that still has one lesser extreme corner but is otherwise excellent. That's disgraceful. I returned as many Sony Zeiss FE lenses in two months as I have Canon, Zeiss, Leica and Pentax lenses in ten years. My Sony FE 28-70mm kit lens is also clearly decentered (horrible lower right quadrant until f11, at which point it is OK), but I simply could not be bothered to continue the mail ping pong. Thankfully my 70-200 f4G was perfect on the first copy, but I bought that from a local dealer at a higher price specifically because I could exchange it same day if I had any problems. Thankfully I did not have to. However, the end result is three good lenses out of seven copies.
    I have read quite a few comments about decentered 90mm Macro G and Zony 35mm f1.4 lenses. Great copies are very impressive, it seems, but my impression is that one encounters users commenting about exchanging copies much more often than with, say the Canon 100mm f2.8 IS L macro, which surely has sold vastly more copies. The only thing making the Zony 35mm f1.4 look less than perfect is the new Canon 35mm f1.4 L II; however, that lens is ridiculously good and even more expensive.
    For some time I have gotten the impression that Canon has been producing the most consistent and some of the best mass produced lenses at the moment and Lensrentals shows that Canon is indeed at the top of the pile, especially with recent models. Now all they need to do is sort their sensors out! While Roger's report shows up the shortcomings of Sony, it does at least show how well Canon is doing, so its not all bad news.
    Oct 2012
    Nyköping Sweden
    1,190
    They know what they are doing? One difference is that Lensrentals only test at full aperture normally. That is logical as much of their testing is intended as quality assurance of the lenses going out to customers.
    But, the downside is that maximum aperture is seldom where lenses perform best.
    The optical industry lives by MTF and it is the generally accepted measure of lens sharpness. For instance, Leica, Zeiss, Hasselblad, Schneider and Rodenstock present MTF data for their lenses in a pretty similar format to LR.
    But the manufcturers use two sets of curves, one for maximum aperture and one stopped down.
    The MTF curves essentially show sharpness, albeit astigmatism, field curvature and lateral chromatic aberration may be deduced from MTF curves.
    Especially for Sony users, MTF testing adds some benefits, as the new FE mount lenses can use all kinds of lenses from Canon, Nikon, Zeiss you name it.
    When testing lenses on camera it is not possible to separate camera from lens. A given lens from Zeiss will perform better on the Nikon D810 than on the Canon 5DIII, as the Nikon has higher resolution. If you test on the 5Ds the Canon version will be superior. And the 5DsR will give superior results to the 5Ds.
    You see this pretty clear in the DxO tests, all of the top rated lenses are tested on Nkon D8x0 and Sony A7r. Once they start testing on Canon 5DsR all winners will be Canons.
    Another factor is that MTF values measured on an optical bench are not affected by sharpening, but some sharpening is generally involved in camera based testing.
    Anyway, lens rentals is not a lens testing outfit. They test lots of lenses as a part of their daily operations and they share some of their findings.
    Best regards
    Erik
    Quote Originally Posted by dandrewk View Post
    Dec 2010
    324
    Quote Originally Posted by uhoh7 View Post
    Except that it is a Dragonslayer in real usage. And the lens testing is done under conditions that are impossible to achieve when actually taking a photo. And the copy variation, which is calculated in a nearly opaque and arbitrary manner, may or may not have anything to do with the final image quality anyway.
    Unfortunately, I have now seen a number of people report reconsidering purchasing some really excellent lenses because of this blog post.
    The increasing trend toward quantifying the performance of every camera and lens into one or a small handful of numbers based on bench testing is not, in my mind, always beneficial.
    Fortunately, the option of looking at the results of the work of many photographers and reading the reviews from a variety of sources is more available than ever.
    I am reminded of two quotes:
    There are three kinds of lies: lies, damned lies and statistics.
    And
    A picture is worth a thousand words.
    In this case, I'll go with the picture.
    Or, rather, I'll go with the thousands of pictures over the statistics. It is the pictures I am going to want to look at anyway.
    -Bill
    Jan 2010
    523
    You seem to be ignoring the (too many) irritated owners who have had to send back one or more Sony/Zesiss FE lenses. It has nothing to do with opaque and arbitrary numbers and everything to do with sloppy assembly and poor quality control compared to other major manufacturers.
