Page 41 of 382 FirstFirst ... 31 39 40 41 42 43 51 91 141 ... LastLast
Results 2,001 to 2,050 of 19060
Thread: Fun With Sony Cameras
  1. #2001
    Ithaca, NY
    3,554
    Re: Fun with the NEX cameras....
    A couple of garden shots using the Canon TS-E 24mm f/3.5 II on the NEX-5N.
    Carl
    Gallery
  2. #2002
    Aug 2010
    933
    scho, I see the the issue I had with the 28 on my NEX5 with the corner issues on pics #2 (upr lt corner very obvious) and slightly on pic #5
    please when you get time take a flat on fully open aperture shot of a woods or brick wall at a distance where focus would be set to infinity. I am really curious if Sony truly fixed the issue I had with the 28 Contax in the corners with apertures of 4 and larger. I figure if they did on the 5n then they surely did for the 7 as well.
    thanks in advance
    maybe I can get to use my 21mm if the corner issue has been fixed ..... wheres my sawsall
    Quote Originally Posted by scho View Post
    A few shots taken today with the NEX 5N and Contax G 28mm f/2.8 Biogon. Raw images converted to tiffs with the Sony raw converter and then processed in LR3 (except 1st image converted in Raw Developer 1.92). Still juggling between the NEX and Ricoh GXR. I'll need to wait for the GXR M module before deciding which to keep (might keep the NEX in any event for use with the Contax G lenses). So far I think that the edges and corners look OK with the NEX and both CV M and Contax G lenses. Hope that Adobe support won't be too long coming for the NEX raw files.
  3. #2003
    etrigan63's Avatar
    Earth, Sol System (near Miami, FL)
    2,502
    21
    Carl & Keith,
    I am seriously contemplating getting either the CV 12mm or 15mm for my upcoming NEX-7. I am having trouble deciding between the two.
    Keith, is there a lot distortion with the 12 mm? The crop makes it at 18mm which is a very nice width for landscapes assuming the distortion is controlled.
    Carl, the 15mm looks great and the crop makes it ~24mm also very good for landscapes and even for some street stuff.
    I will be getting the Zeiss 24mm f/1.8 lens for everyday use.
    Care to wax philosophically on this subject gentlemen?
    Carlos Echenique | Carlos Echenique Photography |Olympus OM-D E-M1 MK II | Olympus Pen-F - M.Zuiko 17mm f/1.8, M.Zuiko 25mm f/1.8, M.Zuiko 45mm f/1.8, Rokinon 12mm f/2 NCS, M.Zuiko 75mm f/1.8, M.Zuiko 12-40mm f/2.8 PRO, M.Zuiko 40-150mm f/2.8 PRO
  4. #2004
    Jan 2008
    North Vancouver, BC
    1,168
    Carlos,
    Here are a few examples of the CV 12mm on the NEX 5 from New Orleans. As you can see, with off centre subjects, there's certainly distortion, but then you'd expect it at that wide an FOV. There are some magenta corners with the lens, although it rarely bothers me, especially for B&W.
    As always, click on an image for a larger view.
    Attachment 48738
    Attachment 48736
    Attachment 48737
    Attachment 48739
  5. #2005
    Ithaca, NY
    3,554
    Quote Originally Posted by Jim DE View Post
    thanks in advance
    Hi Jim,
    I agree that the 28 G and probably all wide RF lenses below 50mm have varying degrees of corner distortion issues on digital platforms, but with the lenses I've been using and the subjects that I typically shoot this is a very minor issue, particularly with the 5N. There are no corner distortion issues with either of the particular images you mentioned. Both are crops so you can't see the original corners. The #2 was shot handheld in a 30 mph wind at 1/80 sec so you most likely are seeing some wind induced blur in the trees. I'd be happy to shoot a flat field subject, like a textured wall, at varying apertures using the 28 G if you would like to see the distortion at wider apertures, but I really don't think it is a significant problem.
