Results 1 to 7 of 7
Thread: A few of the lenses I can put on Sony A7rII
    Oct 2012
    Nyköping Sweden
    1,372
    Just six of the lenses I can use with the A7rII. Five of the six allow some tilts and shifts.
    http://echophoto.dnsalias.net/ekr/Articles/A7Flex/
    Click image for larger version.
Name:	Screen Shot 2016-02-07 at 18.44.07.jpg
    Best regards
    Erik
    KEMPTEN / GERMANY
    1,691
    118
    Re: A few of the lenses I can put on Sony A7rII
    Thank you Erik for showing these interesting combinations .
    Can you please give some info about what adapter and adapter/lens holder you use for the HASSELBLAD solution ?
    Thank you .
    Jürgen
    Regards . Jürgen .
    Oct 2012
    Nyköping Sweden
    1,372
    The web page has been updated with some more info:
    Some interesting stuff:
    I five of the examples the HCam Master TSII is shown. This is an adapter with a Sony FE mount on the back and a Canon EF mount on the front. It can be used with all Canon EF mount lenses and yields +/-15 mm shift and 10 degrees tilt.
    Shift is useful to avoid converging verticals and tilt allows for tilting the plane of sharpness.
    This combo gives my old Hasselblad lenses a new hang of life. The large image circle gives around 12 mm of shift. The same goes for my Pentax 67 lenses.
    The Canon 16-35/4 allows some shift and full tilt. The downside is that the lens needs to be stopped down before mounting on the adapter.
    The Rodenstock Rodagon 50/2.8 is hopefully usable as a macro lens, and the same applies to the Photar. Here they are shown in the Zork Mini Makro Mount that allows some focusing.
    Best regards
    Erik
    Thank you .
    Jürgen
    KEMPTEN / GERMANY
    1,691
    118
    Thank you Erik .
    Stefan Steib from HCam is not far from my place .
    I might contact him and meet him .
    Regards . Jürgen .
    Oct 2012
    Nyköping Sweden
    1,372
    Hi Jürgen,
    I use the Novoflex adapter on Stefan's recommendation. First I tried the "Fotodiox adapter" but that was quite crappy. The Novoflex is cleanly made. It consists of two parts a Canon back end and a Hasselblad front end.
    The Novoflex has rather small internal diameter, but I don't think it matters. There is some shading with shifts above 12 mm, but I think it comes from the internal baffles of the HCam Master TSII.
    For the Pentax I bought a Kipon (Pentax 67 to Canon EF) adapter. It is similar to the Novoflex, although the black painting on the inside of the Novoflex is better (more matte and less glossy).
    I have tried the Planar 100/3.5 and the Distagon 60/3.5 with "shift panos" on the A7rII the Planar 100/3.5 was pretty good and the Distagon was quite OK.
    Best regards
    Erik
    Thank you .
    Jürgen
    Oct 2012
    Nyköping Sweden
    1,372
    Some more sample images of the HCam Master TSII
    This page shows some more images of the HCam Master TS:
    http://echophoto.dnsalias.net/ekr/Ar...m_Master_TSII/
    This page shows some image samples with Hasselblad lenses on the A7rII: http://echophoto.dnsalias.net/ekr/Ar...nses_on_A7rII/
    The Master TSII allows something like 12 mm shift, so, the camera in vertical position and used shifted stitching I can get an image size 48x36 mm, about the same as with my P45+ (49x37 mm), but with twice the pixel amount.
    All stitching done in Lightroom.
    Best regards
    Erik
    Mar 2013
    289
    Re: Some more sample images of the HCam Master TSII
    Hi Erik,
    Could you check what is the image circle of the 25 photar at infinity?
    Thanks a lot
    David