    Internet pictures don't tell you much about copy to copy variation. The thousands of pictures you speak of may give you an idea of the general characteristics of the lens and whether you like the look, but it will tell you nothing about the probability of your newly ordered $1500 35mm Distagon arriving with a soft left side.
    Quote Originally Posted by ohnri View Post
    ... And the copy variation, which is calculated in a nearly opaque and arbitrary manner, may or may not have anything to do with the final image quality anyway.
    -Bill
    Apr 2014
    Marin County, CA
    593
    Quote Originally Posted by turtle View Post
    Define "too many"? What number is that? How does one determine a statistic or percentage based on what someone might or might not post on an internet forum? If they should post, how certain are we that their evaluation or methodology is valid? e.g. One person may see a "defect", and another one does not.
    The point is forum posts are purely anecdotal, and often biased. We also have to consider that problems are much more likely to be publicized than no-problems.
    From looking at posts in Sony forums, here and elsewhere, there is a good deal of overlap on folks reporting issues. Some are quite vocal and post several times, often with increased rhetoric.
    I see, hear and read issues with QC with other makes. Just briefly peruse Nikon, Canon forums and you will always see issues, and believe me those that have those issues are quite upset about it.
    To be clear, I am not saying there aren't QC issues with Sony. But nobody will know if they are better/worse than any other manufacturer. It's all conjecture.
    And I repeat my earlier post, I don't put much stock in tests that don't include the mated camera. If I care to consider MTF charts, -at all-, I'll consider methods that have been tried/tested/proven for decades.
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    -Bill
    I am not one of them. I am not persuaded or dissuaded by that testing and/or any mis representations of the results there.
    The 24-70 Zony zoom I bought and returned (2 samples) had nothing to do with lens rentals. However, the 3rd sample that I never bought and will not buy has everything to do with what they showed- ie. how it is put together.
    Not worth my cash.
    How about Sony increasing the quality of their products and stop peddling the Zeiss logo for no good reason other than profits?
    Nov 2012
    Miami - New York
    122
    I'm not sure you can really expect mass produced AF optics to ever had the quality control that will provide 100% defect free lenses every time at the prices people are willing to pay. In thirty years plus of professional shooting and owning almost every brand of camera from 35 - 8x10, I can only remember one or two instances where I felt the lens I purchased was not up to expectations. I returned them and remedied the situation.
    It's amazing to me that any large aperture AF lenses can maintain perfect optical alignment through production and wear and tear for very long.
    If you really want to make sure you invest your money in only superb lenses, buy Leica C or Zeiss Ultra Prime cine lenses. Plan on spending about $20k per lens, and you are are assured of perfect quality every time :-). I use them on a RED occasionally that they will satisfy the most critical optical snobs, although many only cover APS-C (S-35 format).
    In comparison, I think Zeiss is doing a very good job with their new lenses and is probably striking a perfect balance between quality and price. And until Sony zooms prove themselves to be up to at least the standards of the latest Canon L lenses, I'll probably hold off on those, although that 16-35 is very tempting :-)
    I was a bit disappointed that Sony didn't release or announce more new lenses at Photo Expo last week, of did I miss something?
    Jan 2010
    523
    We are rarely in command of fully researched and robust data that is beyond reproach, but isn't that typical? We all have to make our own 'assessment' and yours is that there is insufficient data to reach a conclusion that Sony/Zony lenses have QC issues that neccessrily have any effect on imaging performance. Mine is that there is ample data for me to make a confident personal assessment that Sony Zeiss has issues. That a personal call, but it comes from:
    1. Direct personal experience (yes I could be a statistical anomoly, but see next point)
    2. Having read lots of reports of people ending multiple copies back one after the other (which I have very rarely heard about with larger manufacturers which have a LOT more lenses out there)
    3. The Lensrentals optical bench.
    Sure, the optical bench does not tell us for sure what the impact would be 'on sensor', but it does tell us which manufacturers have the greater variances in resolution across the lens. Considering the demands of pixel rich sensors, its not hard to see how substantial variances would at least translate into some kind of variance on sensor. Yes, this could be a gross error, but interestingly, this marries up with what a substantial number of users are saying. To assume that the sensor would somehow mask measured decentering (on the optical bench) is much more of a stretch than the chain of reason outlined above.
    I feel this is a classic case of it looks like a duck, walks like and duck and quacks like a duck, it is probably a duck. So far, all the information in this chain is congruous.... No, this does not mean it is impossible that a false conclusion has been drawn and we are in fact looking at a Kangaroo, however, based on available information would appear more likely to be a duck.
