Anything comparable in C1? Is this for aliasing or for color moire?Doug,
This is from an article...
If you are processing a RAW capture that contains moiré patterns, you can use Adobe Camera Raw (or by extension, Lightroom’s Develop module) to reduce the appearance of these patterns. Simply select the Adjustment Brush, making sure that all of the adjustments are at their default values. Then increase the value for Moire Reduction to the maximum value of 100, and paint on the image in the area where the moiré patterns appear. You can then reduce the value for Moire Reduction to the minimum level required to remove the interference patterns.
The color moire is under control, it's the aliasing I'm trying to get around. Has anyone tried telling SteadyShot an alternate fact with a falsehood focal length? Would this induce a bit of blur that would mask the aliasing?Hi,
C1 has a similar tool. Also, I would say that C1 is better at hiding colour moiré.
In all cases this is more like local desaturation and smearing of colour information, so the programs don't really adress the aliasing but reduce the most obvious effect, name colour moiré.
Best regards
Erik
Yes that helped with color moire. This question is about aliasing. I was having trouble with color moire when using the a7II. I have not have significant aliasing trouble with the a7II.Doug, As I suggested earlier http://www.getdpi.com/forum/sony/55973-please-explain-purpose-aa-filter.html, if the FL input trick works for you in the A7 II, i would expect itbwould work equally good ot better with the A7R Ii due to the smaller pixels in its sensor.
