RE: use of flash with the Leica M. Obviously most don't use flash, but I find it can be used effectively if used sparingly. I find this to be necessary with the M8 to keep the ISO at 640 or less which isn't always possible at a wedding.Marc
You really have this down...great shots and examples!
Re : M/R flash....just don t use it presently. I have a SF-24 but never use it. Just re read all the threads on flash for the M and concluded ..its the Sf-24 for TTL ,the larger Metz units some on TTL , a larger flash on "A" or go back to manual. What I am looking for is a flash with a small,low profile that I can use on the "A" for fill flash.
Re: Working aperture...my biggest frustration with the D3/D700..probably because I am not using them as much as my M s ...too many misses when I try to shoot wide open and use AF . Not sure if this is practice, technique or equipment..or maybe expectations.
Re: balance between ambient and flash...avoiding what is essentially a double exposure....I have more of problem with this when the ambient is fairly good and I let the shutter speed drop below 1/60.
Re: Dark reception hall....my experience exactly ....choice of dark backgrounds or using motion creatively to enhance the image. Better ISO performance helps here.
Thanks again for taking the time to post the examples.
Roger
I used a TTL SF20 on my M7's and now a SF24D on the M8s .... BUT always with a diffuser. The diffuser I always have used is the S-FILL that was designed by Lutz specifically for the Leica SF flashes ... which I am not sure are available anymore. Something to ask about on the Leica Forum perhaps?
One little secret I employ when using the non-tilting, non-rotating SF flashes while shooting in portrait mode is to always have the diffused flash on the darker side of the subject. So you determine where the ambient is primarily coming from and have the flash oriented to the opposite side.
The other thing is that the Ms really work well with off-camera lights using a tiny Microsync radio trigger. They do not have the distance capability of a Pocket Wizard, but more than the infrared type triggers.
I'm currently assembling a complete one man off-camera kit designed primarily for use with the Nikons, but will be adapting it for use with the M8s. It currently consists of 2 SB900s and a Nikon TTL Commander, 2 Quantum Turbo C with cords to connect the SB900s. 2 light stands, 2 43" Photogenic ribless white umbrellas (that can be converted to shoot through) as well as a gold umbrella and a smaller hair light umbrella, and for greater distance like at a reception three Pocket Wizards with screw-in Nikon cords from Paramount Cords. The Leicas can then be used with the Pocket Wizard in the hot shoe to fire the Nikon flashes ... but obviously no TTL ... so you need to set the flashes to Manual, or A with the sensor pointed outward and the head toward the umbrella and control them that way.
What is not clear yet is whether the new Leica SF58 will offer any kind of a remote TTL trigger like Canon and Nikon offer. If they do eventually offer it (which they should to be taken seriously), they could be used on the stands and triggered by a M8. IMO, Metz seriously lags in the wireless system arena ... or if they have it done a good job of keeping it a secret
What made this kit a very compact system for transport is the Light Caddy recently made available ... which was designed by an old internet pal Robert Madina (another wedding shooter).
http://www.thelightcaddy.com/
Here is what the M8 looks like with the SFILL diffuser mounted. It doesn't work with the flash set to A because the diffuser reflects light back into the auto sensor on the front of the flash. So, it's strictly for TTL.
