Results 1 to 5 of 5
Thread: CZ 135 focus ring stiffness
    Member picman's Avatar
    139
    Just received my CZ 135. I've been taking some test pictures with it and optically it seems to be OK (well more than OK of course :-)). However, the focusring is so stiff. Also it is entirely in metal rather than having a rubber grip. Because of the stiffness, manually turning it just does not go in a smooth continuous movement. I will hardly ever be focussing manually, but still, is all this normal?
    Thanks, cheers, Bob.
    Senior Member Eoin's Avatar
    Feb 2008
    Dublin / Ireland
    410
    Re: CZ 135 focus ring stiffness
    It doesn't sound right, however, the focus ring is a hard metal, not rubber like the ZA zooms.
    When you say you can't turn the focus ring, I presume you are dis-engaging the AF via the mf button on the camera. These ZA primes don't have direct manual focus unless you set it up in the menu, main camera menu, page 3 AF-A Setup = DMF as opposed to AF-A. Then what happens is the camera autofocuses as normal and when focus is achieved it enables or disengages the af drive allowing you to manually focus via the focus ring.
    I think you can also program the focus hold button to do the same thing. The other method I use to manually focus is af as normal then press and hold the AF/MF button which enables the focus ring and adjust as necessary then keeping the button held press the shutter.
    The menu setting for this is, cog wheel page 1, AF/MF button = AF/MF Control.
    Feb 2009
    Bangkok
    1,470
    Quote Originally Posted by Eoin View Post
    I agree with what Eoin said, I have also done the same mistake in the beginning, and this could also damage the focusing mechanism. I like to select the AF/MF to be on toggle instead of hold. This way I can keep the camera on MF for as long as I wish.
    139
    Thank you both so much for the replies. I was simply not doing it right as I am used to the 16-35 and 24-70, but now I realize this is totally different. I usually read manuals very thoroughly but here I didn't think of reading the little leaflet that accompanies the lens. Here is what I found
    Eoin:
    Simply putting the camera menu item AF-A setup to DMF did not work at first, but I had the rotary switch on the front of the camera still on S. Once I put it on A the ring worked smoothly after focussing as you said.
    Engaging the af/mf switch on the back of the camera works: and then the ring turns very smoothly.
    edwardkaraa:
    Yes I too like to put the switch on toggle rather than hold. It avoids having to continually push that little button .. but you must not forget to switch back
    Putting the rotary switch on the front of the camera to MF also works and the ring becomes smooth to turn.
    Gee, am I glad I asked
    Cheers, Bob.
    Feb 2008
    Dublin / Ireland
    410
    Glad you got it sorted, I was not aware that the DMF didn't work on the S setting, I guess we learn something new every day.
