A7R III image stabilization and manual vintage lenses ?
archivue
is it possible to use image stabilization on a sony A7R III using a vintage lens ?
in photo mode ? video mode ?
i would like to use a bunch of contax/zeiss with a novoflex adapter... it would be perfect to be able to use it with image stab...
pegelli
Yes, you need to set the focal length in the menu and then the sensor based stabilisation will work
k-hawinkler
That can be accomplished with 3 buttons:
1) switching IBIS ON or OFF
2) IBIS focal length setting “Auto” or “Manual”
3) If “Manual” select from a list
Also autofocus is available with the Techart Pro adapter.
