Results 1 to 5 of 5
Thread: Fe 55mm 1.8 no longer auto focuses
    Senior Member Rawfa's Avatar
    Nov 2008
    Rio de Janeiro
    2,393
    TheFe 55mm 1.8 no longer auto focuses (tested on 2 different a7s. Has this ever happened to anyone? Any idea on how to fix it and how much would it cost?
    Vivek
    Re: Fe 55mm 1.8 no longer auto focuses
    Quote Originally Posted by Rawfa View Post
    Try cleaning the electrical contacts (lens and camera). The CORRECT instructions are on Canon website somewhere.
    Nov 2008
    Rio de Janeiro
    2,393
    On CANON/s website?
    Vivek
    Jul 2009
    Swiss Alps
    1,444
    3
    Well I have got that kind of problems several times.. But it was my settings : I have set AF to the back button, the one that also has the AF/AEL switch. Sometimes the switch get displaced and memorize AEL instead of AF.. Usually it takes me a moment to realize it.
    But if that occurs with two bodies, then that can't be the problem. However sometimes I get a lens that isn't responding : it's because it wasn't mounted properly. May be there is something on the lens mount preventing it from correct mounting . And as already said : clean the contracts first.