    Dec 2010
    324
    When people actually show an image that leads them to return a lens - that is exactly the data I would look at.
    I agree that it has nothing to do with arbitrary numbers.
    Can you really make a fair comparison to other manufacturers from this data?
    Hardly. Read a little of Thom Hogan's discussion of Nikon's QC issues for some perspective. Getting my D800 and 85/1.4 D to be sharp was always an adventure.
    Or look at Leica. I have used Rangefinder Leica's for nearly 50 years. Talk about focus issues! A minor bump can so easily lead to miscalibration and to misfocus. Or, with digital M's, worrying about whether my camera was set for the optimal distance of focus for each lens - rah, rah focus shift. Basically, you almost had to mate a specific lens to a body for critical close to medium focus at wide aperatures.
    Or, try to critically Manually Focus any DSLR at f/1.4 through the viewfinder. Hah! It is almost not possible due to the optical design of modern viewfinders.
    I have a higher percentage of critically in focus, wide aperature shots from my 35/1.4 and 90/2.8 using the Sony A7r2 and Eye Detect than I ever got from other systems. So, now which lens is better? The ones I get critical focus from or the ones I don't ? The whole imaging chain is important.
    And looking at many internet pictures from many lenses would seem to me to be a perfectly reasonable way to make a rough guess at whether the lens I am going to order will fulfill my expectations.
    If Lens Rentals took their many copies of lenses and shot many types of images while looking for many different image qualities it would mean so much more. But, that would also be so much more difficult and expensive and time consuming.
    That is probably why no one does it.
    -Bill
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    -Bill
    Any idea what a Zheiss QC certificate entails?
    Jan 2010
    523
    People do show images that cause them to send lenses back...
    I think you are conflating issues:
    1. D800 + lens issues were in many cases due physical focus problems, lens compatibility and possibly pixel pitch.... not optics.
    2. The Leica M issues you speak of are due to RF calibration.... not optics.
    3. Manual focus of DSLR lenses vs. live view EVFs is about systems.... nothing to do with the optics themselves.
    Whether or not a lens meets your expectations has nothing to do with whether or not there are optical quality control issues at Sony/Zony. Surely it just means they are below your tolerance threshold, or do not matter in the context of the other benefits the system brings you?
    Regarding your last point, I think you are missing the point. You say "If Lens Rentals took their many copies of lenses and shot many types of images while looking for many different image qualities it would mean so much more. But, that would also be so much more difficult and expensive and time consuming". This statement is unconnected to what I have been saying or what Lensrentals has been saying (optical consistency within lenses and across samples i.e. decentering). You appear to be talking about something quite different i.e. 'why don't they look at factors other than optical bench measurements and cross frame and batch consistency, to produce a more rounded profile/evaluation of the lens.' The answer is 'because they aren't, don't pretend to be and this discussion is about what they are showing and not what they aren't.' If you don't think the evidence supports there being optical QC issues with Sony/Zony, that's fair enough. If you don' think they matter (to you), that's also fair enough. If you prefer to give consideration to optical qualities other than even performance across the frame, that is of course also understandable. However, confusing the various issues is, well, confusing.
    -Bill
    Blog: http://www.thephotofundamentalist.com
    https://www.facebook.com/thephotofundamentalist
    Los Altos, CA
    10,486
    1031
    I have said it before, but it bears repeating: E V E R Y lens is subject to sample variation, and the only way you will know if yours is good (enough for you) is to test it (on your typical subjects at your typical apertures).
    rant This is where I have issues with the dedicated brand adherents -- fanboyz if you prefer -- when it comes to anybody's camera or lens line. Loyalism is one thing, but uninfomred loyalism as respects quality and performance is simply sophomoric. /rant
    home: www.getdpi.com
    Dec 2010
    324
    Actually, that is part of my my point. I care about my final image. What is being tested appears to have zero application to my final image. I am not going to claim Sony has a giant QC issue when I get better images with it than I do with other systems. So, yes, if a lens and camera imaging chain meets people's expectations it has everything to do with whether QC is sufficient or not.
    If others, such as yourself, have found inconsistency such that your final images are not up to your desires then I understand your frustration. If you can produce the images you want consistently with other cameras and lenses from other companies then that becomes more interesting in terms of whether Sony has an issue or not.
