Results 1 to 10 of 10
Thread: cRAW
    Feb 2009
    Bangkok
    1,470
    cRAW
    Anyone using this format? Seems to be slightly lossy but not more than Canon and Nikon standard raw. At 36mb per file, I'm starting to think standard raw is a waste of storage space.
    Aug 2008
    Bruce Peninsula, Canada
    2,535
    184
    Re: cRAW
    I've used it a lot for non-critical work and I simply can't tell the difference! Gary Friedman, in his book on the a900, says he can't tell either.
    I guess one should try a few direct comparisons in difficult conditions - high ISO and/or high contrast situations. I had read somewhere that there might be a noise penalty.
    Bill
    Feb 2009
    Bangkok
    1,470
    Re: cRAW
    So does this mean that only Bill uses cRAW over here? What about every one else? Standard RAW?
    Senior Member deepdiver's Avatar
    Mar 2008
    310
    Re: cRAW
    Me..!!
    I always use CRAW on my A900
    Leica M9 | SE 18 | Lux 24 | Lux 50 | ZM 35 | Nikon D700 | 35/1.8 | 45 PC-E | 50/1.4 | 70-200 VR II | SB 800+600 |SF 58|
    Hampshire, UK
    904
    20
    Re: cRAW
    I must admit to only ever using the full RAW image. Anything that smacks of compression I try and stay away from, only using conversion to jpeg's for images destined for web, email and digital projection.
    My workflow is: C1 for processing the Raw image and conversion to 16bit Tiffs using Adobe RGB colour space. Crop and Re-size using Photoshop and print from Photoshop using the full 16 bit tiff image. I also do the conversions from 16 bit to 8 bit and any change of colour space required in PS for saving to jpeg for web work.
    Since changing to the Sony A900 from a Leica DMR, I never need to do any more PP in Photoshop as C1 produces the perfect file. However I do prefer to use PS for cropping and of course printing.
    Cheers, Dave
    www.simmondsphotography.com
    rogprov
    Re: cRAW
    I've never seen a comparison between raw and craw convincingly demonstrating a difference in the image. Until then I shall continue only using craw as the saving in disk space is significant.
    Incidentally, being pedantic, raw is just the English word and not an acronym so should not be capitalised.
    Los Gatos, CA
    340
    Re: cRAW
    Quote Originally Posted by rogprov View Post
    But, "craw" isn't a word...at least not in this context...so where does that leave us? Which is more incorrect? Shouldn't that then be c-raw?
    Yes, the term "raw" was begat as an English word, but now it refers to a file type, just like cRAW does.
    Frankly, when I see a definition of a file type, I prefer to see it capitilized, just like it is with every other extension. A raw file to me is one that's literally uncooked.
    But maybe that's just stuck in my craw.
    Greg
    carstenw's Avatar
    Berlin, Germany
    2,530
    Re: cRAW
    Quote Originally Posted by gsking View Post
    Huh? Are you still using FAT?
    Carsten - Website
    Panopeeper
    Re: cRAW
    Some related info:
    1. Sony's craw is much less lossy than Nikon's 12bit lossy format of the D300/D3/D3X; it maintains about 1770 levels (out of about 3960 original raw pixel levels), in contrast to the D3's 690 levels (in 12bit mode) and over 2700 levels (in 14bit mode).
    It is a smart method, probably never causing posterisation.
    2. "Compressed" and "lossy" are not synonymous. The "standard" raw file of the A900 is compressed as well, though that is a rather simple and not very effective compression, but it is not lossy.
    3. The obvious confusion of some is probably caused by Nikon's and Sony's euphemism: the lossy format has been named "compressed". Originally, the non-lossy format of Nikon cameras was not compressed, but this anyway incorrect terminology became ridiculous: the D3xxx cameras offer three different formats: uncompressed (lossless), compressed lossless and compressed lossy.
    Nikon calls the compressed lossy "compressed" and the compressed lossless "lossless".
    Sony calls the compress lossless "standard" and the compressed lossy "compressed".
    4. Regarding "uncooked" raw data: the A900's data is the most cooked one I have ever seen, but it has nothing to do with compression or lossiness, i.e. it is cooked, no matter if standard or craw. See Noise reduction in the A900 raw data
    Not directly on-topic:
    5. Canon DSLRs always compress the raw data, but always losslessly.
    6. FAT is not a file format.
    carstenw's Avatar
    Berlin, Germany
    2,530
    Re: cRAW
    Quote Originally Posted by Panopeeper View Post
    Right, it is the file system which DOS gave us. However, it is the only filesystem I am aware of which forces capitalization of filenames, including extensions. gsking was talking about capitalized extensions. My Mac uses lowercase for all extensions, as do all modern versions of Windows, and probably all unices.
    Carsten - Website
