Results 1 to 5 of 5
Thread: Difference in PS after ACR processing
    Apr 2009
    Sydney, Australia
    581
    2
    I hope this is a dumb question, but here goes. I took a number of people shots at the weekend and just started to work on them. I used ACR to get WB and a bit of vignetting and then opened them in PS CS4. The image that I see in PS is significantly redder than what I was seeing in ACR. Given that I am looking at skin tones, the difference is really obvious.
    I am using a calibrated Eizo CG2222W. Any one have any idea, how this can happen?
    Jeff
    Senior Member kweide's Avatar
    Germany
    1,631
    Re: Difference in PS after ACR processing
    Adobe RGB or SRGB or ProPhoto or which colorspace ???
    __________________________________________________
    Part of the Wonderland
    see more ( NSFW ) on : http://www.klaweide.de
    23,623
    2555
    Sounds like your color space is off in PS
    www.guymancusophotography.com
    Apr 2009
    Sydney, Australia
    581
    2
    I'm using ProPhoto in PS. In ACR it shows Sony DSLR-A900. Funnily enough, this looks like the same problem I had with Phocus a while back. Under CS4, it always opens the image on the primary monitor (an iMac) where it doesn't look too bad. When I drag it to the Eizo monitor it goes red.
    I just opened it with CS3. It looks great so the issue is in CS4. I also posted in the Adobe forums and the suggestion over there is that it may be an OpenGL issue. I'll report back once I sort it out.
    Thanks for your help.
    Apr 2009
    Sydney, Australia
    581
    2