    Carl
    Gallery
  6. #2006
    Ithaca, NY
    3,554
    Quote Originally Posted by etrigan63 View Post
    Carl & Keith,
    Carlos,
    I don't have the 12 so I can't make any direct comparisons. The 15 does have some corner distortion, but it seems to be reasonably controlled on the 5N. I have the old screw mount version of the 15 and although it is very tiny (matches the 5N in that respect) it is quite awkward to focus on the 5N because the focus ring has no tab. It is not a lens that I would use very often, but the wide FOV is nice to have for certain landscapes. The great DOF would be advantageous for street shooting and you could just stop down to about f/6.3, set a fixed distance, and shoot away without the need to focus each shot.
    Carl
    Gallery
  7. #2007
    Aug 2010
    933
    Yeah Carl I have continued to use my 28 on my NEX 5 but do a work around using no larger aperture than 5.6 with that lens. The 45 and 90 on the NEX 5 are as good as it gets. I was hopeful that with the 3G showing corner performance improvements that the 7 might be able to resolve the 28 and possibly the 21 better than my NEX 5.
    If you say it's a non issue I will accept your findings and be even more impatient for November
  8. #2008
    Jan 2008
    Toronto, Canada
    3,026
    1117
    Carl & Keith,
    Carlos
    From the images I've seen I would lean more toward the 15mm if you are going to do landscapes. You can see the distortion of the 12 in my black and white image against the Toronto skyline - the CN tower is quite distorted. I rarely use this lens for landscapes - more for fun type subjects and street work. I don't have the 15mm
    Here are a couple more examples - no 2 shows lots of distortion
    Keith
  9. #2009
    etrigan63's Avatar
    2,502
    21
    Thanks guys. Based on your input and the samples you have provided, I think I will plan on th CV 15 mm for wide work on this camera. That wil make my NEX-7 kit at:
    1. Cv 15mm f/4.5 for landscapes
    2. Zeiss 24mm f/1.8 for walkabout
    3. Cv 35mm f/1.4 for lowlight normal aspect
  10. #2010
    Ithaca, NY
    3,554
    A few shots with my 30 yr old Canon FD 50mm f/1.2 on the NEX-5N.
    f/1.2
    f/2.8
    f/6.3
    f/6.3
    Carl
    Gallery
  11. #2011
    Mar 2011
    187
    I've posted a few images here because they're a bit wide. If you want to see several more samples: http://www.jaegraphy.com/blog/?p=128
    First, DO NOT buy the cheap ebay adapters, I'm returning mine to the sketchy seller. I purchased a Photodiox version and while it looks Identical on the exterior to the cheap ebay version, it doesn't grind and stick. I also have a Metabones adapter on the way.
    I apologize for the horizontal scrolling on the blog, need to get that fixed!
    These are OOC JPG with Noise on LOW and mode on Standard.
    I have NOT POST processed these at all except for slight straightening. The included lens hood was used, no polarizers or filters of any kind were used. I have purposely not post processed these images to simply demonstrate what amazing files you'll get to start from. I can't wait for RAW support to be fully implemented in Adobe Camera Raw.
    I'm just flabbergasted by the level of contrast and detail in these images. This is possibly the best value lens I've ever purchased. The lighting was very flat today, overcast yet the contrast and saturation is just incredible for Zero post production! Come on! Let me emphasize, the lighting Sucked big time today.
    Its pretty good wide open but fantastic at F2.8 with most aberrations negligible at that end.
    I'm pretty sure I'll be purchasing another one as a back up.
    My only drawback right now is the somewhat busy bokeh at F2 with some purple fringing but I'll have to do a bit more experimenting. I'm really curious what this would look like on a full frame sensor. The PF gets cut down a lot at F2.8.
    The NEX-5N JPG engine also seems to oversaturate Red and Magenta a bit even on standard.
    Wide open at F2:
    Various apertures I do not recall:
  12. #2012
    Senior Member ecsh's Avatar
    Jun 2009
    Tax State
    549
    re: Fun With Sony _____
    Couple of happy snaps from last weekend. A900, 16-35, 24-70
    Joe
  13. #2013
    Morfeus
    Hi, first post here.
