Results 1 to 17 of 17
Thread: Quick access to RX1RII focus points?
    Feb 2015
    357
    I have the left button on the wheel as my focus point access but thus far you still have to hit it once, then hit ok to get to move the focus point around. Is there a function where I can just hit something ONCE to get right into moving the point?
    Nov 2015
    9
    Re: Quick access to RX1RII focus points?
    Quote Originally Posted by Speedgraphic View Post
    This is for the A7 series but should work for you. Set the center button to Camera Standard. You can be on any focus mode. You then can move to any af point.
    Jul 2009
    324
    60
    I set the camera in Flexible Spot or Expand Flexible Spot. Pressing the centre button (silver) once allows me to change the focusing point using the command wheel.
    Feb 2015
    357
    Ah, perfect! That works much better. Man this camera really screams out for a touch screen though. What a strange omission.
    Jul 2009
    324
    60
    I actually prefer it as is - with touch screens on small cameras and my big greasy fingers, I always end up touching something I didn't mean to touch Similar with the "macro mode" - half the times I change aperture without looking, I end up shifting the focusing range. Sometimes less is more.
    Apr 2014
    Marin County, CA
    593
    It's not an omission, it's a choice. Add touch to that LCD screen and you almost certainly would lose the ability to flip out the screen.
    Vivek
    Quote Originally Posted by dandrewk View Post
    It is an omission. One less thing to warrant a recall.
    The NEX-5N featured a flip screen + touch functions.
    Apr 2014
    Marin County, CA
    593
    It's not an omission, unless you want to compare the resolution of the the LCD screen/sensor between the Nex 5 and RX1rII and A7rII.
    Not everyone is into "Sony is evil". Eliminating a useful feature under the supposition it may require a future recall?
    Vivek
    How can you be so sure? Do you have any inside knowledge?
    btw, the NEX-5 did not have a touch screen. It is the 16mp NEX-5N that had it. i know because I have owned both and still have a few NEX-5N.
    Santa Monica, CA
    2,373
    2
    Inside knowledge? Do you have any either?
    Isn't this getting a bit old?
    Vivek
    Quote Originally Posted by stephengilbert View Post
    Inside knowledge? Do you have any eitther?
    none. I just posted an opinion to a post earning for the touch screen. If it gets characterized as something else, it is not in my control.
    Understand that i do own/ use/ the sony cameras under discussion.
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    4,340
    I used my NEX-5N just yesterday, very enjoyable.
    It's a small but fine camera.
    Even the Summicron 28/2 works pretty well on it.
    With best regards, K-H.
    Feb 2015
    357
    The Q has a touch screen and those puritans aren't complaining. Think of it this way. With a touchscreen you can always turn it off if you don't want to use it, and everybody's happy. I'm not saying Sony is evil I love this camera. I'm just saying it was the wrong move IMO to omit the feature. Even with the quicker access to the focus point it's a PITA to change points. Fuji just learned this and has implemented their joystick. With a camera this high in resolution that will so often be shot wide open, "focus and recompose" won't always be sufficient to maintain focus where you want it.
    Vivek
    Are you using AF in the contnuous mode? It appears to be blazingly fast (put it on wide area) and will lock on the nearest subject in the frame.
    I do agree tbat a touch screen feature can be turned off when not needed.
    One other neat advantage of touch screen that Panasonic showed me is the touch focus/capture in combination with spot metering. Total bliss!
    Nov 2012
    114
    Hmm, focus lock and recompose was when there was no other way. I recommend listening to Gary Fong's reasoning behind the systems offered today:
    https://www.garyfong.com/learn/confi...bject-tracking
    Feb 2015
    357
    I've been using it in AF-C with the Wide-Small area (forget the actual name). I know I need to play around more. In everything but really low light i'm happy with it. You definitely need to find that small contrasty spot for it it find focus, but it does pretty quickly. In bar type lighting I find the AF really struggles which is disappointing. My only concern about AF-C is that it might drain my battery even faster. I'll have to experiment more. The good thing is that this lens and this camera just beg to be used. It's so good!
    Apr 2014
    Marin County, CA
    593
    Yes, do continue to experiment. There are numerous images online of folks taking low light images in bars and night clubs. For myself, shooting indoors, the AF worked just a good as any of my Nikon systems.
