Results 1 to 5 of 5
Thread: Panoramic heads for medium format digital
    Feb 2009
    793
    Does anyone know of a panoramic head/mount that willl work with a phase one DF body? I would like to do to stitched panoramas with medium format digital systems.
    carstenw's Avatar
    Berlin, Germany
    2,530
    Re: Panoramic heads for medium format digital
    I am guessing that any of the larger heads would work with an L-bracket. I use the RRS system, and it works well with my cameras, including a Contax 645.
    Carsten - Website
    May 2009
    Marseille, FRANCE
    972
    Arca Swiss D4 and D4M are really good !
    Shashin's Avatar
    May 2011
    Florida, USA
    4,503
    141
    The majority of my panoramas with my Pentax 645D are not only not taken without a panoramic head, they are handheld. The need for a head is only under circumstances where you have a lot of foreground objects likein a forest. I use an Acra Swiss PO ballheadwith a Manfrotto macro rail as a nodal slide. That works with all my 35mm, 55mm, and 120mm lenses. Really Right Stuff has a number of nodal slides/rails for their heads or heads that take certain quick release plates.
    LB Jefferies
    I use a mixture of Kirk and RRS parts. RRS for the rotating clamp, Kirk for the ballhead and brackets.
    Either of those two brands will serve you well.
