Results 1 to 9 of 9
Thread: A900 - can I do this?
    Oct 2008
    Saffron Walden, UK
    1,983
    58
    The A900 has several useful functions: mirror lock up, auto bracketing, and the remote commander.
    Can they be used in combination?
    The same (drive) menu is used to select between these three functions. Ideally one would be able to use them together.
    The remote commander does away with the need for any corded remote. Use that together with, say, continuous autobracket when the A900 is on a tripod and hey presto, an HDR redy combination taken with minimum effort. Or maybe select mirror up and use the remote commander for reduced vibration.
    Quentin
    Quentin Bargate
    Oct 2008
    Saffron Walden, UK
    1,983
    58
    Re: A900 - can I do this?
    A check on another forum sugggest not
    Looks like Something Sony could address in a firmware upgrade.
    Quentin
    Quentin Bargate
    Senior Member Braeside's Avatar
    Jan 2009
    Fife, Scotland (UK)
    1,171
    You are right Quentin, it isn't possible with the supplied remote commander, unfortunately.
    I have a third party wireless (radio) remote that I can use for that however, got in eBay a couple of years ago, very inexpensive, and has minolta/sony plug on it. I velcro the receiver to the tripod leg.
    David Anderson
    Jan 2009
    Fife, Scotland (UK)
    1,171
    The one I use is similar if not identical to this which is about $20 from Hong Kong.
    http://cgi.ebay.com/Wireless-Remote-...25112009r11392
    David Anderson
    Oct 2008
    Saffron Walden, UK
    1,983
    58
    Thanks, looks interesting, David - but how dumb of Sony not to enable their own supplied controller to do this? Nuts.
    Quentin
    Quentin Bargate
    Hampshire, UK
    904
    20
    I am not too keen on the remote commander as you need to be slightly in front of the camera/tripod for it to work! I prefer to use the remote cable, I have the long one which can always be coiled up for when you need to use a shorter cable. Never tried it with bracketing, mirror up though!
    Cheers, Dave
    www.simmondsphotography.com
    Feb 2009
    Bangkok
    1,470
    Sony probably believes the remote control is to take pictures of yourself with your friends. After I discovered it can't lock the mirror up, I bought the good old 50cm remote cable. The remote control is awkward to use as Dave mentioned as the sensor is in front and it is just a gimmick to impress the buyers and his friends not a serious tool.
    Jan 2009
    Fife, Scotland (UK)
    1,171
    I believe that the remote is as you say designed for self portrait like situations, where the front sensor makes sense. It is also really useful if you are showing camera pictures on an HDTV via HDMI. I have used it about twice only. I normally just use the 2 second timer built in to the camera if I don't have a cable or radio wireless release with me. The radio unit I mentioned is nice if you need a bit of range, like remote picture taking of birds at the feeder and so on.
    David Anderson
    8,498
    44
    Quote Originally Posted by Braeside View Post
    Big difference between radio control and optical control. I may get that Hong Kong one for weddings when I have a camera on the Balcony and am on the floor shooting from the side lines. Cool tip, thanks.
