Results 1 to 6 of 6
Thread: Firmware 2.0 for A7ii out on Sony UK site
    Jan 2013
    Minnesota, USA
    933
    Mac version - Sony Support
    Windows version - Sony Support
    Benefits and improvements:
    • Adds the selectable feature for uncompressed 14-Bit RAW image capture(*)
    • Adds support for AF Phase-detection for LA-EA3/LA-EA1
    • Adds custom buttons for MOVIE recording
    Feb 2015
    311
    Re: Firmware 2.0 for A7ii out on Sony UK site
    Glad they are supporting the all-rounder so to speak. I like mine a whole lot. Would love to see them add some support for more than 2 aspect ratios though, which seems to me to be the easiest thing in the world...but what do I know. Hopefully this will allow decent AF with the Contax G adapter.
    May 2015
    596
    Just loaded the firmware upgrade to A7II.
    Then did a quick test with some Canon Lenses via Metabone IV with V45 per the Sony menu.
    The focus was acceptably fast with all the tested lenses. I have more testing to do but am happy so far.
    It seems to be on a par with the A7RII. The uncompressed raw is also welcome.
    There is also a V.46 version update for the Metabones IV dated Nov 10, 2015. It seems to help a bit with PD auto focusing.
    Nov 2010
    NYC
    1,575
    4
    I found that upgrading to v.46 ruined Canon PDAF with the A7II and v2.0 firmware. Be careful! It was good at v.43 w/2.0.
    Senior Member ggibson's Avatar
    Oct 2009
    SF Bay Area
    743
    So still no silent shutter on the A7II, correct? That would have been a nice addition.
    May 2015
    596
    Quote Originally Posted by MGrayson View Post
    That's interesting. I've found it to work well.
    It does seem, sometimes, like the Metabones and lens have to get synced.
    I also tried holding down the button when attaching the lens. That seems to make things work a bit better.
    I've been testing a 300mm F4 L which is an older lens and it seems to be working fine outside even with small focus point selected. I also have been doing some testing with 200mm F2.8 L II. It also seems to work fine. I just tried it with AF-C and slow continuous shutter. Won't find focus with small focus point. Worked with Mid focus point.
    I noticed that the Meta Data lists the lens as a 200mm G SSM II when the 200 is mounted on the Metabones IV.
    Update: I looked at the 200mm AF-C images. The first was in focus, the second and subsequent were not. It's not something I'd use often. I know the 160-600 Tamron does an acceptable job with the AE3 adapter on the A7R2.
    That will be next test with A7II and updated firmware.
