Page 108 of 368 FirstFirst ... 8 58 98 106 107 108 109 110 118 158 208 ... LastLast
Results 5,351 to 5,400 of 18380
Thread: Fun With Sony Cameras
  1. #5351
    2,681
    Re: Fun with the A7/7R
    Thanks Godfrey...the initial look at the RAW file was uninspiring...sometimes it helps to look again. I do like it a lot myself.
    Regards,
    Bob
  2. #5352
    No CA
    746
    Nice reportage, Ashwin! Do you happen to recall what lenses? They seem to be covering the corners quite well.
    Kirk
  3. #5353
    Godfrey's Avatar
    Jan 2009
    Near San Jose, California
    7,857
    The Elmarit-R 24/2.8 I bought via Ebay arrived. It's in generally very nice shape, in the original box with packing and lens hood. Very tiny scratch on the front element ... inconsequential. Focus ring and aperture work smoothly and easily, no oil on the aperture blades.
    I fitted it to the A7 and did a couple of quickie test shots (still too darn busy to take a few hours off and go for a shooting walk). Corners look good (little to no smearing) even at f/2.8, of course they tighten up and look better at f/4 and f/5.6. A bit of light falloff wide open, again better when stopped down a stop, etc.
    I think compatibility with the A7 sensor is at least very good. I'll have to do some more rigorous testing. This is one I'll likely shoot a roll of film alongside the A7 to really see what the lens is like in both mediums. But I'm already pretty sure its going to work out just fine anyway. :-)
    Now back to work.
  4. #5354
    Ithaca, NY
    3,438
    Just received a near mint condition Leica R Vario-Elmar f/4 35-70 and played around inside with macros and focus stacking. Very nice lens and hope it warms up a bit this weekend so I can take it out for a test walk.
    Carl
    Gallery
    Likes 13 Member(s) liked this post
  5. #5355
    Ithaca, NY
    3,438
    Now back to work.
    Congrats Godfrey. I have this lens also and it behaves about the same as you described on my A7R, except I have to stop down to about f/8 to get the corners sharpened up. My 28 elmarit R is better in terms of edge/corner performance on the A7R, but both are very sharp and produce nice color with the sony sensor.
    Carl
    Gallery
  6. #5356
    ashwinrao1's Avatar
    Feb 2010
    Seattle, WA - USA
    3,276
    Quote Originally Posted by thompsonkirk View Post
    Kirk
    Hi Kirk, I used the 21 SE (rarely), and mainly the 35 lux asph (pre FLE) and 75 Summilux...All seem to do fine for this type of work, on the A7. The 35 and 75, in particular, were stellar, and the 21 was totally fine in this light and circumstance...plenty sharp and not much notable smearing...
    Ashwin Rao
    Seattle, WA
    My Photography
  7. #5357
    Senior Member nostatic's Avatar
    Jan 2008
    socal
    1,037
    Wait, you're not allowed to shoot sports with a mirrorless. Even media days. I'm sure it violates some state law or something.
    Maybe if you painted the lens white...
  8. #5358
    Apr 2013
    14
    C/Y Planar 50mm f/1.4 @ f/2.0, fast becoming my favourite lens
    Likes 17 Member(s) liked this post
  9. #5359
    Senior Member W.Utsch's Avatar
    Oct 2012
    Heidelberg, Germany
    911
    With the ZE 18/3.5
    "Curves and straight lines - Cold and Warm"
    Likes 7 Member(s) liked this post
  10. #5360
    Dec 2013
    232
    Quote Originally Posted by kienchil View Post
    That's what I call impressive!
  11. #5361
    Godfrey's Avatar
    Jan 2009
    7,857
    Quote Originally Posted by scho View Post
    Thanks!
