Page 107 of 368 FirstFirst ... 7 57 97 105 106 107 108 109 117 157 207 ... LastLast
Results 5,301 to 5,350 of 18375
Thread: Fun With Sony Cameras
  1. #5301
    Mar 2011
    Beach Haven, NJ
    679
    Re: Fun with the A7/7R
    Quote Originally Posted by gurtch View Post
    A7R with Sony LA4 adapter and Minolta 20mm f2.8 lens, hand held. ISO 400, 1/100 at f9. Center is sharp, corners not bad, edges (left /right) a little soft, but all in all I would not hesitate to make a 20"x30" print. I have also included a 100% crop, actual pixels....no sharpening applied yet
    Dave in NJ
    Thank you all for the kind words and encouragement.
    Dave in NJ
  2. #5302
    Senior Member Bill Caulfeild-Browne's Avatar
    Aug 2008
    Bruce Peninsula, Canada
    2,465
    145
    Quote Originally Posted by Pham Minh Son View Post
    But a little soft and fluffy to the lower corners. This could be the lens or the adapter aberration.
    I was focussed on the white number plate. The lower corners are simply too near for the DOF and are just out of focus.
    Bill
  3. #5303
    Aug 2008
    2,465
    145
    Quote Originally Posted by MarcB83 View Post
    Bill, apologies for my ignorance, but what do you mean by LCC plate; what does it entail? Etc.
    I did Google it but not with satisfactory results.
    Thanks!
    Marc
    Marc, it's Lens Cast Correction plate sold with Phase One MFDB. Basically it's a square of white translucent plastic - you could like use anything white, flat and milky that allows light to pass through.
    You use it by shooting a second shot through it after you have taken your picture, at the same exposure and focus as you used for the shot. Then, in Capture One, you combine the two exposures. Lightroom has a similar facility.
    It's usually used when shooting with a tech camera where swings and/or tilts are involved but I often use it for any extreme wide-angle such as the Voigtlander Heliar 12 mm, the Elmarit M 21 mm and even (on the A7r) the Summicron 28 mm.
    You can also buy software called Corner Fix which does much the same thing, but not as well IMHO.
    It's quite easy, even when shooting handheld, to pop the LCC plate up against your lens shade to take a second shot.
    You can "save" your LCCs in Capture One so after a while you can use previously shot LCCs and apply them to other pics from the same lens and characteristics. Then you need no longer create one each time you use the wide-angle lens
    Hope this helps!
    Bill
  4. #5304
    Austria, close to Vienna
    3,728
    Quote Originally Posted by jaree View Post
    Thanks Peter. I shoot RAW and process in LR. For the WATE shots, the only PP I did is to adjust the exposure/highlights, basically pulling them back and added blacks.
    Generally, I don't spend more than 2 minutes on an average for each picture (after that my patience runs out!).
    Best,
    Eeraj
    Eeraj,
    so there are then obviously no corner issues as color shift etc even using the WATE on the A7r - good news!
    Thanks again
    Peter
  5. #5305
    3,728
    Quote Originally Posted by Bill Caulfeild-Browne View Post
    Thanks very much, Peter.
    Processed in C1 at defaults with a +15 saturation and a lightening of the shadowed verandah, no other adjustments. I have cropped a bit and would clean up the top left corner if I were to print it.
    Bill,
    that should prove that also the 35 is working nicely on the A7r - no color shift or what so ever. This is very good.
    Peter
    Life is an ever changing journey
    http://photography.tomsu.eu/
    https://www.flickr.com/photos/peter_...tography/sets/
  6. #5306
    Shashin's Avatar
    May 2011
    Maine, USA
    4,343
    139
    That is called snow…
    Will
    http://www.hakusancreation.com
  7. #5307
    Jan 2012
    New Jersey, USA
    346
    You are welcome, Peter. Note that I am using the A7 and not A7R. Based on samples I have seen, I believe WATE also works fine on the A7R. It is really a fine lens with superb color and contrast.
    Quote Originally Posted by ptomsu View Post
    Eeraj,
    Thanks again
    Peter
  8. #5308
    Senior Member PSon's Avatar
    897
    139
    I can always count on Will to get the joke. LOL
    ALPA (MAX, STC, TC) | CAMBO (Actus DB2, WRS-AE) | CONTAX | HASSELBLAD | LEICA | DS (CFV-16, IQ180, IQ260, IQ3100, M9-P, P25) | Lens (Canon, Fujinon, Leica, Nikon, Pentax, Rodenstock, Schneider, Zeiss)
  9. #5309
    Senior Member bensonga's Avatar
    Alaska
    2,383
    802
    A couple more of the Raven totem.
    A7 with the Leica 50mm Summicron-R lens at about f4 or f5.6.
    Likes 14 Member(s) liked this post
  10. #5310
    Oct 2008
    Seattle, WA
    5,672
    Dublin, Ireland. Second week of December. A7 with Sony 28-70mm lens.
