Results 1 to 8 of 8
Thread: banding while silent shooting is enabled
    Mar 2012
    Hamburg/Beijing
    247
    7
    Hi everyone,
    is anybody else experiencing this effect?
    first shot, silent mode,
    second one, mechanical shutter
    camera is on firmware 3.0
    best regards
    mirko
    Attached Images Attached Images
    Senior Member pegelli's Avatar
    Dec 2010
    Belgium
    2,118
    Re: banding while silent shooting is enabled
    This is a well known and documented effect, caused by the cycling of the electric lights.
    Google "silent shutter banding" and you'll find many references and technical explanations.
    My Pics
    Apr 2013
    398
    Stick to shutter speeds slower than 1/125 sec during silent mode shooting (electronic shutter) and the images should be free from banding. Unless you are shooting with sunlight and or flicker free continuous light (cinema) sources you will get banding due to the frequency of the light (cycling). Most light fixtures have an on/off cycle. You see them as continuous but they have a frequency and the electronic shutter, since its not really a global shutter, registers that cycle during the exposure if its equal to or faster than 2x the Hz of the local electricity, in the US it is 60 Hz so you get the banding at 1/125 but not at 1/60. At 1/125 sec the banding might not be visible though. At 1/160 it most definitely is.
    Dec 2013
    London
    590
    I would go to less than 1/90th sec to by more certain.
    Oct 2012
    Nyköping Sweden
    1,191
    Electronic shutter has slow travel, so I would avoid to use it if it can be avoided. EFCS is essentially vibration free, so I would use that if silent mode would not be absolutely needed.
    Silent shutter also forces 12 bit mode, so you loose some DR.
    Check this: How fast is the Sony a7RII silent shutter? | The Last Word
    Best regards
    Erik
    Quote Originally Posted by Ken_R View Post
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,298
    All correct, nevertheless the silent nature of the electronic shutter in certain situations may override with its advantages all its drawbacks!
    With best regards, K-H.
    Mar 2012
    Hamburg/Beijing
    247
    7
    thx to everyone for the info
    best regards
    mirko
    Apr 2008
    Mass
    306
    Also listed as a limitation in the A7R2 Help Manual
    "If you shoot images under instantaneous lightning or flickering lights, such as the flash light from other cameras or fluorescent lighting, a striping effect may occur on the image. "
    Mike Broomfield
    www.pbase.com/mike_broomfield