    I wonder if the better edge/corner performance of the 28mm is mostly because it's a slightly longer focal length. No matter really, just idle conjecture ... :-)
    I put the A7+Elmarit-R 24mm on a tripod this morning and set it level (vertically) and square to cover my bookcase so I'd have plenty of corner/edge detail to look at. I did two exposure test runs: first run I focused on an item near the center of the FoV, second run I focused on an item at the corner of the FoV.
    f/2.8 - corners are approximately 1EV down from center and somewhat soft. Center is good.
    f/4 - corners are about .3-.5EV down from center, sharper to very good; center is excellent.
    f/5.6 - corners are within .1EV from center, excellent; center excellent
    f/8 - little change
    f/11 - little change
    f/16 - slight softening overall (diffraction I am sure)
    f/22 - slightly more softening overall
    I saw no evidence of sensor-induced smearing, just normal wide-open softness and fall-off at the corners for an ultra-wide lens from f/2.8-f/4. By f/5.6, performance was great everywhere.
    There's a small amount of lateral CA; Lightroom 5.3 eliminates it completely.
    I did a composite JPEG showing a detail clip of the lower-right corner of the frame. The only processing done beyond the LR5.3 defaults was to turn on lateral CA removal and add 0.7 EV exposure to all seven frames. The image file is large (5100x1200 pixels, 1.5Mbytes) so you can see the detail, I'll link to it rather than embed it:
    https://dl.dropboxusercontent.com/u/...erformance.jpg
    Overall, I'm sure this lens is usable even at f/2.8 for less demanding work (say, trying to work with very dim circumstances and more hand-held, people type subject matter), but for more demanding work f/5.6 to f/11 is the sweet range. Very pleased ... I'll have to repeat the experiment with the Leicaflex SL to confirm that what I'm seeing is purely lens and not sensor, but it's darn good enough anyway. Can't wait to get out and do some real shooting with it. :-)
    BTW, this was also my first opportunity to test the Novoflex ASTAT/NEX tripod mount. It's a little fussy to set up since you have to remove the mount adapter and fit it, then replace the adapter with the foot loose. To get it aligned correctly, I first aligned and leveled the tripod head. Then I fitted the camera and turned on the camera's two-axis level display. I rotated the camera until all indicators went green with the camera in horizontal orientation, tightened the clamp, and put a paint mark on the device and on the adapter. Then I loosened the clamp, rotated the camera 90 degrees for vertical orientation aligning the heads up display, and added another paint mark on the adapter.
    With index marks now in place, it is very easy to rotate the camera orientation between landscape and portrait with virtually no disturbance to the optical center of the framing or the rest of the tripod setup now.
    happy happy
  12. #5362
    Senior Member Bill Caulfeild-Browne's Avatar
    Aug 2008
    Bruce Peninsula, Canada
    2,468
    145
    My village is completely cut off owing to severe weather. The only road in (we're at the end of a peninsula) has been closed for nearly four days. Fortunately we have plenty of food, fuel and wine.
    But getting out is a problem so I'm back to some indoor sport. Here is my venerable Rollei 2.8F taken with the a7r, LE4A adapter and Sigma 70 mm A mount macro. Shot at F8 and 1/6th second with no evidence of shutter vibration. 6 shots processed with Helicon Focus.
    Bill CB
    www.billcaulfeild-browne.ca
  13. #5363
    Godfrey's Avatar
    Jan 2009
    7,857
    A wonderful Rolleiflex, Bill!
    Hopefully, the weather will relent soon.
    Godfrey - GDGPhoto Flickr Stream
  14. #5364
    k-hawinkler's Avatar
    Dec 2009
    The "Land of Enchantment"
    3,059
    Quote Originally Posted by Bill Caulfeild-Browne View Post
    Being isolated like that it looks like you have a wonderfully peaceful time!
    Great image. Thanks.
    With best regards, K-H.
  15. #5365
    Michiel Schierbeek's Avatar
    Mar 2009
    Amsterdam/Normandy
    4,011
    762
    Here are few from today. The second with a Tilt adapter.
  16. #5366
    Apr 2008
    Englewood, NJ
    528
    I just became a new user of A7r ....
    Testing my Rokkor 100/2.0 ....
