Results 1 to 8 of 8
Thread: Sony A7r IV pixel shift with strobe problem
    Jun 2016
    22
    Hello,
    I just bought an A7r IV and have been putting it through some tests. I'm very impressed by the results, especially the pixel shift. One thing though, When i use pixel shift with a strobe, I get frames that are mostly black. e curtain shutter on or off doesn't appear to change this. Has anyone else experienced this and/or have an inkling on how to remedy it?
    Many Thanks,
    Al
    Click image for larger version.
ID:	144380Click image for larger version.
    Senior Member Barry Haines's Avatar
    Mar 2014
    Cornwall
    2,150
    Re: Sony A7r IV pixel shift with strobe problem
    Quote Originally Posted by alharding View Post
    Hello,
    Many Thanks,
    Al
    It's been a couple of decades since I professionally lit interiors with flash...but it looks to me like the shutter speed you have chosen is faster than your flash synch speed of your camera.
    These links maybe of help
    https://fstoppers.com/originals/demy...eed-sync-68527
    https://www.tanguayphotomag.biz/flas...flashsync.html
    Enjoy your A7R IV camera
    Jun 2016
    22
    Thanks Barry, I appreciate this. I think your answer makes sense. I'm still at a loss as to why it doesn't occur in single shot vs. Multi shot but the sync issue does explain the look of the partially black frames. Thank you,
    Al
    Hello,
    Many Thanks,
    Al
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    4,768
    +1
    With best regards, K-H.
    Jun 2016
    22
    I just ran some more tests and Barry, you were correct. Anything faster than 1/8 causes the artifact. Very low sync speed with the pixel shift.. It has to be static anyhow I guess.. Thanks again,
    Al
    Thanks 4 Member(s) thanked for this post
    Senior Member seb's Avatar
    Aug 2015
    Switzerland
    456
    19
    It may depend on the flash as well... What flashes you used? Do you checked High Speed Sync?
    My preorder of the a7RIV is still open. Therefore I can't check it by my own to give you some more experience data.
    Al
    Jun 2016
    22
    I had only used the camera with a Profoto Acute 2400 set..I haven't tried the HSS options or another flash just yet. Its a good point though, I should try some other units. P.S. The camera is great. You'll be pleased with the results.
    Quote Originally Posted by seb View Post
    Aug 2015
    Switzerland
    456
    19
    From dpreviews review:
    Key takeaways to pixel shift:
    • Users can choose to capture 4 shots to cancel the Bayer filter array and get better detail from 60.2MP files, or capture 16 shots and combine them on an editing computer for 240MP files
    • Works with strobes, but the fastest shutter speed available is 1/8 sec
    • No motion-correction severely limits the range of subjects it can be used with
    • Cumbersome 'Imaging Edge' software is required for best results (the camera cannot combine its images internally)
    Flickr
