:thumbup: Great practical test, thanks for posting. I'm glad extension tubes can work without vignetting. Do you know the inside diameter of the extension tubes?Hardly use it, but I did a few 2:1 with extension tubes (52mm in total) and the 90/2.8 G. The extension tubes are some cheap no-name with electric contacts. There was no vignette so far but I had some light leak when the light came from a bad angle.
I'll check that at home and post a pic of them. I'm still at work and will go for a run when I'm home. Maybe it's been late until I can post you the details.:thumbup: Great practical test, thanks for posting. I'm glad extension tubes can work without vignetting. Do you know the inside diameter of the extension tubes?
Just one note about the extension tubes with the 90/2.8 G Macro. The lens is that sharp that I'm still not sure if a crop (without tubes) wouldn't give you the better result.