    I will certainly not claim Sony is worse than other companies based on this data. There is no basis for stating Sony lens/camera IQ is worse than that of Nikon or Canon based on anything Lens Rentals is doing.
    Many people think that the D610 and D810 exist solely to fix QC issues with the D600 and D800.
    Even if Canon is a paragon of consistency they don't make a camera I want or even a camera sensor I want. So I can consistently get images I don't want. Or use adapters, which apparently have their own problems. So maybe Canon is guilty of sloppy design. Putting mediocre sensors in big bodies that don't even do 4K video.
    I will, finally, repeat what I have said before. Tests done on a lens, alone, in one setting and wrapping the results in opaque and arbitrary math is not going to be high on my list of criteria for choosing a camera/lens combination to shoot with.
    And, finally, finally, I am finished with this back and forth. I believe you are fully entitled to you opinion and that it is valid for you. I believe that Sony might really have issues with lens consistency that probably fall below the threshold of the vast majority of users notice. I believe that if only a tiny percentage of users have a problem with consistency then it is not really a problem. I believe it is impossible to divine anything meaningful about Sony vis a vis other companies regarding image quality from any readily available lens testing. I believe in images more than Frankenstein test rigs.
    I believe you are sincere in feeling Sony has a problem. That is fair.
    I believe Roger is sincere in his tests and feeling they are helpful. Maybe they are.
    I believe people are using Sony cameras and praising their lenses because they are getting amazing results.
    I believe Sony can probably do even better and feedback is an important part of that.
    I believe I have had great results with every camera system I have ever used as well as real frustrations with each one. That includes my current Sony system.
    I believe I have no more time to spend on this issue at the moment but may return to it down the road.
    Take care,
    Bill
    Mar 2014
    Espoo, Finland
    125
    Lensrentals also tests these things with camera/sensor inequation, with Imatest. Here's what Roger had to say about FE lenses on Imatest
    http://www.dpreview.com/forums/post/56675717
    Also, it seems that manufacturers including Sony respect Roger's work and he works with them quite closely and some parties even contract Lensrentals lab for testing purposes only.
    http://www.dpreview.com/forums/post/56675944
    As for lens variation issue overall I have one question: how many people over here have exchanged a "pure" Zeiss lens for decentering etc. issues. Forums are full of reports of how many tries it took to get a good copy of a Sony Zeiss lens yet I'm yet to see a report about decentered Loxia or Batis despite those lenses selling well enough for them to be constantly backordered. Coincidentally the pure Zeiss lenses (ZE/ZF, no numbers available for Loxia/Batis yet) tend to score very highly on Lensrentals variation tests and the pure Zeiss lenses are very adjustable/correctable if they get out parameters
    Lensrentals WA copy variation tests for DSLR lenses
    http://www.lensrentals.com/blog/2015...e-angle-lenses
    And please do not take me as hater, I have never owned a non-Sony system camera and currently own a pile of Sony Zeiss lenses. I love my FE 90/2.8 for macro, it is stellar in short range both optically and in useability, but I have not trouble admitting that my Batis 85 looks sharper than 90 at infinity, just like dxomark (short distance test) and lensrentals test bench (infinity) suggest.
    23,623
    2555
    Not questioning Roger here and we all know sample variances exist. Trust me I had my share in every brand and several lenses in Sony for sure. Granted I don't know enough to understand they way he is testing these Sony lenses but taking the lens off the body makes me nervous. Even though it could be correct still makes me nervous . Also to Rogers credit he did put in his warning on it. Now I know for a fact I had a bad 35 2.8 and 2 bad 24-70 and I know I have a very slight corner issue with my 35 1.4 but I actually consider mine. Very good copy. 1.4 is a tough beast to test wide open and corners are never perfect in any brand. I had my issues with Nikon, canon and others as well. This test just makes me a little nervous. Not saying it's wrong, right or anything else. Again I'm back to the puzzle and this is just another piece to consider
    www.guymancusophotography.com
    Nov 2010
    590
    Yes every lens has copy variations. How much they vary, that is the question. Roger, who I cannot thank enough for all the time he puts into this, now has the numbers to show which are the worst offenders:
    "The FE 35mm f/1.4 ZA lenses are all over the place. It actually is a bit worse than the graphs look because a lot of the variance is WITHIN a copy, not just copy-to-copy. None of the 10 copies we tested had even corners. And I'll editorialize and say that none of the dozens we've tested on Imatest had even corners either. If you use this lens for centered objects, you'll be happy. If you want 4 sharp corners, it's not likely to happen unless your standards for equal sharpness are pretty low."