    Sony Nex-3 with Meyer-Optik Görlitz Trioplan 100mm f/2.8 V
    Weed by pictorlucis, on Flickr
  14. #2014
    Aug 2010
    933
    Sony a33 sunset shot
  15. #2015
    Senior Subscriber Member
    San Francisco, CA
    1,306
    Fog over Mt Tamalpais... ZA 24-70 and 16mm Fisheye
  16. #2016
    Feb 2009
    Bangkok
    1,470
    24/2
    Attachment 49410
    24-70/2.8 @ 70
    Attachment 49411
  17. #2017
    Apr 2009
    Pacific NW
    132
    Edward, Great color in both photos. The 24/2 is a stand out, what ISO was used?
    Jerry
  18. #2018
    Apr 2009
    388
    I post some A77 images here but I am still looking for the colours a850 used to give me.
  19. #2019
    Feb 2009
    Bangkok
    1,470
    Quote Originally Posted by LoSenior View Post
    Jerry
    Thanks Jerry! I cheated a little with these 2 photos. Actually these were taken on Provia 400x in a Minolta 7. I find the ZA to work even better with film.
  20. #2020
    Apr 2009
    388
    Can we post film image here?
  21. #2021
    Senior Member PenSon's Avatar
    Jul 2011
    Norway
    259
    2
    One small mushrom, shot with NEX-C3 and Mamiya 80mm Macro lens
  22. #2022
    Feb 2009
    Bangkok
    1,470
    Quote Originally Posted by Mark K View Post
    I hope so, as long as the lens is a Sony
    Here are a few with the ZA 135 and Ilford Delta 3200 (pulled one stop):
    Attachment 49675
    Attachment 49676
    Attachment 49677
    Attachment 49678
    Attachment 49679
    Attachment 49680
    Attachment 49681
    Attachment 49682
    Attachment 49683
  23. #2023
    Aug 2010
    271
    Small Fall...
    SONY A900
    Always outnumbered, never outgunned.
    My Site|Facebook Fanpage|
  24. #2024
    Senior Member pegelli's Avatar
    Dec 2010
    Belgium
    2,175
    October is "one prime" month on Dyxum. This time over 100 people participating in a month long challenge to only shoot with one prime lens and post 1 picture with it every day (or 3/week or any other self inflicted challenge, as long as it is with only one prime lens)
    I've chosen the A850 with an old Minolta 35/2 (a 2nd hand I got not too long ago and I am liking it better every day)
    Here's some stuff I produced:
    much more can be seen over here
  25. #2025
    8,500
    44
    Quote Originally Posted by pegelli View Post
    Nice stuff with that good old 35! Yet another sleeper Minolta lens.
    -Marc
  26. #2026
    Dec 2010
    Belgium
    2,175
    -Marc
    Thanks, I like the way it "draws" a picture and at larger apertures "removes" it from the background. And 30 cm MFD is not bad either for such an old design.
  27. #2027
    KostaU
    Carl Zeiss Biogon T* ZM 25/2.8
    Konica M-Hexanon 90mm F2.8
    Leitz Summicron 35/2 (iv)
  28. #2028
    Senior Member Hosermage's Avatar
    Jul 2011
    Los Angeles, CA, USA
    1,034
    Beautiful tulips! love those two shots.
  29. #2029
    KostaU
    Quote Originally Posted by Hosermage View Post
    thanks.)
  30. #2030
    pjn
    I'm here in Devon & Cornwall UK, on vacation. This is my first post to getdpi, all done on a cheap laptop so I hope they came out OK. These Cornwall photos were taken with my a900 and a variety of Sony lenses.
    -Pierre.
  31. #2031
    Sep 2010
    Canada / USA
    71
    NEX-5 + Japanese Summilux
    Hello,
    A few quick snaps with the NEX-5 and a Canon 50mm F1.4 LTM. I am quite happy with the rendering of this lens. No post processing has been done on the images, only re-sampling/resizing.
    Autumn
    Yellow Flowers
    The Canon Glow
    Canoe
    Cement Factory
    Yellow Wheel
    Sincerely, Matthew
  32. #2032
    jonoslack's Avatar
    East Anglia & Cornwall (UK)
    11,842
    Quote Originally Posted by pjn View Post
    -Pierre.
    HI Pierre - and welcome!
    this is very much home territory to me - I grew up in St Ives, and we have a house at Brane. I'm intrigued to know where the deaf white cat sign is . . . it looks frighteningly familiar - you've done a good job on Lanyon Quoit, but seem to be missing the Men-an-tol - Is that the merry maidens or . . . .
