Results 1 to 11 of 11
Thread: CZ 16 80
    Jamesmd
    CZ 16 80
    Hi all , is this lens ok ? As it's small and light , and I have fast lenses allready , I think it's a good option for travel .
    Is it ok for A900 FF or is it thought for A700 ...?
    Thanks , would apteciate your opinion if you have one.
    Cheers
    James
    Senior Member Eoin's Avatar
    Feb 2008
    Dublin / Ireland
    410
    Re: CZ 16 80
    It will work but the a900 will use only part of the sensor to record the image. In other words the a900 operates as a a700
    A7II, FE 35, 55 C/Y 18, 28, 85, 100, 28-85
    Jamesmd
    Re: CZ 16 80
    Hi sir , uff , new system new world , 1000 questions .
    Do you have it ? did you like it ?
    Cheers
    James
    Feb 2009
    Bangkok
    1,470
    Re: CZ 16 80
    Not as good as the other Zeiss zooms. Why would you want to use it on the A900? You get only 11mp.
    Jamesmd
    Re: CZ 16 80
    Eduard , just looking for a light flexible combination for some situations ,
    I just remembered I have a dinax 7000i somewhere , those would be ok , no ?and of course FF .
    James
    Los Angeles, California, USA
    1,965
    Re: CZ 16 80
    Not much reason for that lens on the A900. Tamron 28-75 would be a better low cost, light alternative.
    Jamesmd
    Re: CZ 16 80
    thanks Douglas I'll consider it
    cheers
    1,965
    Re: CZ 16 80
    Also, Jono has been digging his little Sony 24-105, I believe, so you may want to contact him.
    Apr 2009
    384
    Re: CZ 16 80
    James
    It is lens better on A700 and is a good all around lens. I have it on A700 as a standard zoom lens. If you have not had any dSLR then A700 with this lens is a good start.
    Luc_R
    Re: CZ 16 80
    Better option than the CZ 16-80 is indeed the Sal 24-105. A little vignetting occurrences sometimes and not so sharp on the corners, but still a bargain for the A900.
    A example :
    Exif included.
    Spyder
    Re: CZ 16 80
    Very nice lens on the A700, sharp and pleasant contrast/colors. Not a premium, but better than average.
