Results 1 to 4 of 4
Thread: LAOWA 12mm lens on Sony A7Riii
    Aug 2008
    Saugeen Peninsula, Ontario
    2,595
    216
    I recently added this lens to my Sony arsenal and am very pleased with it. My only complaint is that focussing it with the marks on the lens is pretty inaccurate. In fact infinity is sharpest when turned to about 3 metres or 10 feet. (But F8 is very very sharp!)
    Focussing using peaking is very difficult for far subjects but just fine at closer distances.
    Have others found this too?
    Oct 2011
    Kraków
    103
    Re: LAOWA 12mm lens on Sony A7Riii
    Quote Originally Posted by Bill Caulfeild-Browne View Post
    I have this lens for Pentax, Some Pentax Forum users also have problem with infinity.
    What I found is @ infinity @2.8 I have sharp center but quite weak corners so I use similar 3m set. But I thinks it is because of field curvature, so it is a feature .
    May 2009
    Marseille, FRANCE
    1,005
    i'm going to test it with the magic shift converter... i hope it will be better than the 17 TS-E !
    May 2009
    Marseille, FRANCE
    1,005
    better than my friend 17 TS-E ( not the best copy... )... and using a simple adapter, you can use it as a 12mm... i'm buying it...
    I still prefer the 24 TS-E II... but when you need to go wide...
    please Laowa... make a simple and small 35/4 PC... no competition !