    Roger.
    So testing "in your usual shooting method" is not going to cut it really for some of us, who like Steve Huff, are all about the central subject, and don't really look hard at the edges much. But given the choice I imagine Steve would like the best copy too.
    I suggest anyone who cares about Sony read that blog several times word for word. It's a bombshell if you really care about quality.
    Not just Sony, but you see Zeiss, Sigma, Canon, Nikon variations from a large sample of copies. Hopefully we will see some figures for M as well.
    Also the F/4 and 5.6 and f/8 numbers will come eventually.
  19. #19
    Feb 2011
    Eads, Tennessee
    1,031
    Quote Originally Posted by tn1krr View Post
    I have....... it took 3 Zeiss Otus 55mm lenses before I got one that really lived up to the hype..... all went back to Zeiss and I have the paperwork to back this up. I will say that they are really above board to work with - actually sending me a new copy before they got the old one back from me.
    Victor
  20. #20
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    So the QC certificate with some guy's signature does not mean much?
  21. #21
    Feb 2011
    Eads, Tennessee
    1,031
    The lens is the only thing that means anything to me..... maybe that certificate has some significance for you...... just a piece of paper to me.
    Victor
  22. #22
    Feb 2011
    Eads, Tennessee
    1,031
    It sure is a bombshell...... I have complained about lens quality for years only to fall on ears that thought I was just being too critical....skewed images, soft corners, sides out, a mid section soft, and from lenses that weren't $399.99 but more like $3999.99 and way beyond. The whole thing just pisses me off.... I'm convinced that many of the lens purchasers are either blind, don't know or don't care.
    Victor
  23. #23
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Quote Originally Posted by vjbelle View Post
    Victor
    I thought I could cash that in when the lens is not what it was claimed to be?
  24. #24
    Apr 2014
    Marin County, CA
    593
    Roger.
    That's it exactly. We read these blogs and scratch our heads and get worried. The issue of QC is and always has been an issue with lens manufacturers.
    So we find out that Sony has QC problems. Is this surprising? No. Is it important? That's for the buyer to decide. Obviously, for the amount of money we spend, we want perfection. What defines "perfection" is an individual choice.
    If the question is: Is Sony worse than others? As I posted, we don't know, and everything else is 100% conjecture. This isn't an automobile where user experiences are actively tabulated and published. If anyone is concerned that Sony is worse than others, I invite you to scan threads from Canon, Nikon etc. forums. From doing so myself, Turtle's "it looks like a duck" classic case is pretty universal.
    It's really simple. Research lens. Buy lens. If you like the images in produces, you are golden. Everything else doesn't matter.
  25. #25
    Feb 2011
    Eads, Tennessee
    1,031
    Well..... not and keep the lens but for sure you can get your money back from either B&H or Amazon in the first 30 days.... just a real bummer considering how much money all of this stuff is. I have numerous posts regarding dismal lens quality and its like they hold us hostage.... where do we go? Its all hype and no show!!
    Victor
  26. #26
    Feb 2011
    Eads, Tennessee
    1,031
    You are right...... there are no tabulated cases and never will be.... nobody gets killed from a lens unless its dropped from 50 feet onto their head. But this gets down to the crux of how lens manufacturer's think and its all about spewing this junk out until someone/everyone starts to rebel. If this was just an anomaly from cheap lenses it would be one thing but it isn't. They want the big bucks but deliver junk.....
    Victor
  27. #27
    Oct 2012
    Nyköping Sweden
    1,190
    Re: Sony lenses on Roger's optical bench... some comments
    Lens rentals findings stirred up emotions a bit.
    I feel it may be a good time to spread some oil on the waves or feed some oil in the flames…
    Let's look at the 90/2.8 G which I do own. Lens rentals have tested it using Imatest and reported very good MTF 50 values. Also, DxO-mark has tested and it is the highest ranked lens regarding sharpness in their tests.
