IMHO, if the focus here was exactly aimed at the text of the labels at the center of the image, then the third image shows that something is definitely wrong. This is the center area of the lens, the sweetest spot, and that little defocus/smearing doesn't look right to me.Below images were exactly the same lens captured with tripod ISO 50 1/8 F4,aperture fully open with Hasselblad 503CW Phase one P65+ 2weeks ago.
the image just open with phase one pro and adjust the bright and colour temperature, no further CA adjust no sharp just with default setting.
does anyone give advice of this lens, does it is a crap lens?
Hi MristucciaIMHO, if the focus here was exactly aimed at the text of the labels at the center of the image, then the third image shows that something is definitely wrong. This is the center area of the lens, the sweetest spot, and that little defocus/smearing doesn't look right to me.
But then, it is very difficult to say something precise, because conditions may vary from one test to another, including the ability of the shooter to keep all potential sources of issues perfectly under control.
Hello Mr. hasselblad 503cw,Hi Mristuccia
Thanks for your opinion
first image is the 100% of the central of the last image
the second and others is the 100% corner crop image.
so the third image is the up left of the corner 100% crop sample.
Just for the sake of discussion, here is a comparison between your and my center-image rendering.thanks that is the central. it is correct.
Dear Paul,It does show mushy corners as I remember - it is not comparable to modern tech cam wide angles or the P1 45mm BR, or is my vision off here?
Fair point, but the digression came about because there was this notion in the room that the lens is absolutely excellent and that anything below that must be a misaligned copy or so.Dear Paul,
The fact that the lenses of modern tech cams are better is already a given, and it is not the subject of this discussion.
We are not comparing the 40 IF with Rodies or Schneiders, but possibly with an "old Soviet Jupiter-8m 50mm". We are discussing whether the copy owned by the OP is as it should be according to its specs (= pretty good) or whether it has some issues. And to me it has issues, regardless of how it compares with Rodies/Schneiders/Superdupers.
The 40 IF has been optimized for 44x33 digital backs. Not for 6x6 film nor even for full frame digital sensors.Fair point, but the digression came about because there was this notion in the room that the lens is absolutely excellent and that anything below that must be a misaligned copy or so.
If it is now more commonly accepted that the 40 CFE IF, which is what I have been saying all along, is not that good of a lens by modern day standards and that the lens needs to be seen within its historical context, ie an excellent wide angle for the Hassy medium format film camera, then that’s already a good takeaway. I feel Alkibiades statement further helped to establish this notion.
I just bought it back then assuming it would be absolutely killer but quickly realised that its design showed some age.
That 44x33 comment would tie with the fact that at the centre it was good, but just lost a bit of oomph on a full frame digital sensor in the corners.The 40 IF has been optimized for 44x33 digital backs. Not for 6x6 film nor even for full frame digital sensors.
Within its intended design constraints , it performs excellently IMHO.
Modern tech lenses are better for sure.
But then, to each one his own, including the evaluation of the price/performance factor.
I think that the OP has enough info to take his decision now. So I'll stop here.
I'm a bit confused. The softness you are describing to me just looks like the corner objects are out of focus, which is corroborated by your measurements and also consistent with what I see when you stop down from f/5.6 through f/11 and gain depth of field. Or did you re-focus each time for the center and corners? If not, it's critical to maintain absolute parallelism between the sensor plane and the object plane - very tough to do especially at such short distances (I think that Jim Kasson among others has written about this). Moreover, the lens may or may not perform optimally at ~3 meters focus distance. As for any "smudging" at the center, I can't quite see it but my eyes are pretty tired from being on the computer all day. In any case, I never tested the corners of my 40HR wide open (there's no point as I never use it that way) but if it's like any of my other tech cam lenses, it needs stopping down to look good at the edges and corners.just measure the distance of the middle and corner of the image from the location with laser measure.
central is 2.56 meter,
up left is 3.12 meter.