  17. #5367
    Member pozzello's Avatar
    Oct 2012
    Montreal
    68
    MAJOR LIKE !
    website: http://www.paulozzello.com
  18. #5368
    Aug 2008
    2,468
    145
    Well, as I was busy shooting my Rollei, this little guy was looking through my window. a7r with Sigma macro. ISO 1000, just the centre of the frame. Lots of pixels sure help when you're cropping!
    Bill CB
    Likes 10 Member(s) liked this post
  19. #5369
    Godfrey's Avatar
    Jan 2009
    7,857
    http://www.getdpi.com/gallery/files/...4/_dsc0069.jpg
    They sure look so cute, but boy can they be nasty ... !
  20. #5370
    23,623
    2555
    OT here. Godfrey love to hear more on the Leica 24r it was never rated that high but it could be a nice look lens. Let us know how that goes in your shooting.
    www.guymancusophotography.com
  21. #5371
    Feb 2011
    Chicago
    101
    Finally got my A7r so I could add a few shots here!! From a preview night of an incoming art/light installation for Chinese New Year.
    A7r with 14-24 nikkor
    Chicago Chinese New Year: Luminance by PeteTsai, on Flickr
    A7r with Contax G 90mm
    A7r with 24mm nikkor on kipon tilt adapter
    A7r with Sony FE 55mm
    A7r with 14-24mm Nikkor
  22. #5372
    8,484
    44
    Quote Originally Posted by Michiel Schierbeek View Post
    Love that tilt effect on #2
    Would love to see some portrait work using the Nikon 85/2.8 PCE done in the same manner.
    - Marc
  23. #5373
    Senior Member PSon's Avatar
    897
    139
    7R + Elmarit-M 90mm
    ALPA (MAX, STC, TC) | CAMBO (Actus DB2, WRS-AE) | CONTAX | HASSELBLAD | LEICA | DS (CFV-16, IQ180, IQ260, IQ3100, M9-P, P25) | Lens (Canon, Fujinon, Leica, Nikon, Pentax, Rodenstock, Schneider, Zeiss)
    Likes 9 Member(s) liked this post
  24. #5374
    Oct 2012
    Heidelberg, Germany
    911
    The banks of the river Neckar with the ZE 18/3.5:
    Likes 14 Member(s) liked this post
  25. #5375
    8,484
    44
    Quote Originally Posted by W.Utsch View Post
    Holy-Moly!
    To create a Yogi Berraism … "That's more real than reality".
    - Marc
  26. #5376
    897
    139
    7R + Noctilux-M
  27. #5377
    897
    139
    7R + Summilux-M 50mm
  28. #5378
    897
    139
    7R + Elmarit-M 90mm
    Likes 15 Member(s) liked this post
  29. #5379
    Manchester/Jerusalem
    2,652
    290
    Quote Originally Posted by Pham Minh Son View Post
    7R + Noctilux-M
    WOW! Such energy.
  30. #5380
    897
    139
    A7R + Elmarit-M 90mm
  31. #5381
    23,623
    2555
    90 elmarit looks nice
  32. #5382
    Godfrey's Avatar
    Jan 2009
    7,857
    I know that many dis'ed it because it was manufactured for Leica by Minolta. However, my thinking was 'hmm, Leica felt it was good enough to keep in the catalog from 1974 to 2004, unchanged except for electricals in the mount for the later cameras—how bad could it be?'
    Entry in the Leica wiki about it:
    24mm f/2.8 Elmarit-R - Leica Wiki (English)
    Mine's a 1978 example. It's a nice size and weight on the A7, handling feel is good. In my test shooting around the condo, mostly at f/4 and f/5.6, the images look good, they have that signature look and feel I expect from Leica lenses.
    Can't wait to do some real shooting with it.
    Godfrey's Avatar
    Jan 2009
    7,857
    There are too many great photos accumulating in this thread to comment on all individually. Great work, everyone! I hope to add a couple more soon ..