    Whatever - I hope you're having a grand time in my home county!
    all the best
    Just this guy you know
  33. #2033
    jonoslack's Avatar
    11,842
    Here are a couple with the A77 and the 24 f2 at the botanical gardens in Palermo:
  34. #2034
    pjn
    all the best
    Thanks, Jono!
    I stayed in Carbis Bay for 8 days as a base. The cat sign is just off from Land's End A30 when you turn onto the B3315 (my wife has a 9kg white male cat). One of the ladies at the Apple Tree Cafe (below) gave me sticky notes on my Ordinance map of all the neolithic sites - good coffee too! Long story short, couldn't find Layon in daytime but did in pitch black with the windup LED flashlight I used for the photo. Men-an-tol pics not ready, I met the unwelcomed bull (below) coming back from there, alone deep in the misty moors surrounded by nothing but abandoned buildings, a 1km from my car. Not merry maidens (to come) but Boscawen-un (below), again at night. Last photo is it with 16mm fisheye.
    Terrific 3 weeks, in Tosberry Devon now but leaving this weekend for home. Sent you a PM before I left Ottawa, but so much security now, probably did not get through.
  35. #2035
    Aug 2010
    933
    My old trusty NEX 5 with a Contax G 45 at Bushkill Falls PA
  36. #2036
    Senior Member 4season's Avatar
    Colorado USA
    518
    I just received the new 30mm macro lens and wanted to see how close it could focus (close!). I borrowed a famous image that made the rounds lately, scaled to 20x40 pixels. It seemed only proper that the pixels be provided by an iMac display.
  37. #2037
    Sep 2010
    Canada / USA
    71
    Voigtlander 12mm F5.6 ASPH + NEX-5
  38. #2038
    Apr 2009
    388
    Did not realise A77 is a low ISO machine till today
  39. #2039
    Sep 2010
    Calgary, Alberta
    63
    27
    One from a quick trip down to our reservoir last night, I'm loving the early evening light we've been getting this fall...
    Simon
  40. #2040
    Oct 2008
    Seattle, WA
    5,672
    Beautiful images in this thread.
    Went downtown for lunch with my new gear:
    1. A77; Zeiss 85mm f/1.4; 1/160s @ 1.4; ISO 125
    2. A77; Zeiss 85mm f/1.4; 1/200s @ 1.4; ISO 100
    3. A77; Zeiss 85mm f/1.4; 1/200s @ 1.4; ISO 100
    Cheers, Matt
    http://mdriscoll.zenfolio.com
  41. #2041
    Apr 2009
    Pacific NW
    132
    Matt,
    It's great to see that you using Sony. I've enjoyed your work and look forward to more here. Really like this set.
    Jerry
  42. #2042
    jonoslack's Avatar
    11,842
    Matt,
    Jerry
    +1 Jerry
  43. #2043
    Oct 2008
    Seattle, WA
    5,672
    Matt,
    Jerry
    +1 Jerry
    Jerry/Jono: Thanks!
    Cheers, Matt
  44. #2044
    Jul 2010
    495
    nex-7 with konica hexanon 57mm f/1.2 jpg just resized.
    http://sonyalphanex.blogspot.com/201...onica-and.html
  45. #2045
    Mar 2011
    Beach Haven, NJ
    688
    Sony Alpha 900, 500mm f 8 Minolta Mirror lens. We live on a barrier island in NJ and got hammered yesterday with a Nor'easter. 50 mph winds, sideways rain (no snow).
  46. #2046
    8,500
    44
    Quote Originally Posted by gurtch View Post
    -Marc
  47. #2047
    Mar 2011
    Beach Haven, NJ
    688
    -Marc
    Thanks Marc!
    Dave
  48. #2048
    jonoslack's Avatar
    11,842
    I'm with Marc - Excellent shot
  49. #2049
    Oct 2008
    Seattle, WA
    5,672
    gurtch: +3! Elegant tone and composition.
    Cheers, Matt
  50. #2050
    Mar 2011
    Beach Haven, NJ
    688
    Quote Originally Posted by m_driscoll View Post
    Cheers, Matt
    Thanks all! I only got off 4 shots, this being the last.
    Dave
