Results 1 to 10 of 10
Thread: Sony Cable release
    Terry's Avatar
    New York City
    6,955
    1145
    Sony Cable release
    On the A900 when you go to drive mode you can choose the self-timer OR mirror lock-up OR remote cable release.
    So, seeing as you can only pick one and not a combination of two what do you think is best for shooting on a tripod?
    Apr 2009
    98
    Re: Sony Cable release
    Remote release in the menu is for the IR remote control. With Cable release it functions simply as a shutter press. It will function in whichever drive mode you put.
    Nitin
    A and E mount Too many lenses.
    Terry's Avatar
    New York City
    6,955
    1145
    Thanks,
    Sony doesn't do the users any favors in product labeling. The cable release is called the "Sony Remote Commander"
    terry
    Feb 2009
    Bangkok
    1,470
    When you use the 2 seconds timer, it acts also as mirror lock up, with or without cable release.
    Terry's Avatar
    New York City
    6,955
    1145
    I guess I need to go back and read the manual. Last night when I was using it on the 2 second timer it sounded like it might be doing the lockup when you pressed the shutter but when I read Reichman's field test on LL he said this
    "Another annoying aspect, given how useful this could have been, us that there is also a 2 second self timer release, but there's no way to combine this with mirror lock up, since these are found on mutually exclusive settings in the Drive menu setting.
    Come on Sony! This is almost as bad as the design faux pas usually found from the other guys. Doesn't anyone ever actually ask photographers to field test these things before committing to production? The difference between good and great is when you sweat the small stuff, and this is all small stuff."
    Edit:
    Yes I should have started with the manual:
    After you press the shutter button, the shutter will be released about two seconds. This is convenient to reduce the camera shake because the mirror moves upward before shooting.
    Thanks Edward!
    carstenw's Avatar
    Berlin, Germany
    2,530
    The mirror always moves up before shooting! The question is when You could take the lens off and look in as it takes the photo to get the truth. I wonder if Michael Reichmann had an earlier firmware version?
    Carsten - Website
    Subscriber Member Georg Baumann's Avatar
    Feb 2008
    787
    82
    There sure is room for improvement. When using the cable release, on pressing the shutter the mirror goes up, until you press again. In addition I would love to see a timing where you can freely assign a time frame until the shot is taken.
    218
    2
    Nice remotes available on ebay
    I have purchased two ir remote releases and an intervalometer from ebay. I purchased two in case one goes bad but they are very convenient. They mount on the flash shoe and plug into the remote socket on the camera. You can remove the box from the shoe and use it as a corded release or you can use the included ir remote and use it without the cord. BTW one did not work out of the box but was quickly replaced by the seller.
    I have yet to use the intervalometer.
    Mike
    Los Angeles, California, USA
    1,965
    The problem is that, for some reason, when you use the included IR commander with the 2 sec delay button, it doesn't use mirror lock up. The 2 sec mirror lock up only works when activated from the body.
    Senior Member Braeside's Avatar
    Jan 2009
    Fife, Scotland (UK)
    1,171
    Apparently the IR commander is only designed for taking self portraits of groups when you all stand in front of the camera, (note the IR sensor is on the front of the camera).
    They figured that the 2 sec mode button on the IR commander was to allow you to put the commander out of sight before the shutter fired. It doesn't put the mirror up until it fires to allow the AF to work if someone moves. (This is what I read somewhere else and I suppose it makes sense).
    However, if you want to use the built-in 2 sec timer (which does have MLU), then you need either a wired remote (Sony or 3rd party) or one of those el-cheepo eBay wireless (not IR) remotes which have a much better range than IR commander and you can be behind the camera (or anywhere else).
    I'm not apologising for Sony, just explaining the practicalities. We have been up against this since the A700 came out with the same logic.
    David Anderson