    Senior Member Joe Colson's Avatar
    Oct 2010
    North Carolina, USA
    1,806
    36
    From the Porsche By Design exhibit at the NC Museum of Art:
    Joe
    _________________________________
    Joe Colson Photography
  35. #5385
    Godfrey's Avatar
    Jan 2009
    7,857
    My uncle had a Porsche 356 that looked a lot like that one way back when I was a little kid. :-)
  36. #5386
    Mar 2011
    Coral Gables, FL
    642
    re: Fun With Sony _____
    A few more from swim practice earlier this week. All shot with the a900 with the broken select button, and the ZA 135/1.8. I left the iso at 400 just to see what the lens could really do in low light. Photos minimally processed.
    The photo of the teen in the orange goggles was taken about 30 seconds after he did a race pace swim. The photo of the younger kids was taken at the end of practice. I wanted a bit more dof and light but I am very happy with the way the photo turned out.
    ores12814 by MikalWGrass, on Flickr
    ivanpool12814 by MikalWGrass, on Flickr
    bronze12814 by MikalWGrass, on Flickr
  37. #5387
    Oct 2010
    North Carolina, USA
    1,806
    36
    Another classic from the Porsche By Design exhibit:
    And a little whimsy, courtesy of the late Janis Joplin:
    Joe
  38. #5388
    23,623
    2555
    Its my favorite car of all time.
  39. #5389
    23,623
    2555
    LOL Not sure this one moved in 40 years but it looks cool. LOL
    Shot with the 55 FE at 1.8
    Likes 12 Member(s) liked this post
  40. #5390
    Mar 2009
    Amsterdam/Normandy
    4,011
    762
    This is the old CSM sugar factory terrain. The office buildings are in old silos.
    Csm1 by Michiel Schierbeek, on Flickr
    Csm5 by Michiel Schierbeek, on Flickr
    Csm2 by Michiel Schierbeek, on Flickr
  41. #5391
    Mar 2009
    Amsterdam/Normandy
    4,011
    762
    Some more from the same terrain.
    Csm3 by Michiel Schierbeek, on Flickr
    Csm4 by Michiel Schierbeek, on Flickr
    Csm6 by Michiel Schierbeek, on Flickr
    Likes 11 Member(s) liked this post
  42. #5392
    Godfrey's Avatar
    Jan 2009
    7,857
    Making great use of that CV 21/1.8, Michiel! The A7/A7r might justify purchase of that lens if what you're getting out of it is without doing any corner cleanup!
  43. #5393
    Feb 2009
    1,031
    Guy: regarding the old truck...I would like to see what you could make of the scraped paint on the left front fender (the one to the right side of the pic).
    Roy Benson
  44. #5394
    Senior Member biglouis's Avatar
    May 2009
    2,079
    Biggest barge I've seen in that lock, ever.
    All with the A7 + FE55/1.8 - the 55 makes a nice reportage lens, imho.
    My new book "Whitechapel in 50 BUildings", Flikr Stream, www.louisberk.com
  45. #5395
    Aug 2008
    2,468
    145
    What a lovely mood this conveys. Congratulations!
    Bill
    Bill CB
  46. #5396
    Apr 2008
    Englewood, NJ
    528
    I really like that Zeiss 18mm image....
    Here is one from ZE 25/2.0
  47. #5397
    Mar 2011
    Beach Haven, NJ
    679
    A7R 35mm FE lens, ISO 250, 1/125 at f9.0 hand held
    Dave in NJ
  48. #5398
    Ithaca, NY
    3,438
    Finally got back up close to the freezing point and went for a walk near our "new glacier". A7R + Leica R Vario-Elmar f/4 35-70.
    Edit: One last "elegant rot" image of the old park ranger's house. This is full size so be aware if you click the image you will get a very large image back.
    Carl
    Gallery
  49. #5399
    Aug 2009
    724
    This is so life like it makes me want to reach into that picture!
  50. #5400
    Aug 2009
    724
    These look very good. Do you happen to remember what aperture / focal length these were at, please?