    The 90/2.8G was a cornerstone in my buying into the Sony A7rII. What I wanted was essentially:
    • A very sharp macro lens
    • A short telephoto with reasonably large aperture performing very well at full aperture
    • A short telephoto lens having very little axial chromatic aberration at full aperture
    • A maximum aperture of f/2 seemed ideal to me
    • I really wanted around 70-90 mm, 135 mm is too long for me
    Candidates were:
    • The Zeiss Otus 85/1.4 is great for sure but a bit to expensive, and I don't need f/1.4
    • The Zeiss Macro Planar 100/2 would be great, but it has extensive axial chroma at large apertures
    • The Zeiss Apo Sonnar 135/2 would be perfect, except I don't really like 135 mm
    • An 85/2.0 APO would be ideal…
    • Zeiss presented that Batis 85/1.8 a great lens for me? I put an order on it.
    • Sony released the 90/2.8G macro and Lens Rentals published some very good data on it and so did DxO-mark
    Now, the Batis seemed to be on a very long delivery schedule and Sony macro started looking more and more attractive. DxO data looked really good on the Sony. DxO doesn't report axial chroma, but lateral chroma was really good, indicating liberal amount of SD/AD glass. On the other hand, Guy Mancuso published a set of quite impressive images from the Batis.
    Anyway, I finally decided to go with the Sony 90/2.8G. Ideally, I would have ordered five copies of all my candidates, did some extensive testing and picked the best one. But:
    • I cannot afford to buy 20-30 lenses.
    • I don't have the time to tests 20-30 lenses
    • I don't have the competence to test 20-30 lenses
    So, I ended up buying the Sony 90/2.8G Macro. Honestly, I feel it performs very well. Would a Canon 100/2.8 LII macro be better? According to LensRentals data it would be definitively better at full aperture. Stopped down a stop? Who knows. Many lenses improve a lot on stopping down very little. To me it seems that the 90/2.8 may be quite OK.
    But, it may also be that a Canon 100/2.8 LII macro may be even better. I know that the Zeiss 100/2 macro offers very good MTF 50 at full apertures, but I also know it suffers from a lot of axial chroma at reasonable apertures.
    So, what I see is that the lens I bought works. Some other lenses may work even better.
    Let's roll back to the A7r. Diglloyd has found that lack of EFCS (Electronic First Shutter Curtain) made it perform below pair at say 1/15 - 1/125s. But it still performed as a good 24MP camera. The loss of resolution caused by not using EFCS was not really observable, but clearly seen on MTF data. Now Sony has fixed the shutter vibration caused issues. Everyone is happy.
    What I get from this? The Sony 90/2.8G macro works for me. Would it be smarter to buy the Canon 100/2.8LII macro? Maybe! Would I bee happier with Zeiss 100/2 macro? Probably not with the amount of axial chroma it has. Would the Batis 85/1.8 better? May be, may be not!
    Would the Otus 85/1.4 be the ultimate solution? Possibly but weight and costs also matter…
    Best regards
    Erik
  28. #28
    Senior Member pegelli's Avatar
    Dec 2010
    Belgium
    2,115
    Erik, very wise words! Especially like your what you wrote about axial CA in the Zeiss, there's more to a good lens then sharpness alone. In the end the whole purchase decision is probably is a subjective choice and cannot be made on scientific measures alone.
    For me Roger's tests is just one more datapoint to consider. It's not the final answer but still one of the many inputs before buying a lens.
    How much weight you put on this one vs. the many others you can find on the net is up to the purchaser.
  29. #29
    Vivek's Avatar
    Apr 2008
    Netherlands
    13,594
    21
    Quote Originally Posted by ErikKaffehr View Post
    That sounds like a bunch of Zheiss certificates.
    A 36mp camera performed as a good 24mp camera? For whom?
    Plastic mount got changed by Sony in the A7r? Loss due to vibration was not observable? Sony fixed the shutter vibration?
    Everyone is happy?
    [Not if you have paid 2400 Euros.]
    I am not buying any new Sony camera. Everything becomes available for ~50% in a few short months. Thanks to the A7r.
  30. #30
    Feb 2011
    Eads, Tennessee
    1,031
    Best regards
    Erik
    Before forking out the big bucks for that lens make sure you purchase it from someone who will take it back - no questions asked!! I owned one for one hour - just long enough to test it. I couldn't believe what I was seeing. A complete quadrant was out of alignment - really out of alignment! It wouldn't sharpen out until f6.3. I was/still am flabbergasted and extremely disappointed in Zeiss QC. I sent it back. I hate buying lenses!!