    Cheers, Matt
    Zenfolio | Matt Driscoll
    Flickr | M_Driscoll
    Likes 10 Member(s) liked this post
  11. #5311
    May 2011
    Paris, France
    337
    Awesome pair, Bensonga,just awesome! The last one is my favorite!
  12. #5312
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,010
    762
    Quote Originally Posted by GrahamB View Post
    From one of my favorite movies, Kirk Douglas portraying Vincent Van Gogh in "Lust for Life" (1956).
    Great images Michiel.
    Graham
    I knew it was supposed to be van Gogh but not Kirk Douglas playing him. Thanks!
  13. #5313
    Mar 2009
    Amsterdam/Normandy
    4,010
    762
    Quote Originally Posted by philber View Post
    +1
  14. #5314
    Mar 2009
    Amsterdam/Normandy
    4,010
    762
    The old main postoffice turned into a shopping mall.
  15. #5315
    Dec 2013
    Montreal, Canada
    9
    Bill,
    Thanks a lot! Really clear and helpful.
    Marc
    Hope this helps!
    Bill
  16. #5316
    May 2011
    Paris, France
    337
    Quote Originally Posted by Michiel Schierbeek View Post
    Glad to read this. I would have been sorry for you, had you written: this the great Kirk Douglas, but who is this Van G... guy you are talking about?
  17. #5317
    Senior Member W.Utsch's Avatar
    Oct 2012
    Heidelberg, Germany
    911
    The "Groupello Fountain", Mannheim, Germany
    Likes 15 Member(s) liked this post
  18. #5318
    Alaska
    2,383
    802
    Werner -- I'm really impressed with photos you've posted with the Leica Apo-Macro R 100 on the 7R!
    Manchester/Jerusalem
    2,652
    290
    A7r with 50mm Tak Super @ f1.4 If I'd used magnification rather than peaking it might even have been properly in focus! Some pictures come perfect out of camera, changing anything would be a crime. Doesn't happen often to me but this is one.
    Likes 12 Member(s) liked this post
  20. #5320
    Aug 2009
    724
    Love it!
  21. #5321
    Member pozzello's Avatar
    Oct 2012
    Montreal
    68
    Love/hate relationship with this camera - today it's love
    24mm TS-E stitch :
    website: http://www.paulozzello.com
    Likes 11 Member(s) liked this post
  22. #5322
    Aug 2008
    2,465
    145
    Weather too lousy to go out today so tried something indoors for a change.
    a7r with Summicron 75 mm ASPH at its closest focus. & shots with Helicon Focus.
    Bill CB
    www.billcaulfeild-browne.ca
  23. #5323
    Subscriber Member dunders's Avatar
    Jun 2012
    Isle of Man
    81
    29
    The weather's lousy here, too!
    I took the opportunity to plagiarise Michiel: I've often wondered how to digitally frame images, and never quite got round to applying the leetle (*very* leetle in my case!) grey cells. It seems that Mogrify is my friend...
    This is with the CV 4/21, which doesn't work with the A7r.
    Now - if I can figure out how to do that nice 3d shadow effect......
    pace Michiel!
    Paul.... lost in the Irish Sea
    http://www.flickr.com/photos/dunders/
  24. #5324
    Mar 2011
    Beach Haven, NJ
    679
    Frigid weather here along the NJ shore. Took these recently, A7R, FE 55mm lens hand held
    Dave in NJ
  25. #5325
    Oct 2012
    Montreal
    68
  26. #5326
    Mar 2009
    Amsterdam/Normandy
    4,010
    762
    Quote Originally Posted by dunders View Post
    pace Michiel!
    I was just wondering about that lens. What's wrong with it, corner colour cast again on that naughty A7r?
    It is just a simple dropshadow in Photoshop; copy the layer - select the first layer and make it a little bigger in canvas size - select the second layer and go to layers, layerstyle, dropshadow and make your desired shadow.
    Once you got it you can make an action of it and it will be a whistle of a cent.
    Michiel
  27. #5327
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,855
    http://www.getdpi.com/gallery/files/...allaterson.jpg
    pace Michiel!
    Pretty darn nice for a lens which doesn't work ... !
    You can do drop shadows with the Lightroom Print or Slide Show modules. Dial 'em in, output as JPEG. Easy, fast ...
    897
    139
    Between the Roads (A7R + Summilux-M 50 ASPH)
  29. #5329
    Oct 2008
    Seattle, WA
    5,672
    Dublin, again, with the A7 and 28-70 mm.
    Cheers, Matt
    Flickr | M_Driscoll
  30. #5330
    ashwinrao1's Avatar
    Feb 2010
    Seattle, WA - USA
    3,276
    Greetings from the Super Bowl, my friends. I have been busy, mainly shooting the A7 with native and M glass...and coming away quite satisfied:
    Ashwin Rao
    Seattle, WA
    My Photography
    Likes 19 Member(s) liked this post
  31. #5331
    Oct 2012
    Montreal
    68
    Thanks to everyone who recommended SilverEfex Pro !
