Results 1 to 5 of 5
Thread: Can Leica R Lenses work on Sony A series Cameras
    Nov 2010
    622
    5
    Just curious to see if the Leica lenses will work on the Sony A 7 camera bodies. I believe the R lens are AF thanks
    Member Farnz's Avatar
    London, England
    169
    Re: Can Leica R Lenses work on Sony A series Cameras
    The R lenses are manual focus only but can be used on the Sony A7 series of cameras with an adaptor I believe.
    Pete.
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,297
    I use Leica M and R lenses all the time on my two A7r/2 cameras.
    All you need is an R to E adapter.
    An R to M followed by an M to E adapter also works just fine.
    There are a number of companies making those adapters.
    I found the expensive Novoflex adapters to be precisely made.
    But other cheap adapters work as well.
    Some, but not all, wide angle M lenses exhibit corner smearing.
    That can be addressed by Kolari by replacing the sensor cover glass with a thinner one. But then native lenses might suffer a bit.
    How much? Mostly to be determined.
    With best regards, K-H.
    Apr 2009
    Sydney, Australia
    581
    2
    I have a number of R lenses which have Leitax mounts. To use them on the A mount is a simple matter of swapping the Leitax mounting plate.
    Jeff
    www.jeff-grant.com
    No CA
    795
    Because R's are retrofocus lenses that don't place the rear element too close to the sensor, they'll work perfectly and won't smear the corners (as happens with short M lenses). Many of the primes are Mandler designs, though some of the inexpensive ones, and esp. the kit zooms, were 'borrowed' from Minolta.
    If you have R lenses you're well set up for manual focus with A series.
    Kirk