    Victor
  31. #31
    Member Zlatko Batistich's Avatar
    May 2009
    Cresskill, New Jersey, USA
    102
    ... as you noted above, all of the top rated lenses are tested on Nkon D8x0 and Sony A7r 36mp sensors, while they've tested Canon lenses on nothing more than 22mp sensors. If and when (?) they ever test a lens on a 50mp Canon sensor, the list of highest ranked may well get re-shuffled quite a bit, and a number of Sony lenses may drop out of the oft-mentioned top ten ranking. In the meantime, DxO is likely giving Sony/Zeiss/Nikon/Sigma lenses a nice (if not entirely earned) sales boost with so many people, even some respected photography blogs, quoting their "highest ranked" as if it were something reliable.
  32. #32
    23,623
    2555
    I sold my Sony 35 1.4 yesterday. I tested it again and that left side of mine just bugged me . Mine is actually pretty good to but I sent the buyer my tests so he knows exactly what he is getting. I'm waiting for a Batis 35 F2 but in the meantime I need something so I bout a new Tamron 35 1.8 canon mount a metabones and I snuck in a Canon 135 f2 used in there.
    Both focal lengths I'm waiting to see what Sony does but I need to work too so I need something to get me through the night.
    I'll post my test on this Tammy it's rated very good. Who knows I may wind up buying the 35 Sony again but I'm going to test the heck out of it.
    Honestly for 1700 it was bugging me even though shooting might mean nothing.
  33. #33
    23,623
    2555
    Btw buying the old screw drive Sony 135 1.8 with the adapter was not in the cards with that center cluster . I'm sick of that setup
  34. #34
    Jan 2012
    New Jersey, USA
    353
    If it makes you feel better my brand new Leica 35 Summilux FLE and 21 Super Elmar had issues out of the box: backfocus with the FLE and blurred lower left with the SE. SE was so bad that Leica NJ had to send it to Germany for adjustment. After this, I am calling BS on any claim by any manufacturer about their QC, esp Leica who claims each of the M lens is tested by hand and gives a signed test certificate. BS.
    With this experience, I feel Sony is not so bad.
    I do agree with testing the heck out of any lens you buy - one just can't assume that there is any meaningful QC. And if you do find a good lens, do not sell it.
  35. #35
    Oct 2012
    Nyköping Sweden
    1,190
    My understanding is that DxO measures lenses so they can do lens corrections in their DxO product. So they need to test a lot of lenses on a lot of bodies, for that reason I expect to see a lot lens tests on the 50 MP Canons coming out soon.
    When I looked at the Sony 90/2.8G I found it was rated best in sharpness. But the Otus was tested on the D800 a later test of the Otus on a D810 was besting the 90/2.8G.
    As long as lenses are good, it seems that sensor resolution dominates lens sharpness. Roger Ciala (Lensrentals) has investigated this in some detail, measuring MTF data for the Canon 24-70/LII and the Nikon 24-70/2.8 zoom on both the optical bench and using Imatest. The Canon was much sharper on the optical bench but the Nikon outperformed it easily on Imatest.
    With MTF tests on optical bench the sensor is removed from the equation, so the MTF data just tell about lens performance.
    To complicate things the "cover glass" also affects MTF, as it seems very little with lenses for the DSLRs but more with Sony lenses. Sony probably tries to make the lenses smaller by reducing distance between sensor and outlet pupil which increases beam angles.
    I would expect Canon glass to perform well on Sony.
    This is a bit interesting for me as I realised I need an ultrawide zoom for the Sony. Choice is the Sony 16-35/4, the Canon 16-35/4 and of course the Canon 11-24. I guess it may be I go with 16-35/4.
    As a side note, I have been shooting my Sigma 12-24/4.5-5.6 quite a lot on a trip to Alsace and was very happy with the results but not at all happy with the same lens in the Dolomites. That came as a surprise to me.
    But, in the Alsace I mostly shot church interiors and the Sigma worked great, but that kind of images often don't have very much details in the corners, also I often used it for stitched images where corners are seldom used, so a lens can work great in one situation and not so well in another situation.
    On this image the upper left corner "fell apart":
    Best regards
    Erik
    Quote Originally Posted by Zlatko Batistich View Post
  36. #36
    May 2015
    596
    I sold my Sony 35 1.4 yesterday. I tested it again and that left side of mine just bugged me . ....
    It caught my attention that the 35 tends to have a bad side or corner.
    I was thinking about getting one, since I like that FoV for a "normal" lens.
    Now I'll wait for something more impressive.
    I still have my Canon 35 1.4L with the Metabones IV if I feel the need.