    Likes 13 Member(s) liked this post
  32. #5332
    752
    I used to live in Seattle but now in the san fran bay area.. so i don't like these
    Quote Originally Posted by ashwinrao1 View Post
  33. #5333
    Oct 2008
    Seattle, WA
    5,672
    Ash: Awesome! Just like being there. Terrific shots. I especially like this one of Sherman laughing. In that media circus, probably no one noticed that the little thing in your hands was an actual camera.
    Thanks for the vicarious thrills!
    Cheers, Matt
    Flickr | M_Driscoll
  34. #5334
    Jun 2012
    Isle of Man
    81
    29
    Corner colour cast and smearing with both the 4/21 and the 4.5/15. I bought into the 'Lens Correction' app from Sony, and a very 'quick and dirty' correction has dramatically improved images from both lenses. There is some corner smearing and vignetting with the Biogon 2/35 and even with the Nokton 1.5/50 wide open, but I haven't tried the 'lens correction' app with these: in real-world use most images from these seem pretty good, though they wouldn't always please the pixel-peepers.
    Michiel
    Thanks, Michiel. I don't have PS, but Godfrey has pointed me to a LR solution. I'll try it next time it rains....
  35. #5335
    Jun 2012
    Isle of Man
    81
    29
    Thanks, Godfrey. I'll give it a try next time it rains. That'll be soon, then!
  36. #5336
    Jun 2012
    Isle of Man
    81
    29
    Lovely stuff! These are outstanding!
  37. #5337
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,728
    HI There - I lent my A7 to a friend for a week, just got it back, absence makes the heart grow fonder! Here are a couple from last night with the kit lens:
    Waiting for the train
    Past the Glass
    Just this guy you know
    Likes 9 Member(s) liked this post
  38. #5338
    Mar 2011
    Coral Gables, FL
    642
    Ashwin, sweet stuff. A great photographer with unparalleled access to his subjects is a combination that cannot be beat.
  39. #5339
    2,652
    290
    Past the Glass
    That picture is making me need a pint!
  40. #5340
    Mar 2009
    3,574
    Ashwin...fabulous shots and as usual! I'm saying this with a mix of admiration and envy .
    The shots of Sherman are especially good from a reportage point of view and I think there is something to be said for using a small unobtrusive camera like the A7 in such an environment. Most definitely looking forward to future postings of your Superbowl week experiences!
    Dave (D&A)
  41. #5341
    23,623
    2555
    Just to add to the fun. Leica 19mm R lens
    www.guymancusophotography.com
  42. #5342
    Senior Subscriber Member
    Feb 2008
    411
    Guy, do you use the Leica hood for your Elmarit-R 19?
  43. #5343
    23,623
    2555
    NO. The dang hood even with my retrofitting the hood for the D800e on the Sony A7r I still see the dang corners. So here is what i did , I just got this and it takes a 77mm filter but when I put the ND 77mm I got vignetting so i am ordering a new 85mm ND with step up for it. But Stephen sent me this link and i bought it, serves as a nice hood for one and i ordered a 80mm push on cap for it too. Really like this
    Here are some links
    Duclos Lenses — Leica 19mm V.II 80mm Step-Up Ring
    Kaiser 80mm Push-On Lens Cap 206980 B&H Photo Video
  44. #5344
    2,681
    This is from the A7r....
    Sony ICLE-7R
    Thanks,
    Bob
  45. #5345
    Feb 2008
    411
    Guy, thanks very much for the info. I really like the Elmarit-R 19 but not the hood! I am also glad that you kept your copy (I was worried when you had it FS few weeks ago).
  46. #5346
    23,623
    2555
    Quote Originally Posted by Ocean View Post
    Guy, thanks very much for the info. I really like the Elmarit-R 19 but not hood! I am also glad that you kept your copy (I was worried when you had it FS few weeks ago).
    I was having a bad brain fart. LOL
    Actually i was thinking of a canon 17 TSE lens to replace it which is not a bad thought but it also took the small lens away with a big truck of a lens and also I realized its usage is limited. Something i could rent when i get a gig like that.
  47. #5347
    ashwinrao1's Avatar
    Feb 2010
    Seattle, WA - USA
    3,276
    A few A7/M lens combo. Color was a challenge here, due to the mixed lighting...
    Ashwin Rao
    Seattle, WA
    My Photography
    Likes 16 Member(s) liked this post
  48. #5348
    2,681
    Trains in Texas....
    Sony ICLE-7R Zeiss ZF.2 25 F 2.0
    Thanks,
    Bob
  49. #5349
    Godfrey's Avatar
    Jan 2009
    7,855
    Correction ... Not the Print module, just the Slide Show module. Demonstration:
    Pentax *ist DS, FA 100-300mm
    ISO 800 @ f/11 @ 1/3200 s @ 255mm fl
    (Three more of these from my visit in 2005 just posted to flickr.com. Click the above to get there...)
    Godfrey - GDGPhoto Flickr Stream
  50. #5350
    Godfrey's Avatar
    Jan 2009
    7,855
    Quote Originally Posted by docmoore View Post
    Trains in Texas....
    Thanks,
    Bob
    That's gorgeous, Bob.
