A mystery solved.
Bill Caulfeild-Browne
Just in case anyone else encounters this problem. I use Capture One (v16.0) and found my M11-P shots showed flashes of green whenever I adjusted the image. After adjustment they were fine - but it was irritating to see the shift while moving the sliders. I wondered if it was the camera or the software but as I only have C1 I was stuck. And it wasn't happening with my M11.
Then I upgraded to v.16.3.6 (the latest) and lo! - the problem disappeared and the M11-P shows up in the Base Characteristics tool, which it didn't before. I can only assume that the files are different from the M11 because of the Contact Authentication - though why I've no idea!
So if you see the same problem....
Bill
