Good zoom in range of 50-100mm for A7RII ?
KenLee
I shoot almost all my photos in the range between 50 and 100m in full-frame terms. The wonderful new 24-70 lenses are a bit short for my shooting style. Can anyone recommend a zoom in the roughly 50-100mm range, appropriate for the A7RII ?
While we're on the subject, is there a 75mm prime lens (not 85mm) which would work nicely ?
It's OK if these lens are manual focus and/or require an adapter: I'm just looking for a lens of sufficient resolution and desired focal length.
Many thanks !
pegelli
member scho (and maybe others) uses the Sigma MC11 adapter + Sigma 24-105 A. Maybe you can ask him for some samples to see if it meets your expectations.
ErikKaffehr
I use a Canon 24-105/4L with a Metabones IV-T adapter, this is my most used lens. I also have a Contax 28-85/3.3-4 and a Contax 35-135/3.3-4.5 zoom that I mostly use for tilt work.
A lens I don't own but which is known to be good is the Sigma 70/2.8 macro.
Canon 24-105/L samples here: https://echophoto.smugmug.com/Technical/Canon-24-105-4L
Best regards
Erik
Many thanks !
