k-hawinkler
I just got an email stating:"Your TECHART PRO order from February 10, 2016 is SHIPPED." :thumbup:
The "ring reflection" is not an internal reflection. It is a software correction in camera. Turn off your automatic lens corrections and it will disappear.
Wonder if anyone will agree, 2 minutes to lock focus is a little too long in my opinion. Wonder why Techart could not use a motor that suited CDAF.It took about 2 mins to lock focus and trip the shutter.
Jupiter-3 5cm f/1.5 (f4), NEX-5N monochrome.
Thank you, K-H!
It is not possible to manually focus when this adapter is mounted with all the electrical contacts intact.
It is AF or bust! No DMF or MF possibilities at all. Also, my 5N reported "not enough power" for a sensor clean with the adapter on!
This was one lucky shot. The AF worked within ~10-15s to make this!
Juipter-3 5cm f/1.5 f/2.8, NEX-5N monochrome.
Finally, I found something slower than me (in my current physical condition).
Great question Michiel.Interesting! So in what position schould your manual focus ring be? Or doesn't matter at all? Silly Question??
On a A7rII it would be better?That is correct. Unless you use the latest cameras, avoid this adapter.
I received my adapter last Saturday, and have shot several hundred photos since then.Interesting! So in what position schould your manual focus ring be? Or doesn't matter at all? Silly Question??
Thanks Monza, very informative!I received my adapter last Saturday, and have shot several hundred photos since then.
I've been using "Flexible Spot: S" successfully, the only photos that have not been in focus were the result of user error (i.e., firing without first pressing back-button AF.)
A few notes:
Mine apparently came with firmware version 1. However when I looked at the version number, it originally said:
Lens
Ver. 02
So I originally thought it shipped with firmware version 2.
After updating to version 2, the motor is less 'chirpy' and focus seems a bit slower, but that may just be an initial impression as I just updated it a few minutes ago and have only done a few tests around the house.
Now, when I go to the Version screen on the camera, it shows:
Lens
Ver. 01
As far as where to put the focus ring on the lens, I leave it on infinity, unless the subject is relatively close.
For example, with the 50/1.7 C/Y, the minimum focus distance is 0.6m. That's a little long for my preference with SLR lenses (the 50/1.4 C/Y has an MFD of 0.45m for comparison) so the Techart adapter is very useful, as it's in effect a built-in, on-demand, variable extension tube.
So, if I'm shooting something that is in the range of about 1m to infinity, I leave the lens on infinity.
If the subject is fairly close, however, say, in the range of 1m or less, I'll turn the focus ring on the lens until things look reasonably sharp in the viewfinder, then hit the back-button AF to lock focus. After a bit of practice this becomes second nature, and the motor in the Techart only has to move very slightly to lock focus.
The above would be the recommended usage for lenses with floating elements; coarse focus manually, and then press AF button to lock.
If the lens is NOT at infinity, and you try to AF on something farther away, the Techart might not be able to reach focus. At first I was wondering what was up, but it was just user error. In this situation the motor moves a bit, but never 'beeps' with focus confirmation and the green square doesn't light up. Set the focus ring to infinity and then press the AF button again.
At first I wasn't able to use focus magnification, but finally figured out that AF/MF Ctrl has to be toggled first.
So in AF mode, you won't see focus peaking, and you won't be able to magnify. This error will appear:
“This operation or setting
is not available as follows
Focus Mode
Single-shot AF”
Toggle to MF and focus peaking will appear, and magnification is then possible.
My camera has AF/MF Ctrl Toggle set to the Center Button, Focus Magnifier set to C2, and Steady Shot Focal Length set to C4 (trash can.) This arrangement was suggested by Chad (@Show Performance.)
Hope this helps!
Bart will let us know if that is the case.On a A7rII it would be better?
Most of my shots were taken with C/Y lenses, so the Techart + a C/Y-to-M adapter.Thanks Monza, very informative!
Tw other questions are:
Infinity with adapters is mostly a liitle past infinity, especially if you start using two adapters on top of each other.
If I try to think logically with my limited tech brain I would think this is not a problem for the Techart adapter?
A7-II.Did you use one of the latest Sony camera models? Because, as Vivek stated on the old models the focussing is like a snail and I didn't
hear you complain about focussing speed.
Yes, the adapter was designed for use on the supported cameras with PDAF - a7II, a7RII and a6300 - using it on anything but will be a painful experience.On a A7rII it would be better?
Don't hold your breath, guys !Bart will let us know if that is the case.
Michiel, you are welcome to try the adapter on your A7r.
Hi Sir,
Sorry to tell you that due to the heated demand and limited supply, we are not able to ship all the preorders in late March.
According to your order number, we are going to ship in around late April/early May. Will let you know when it is available to ship.
Thank you very much for your understanding and patience. We will make sure this waiting is worthwhile.
Please stay close to our webpage/facebook page for latest shipment updates.
Thanks again for your support and sorry for all the inconvenience caused!
David
Got this today ...
All Jupiters- 3,8 and 9 or even the 12 are just wonderful. I look forward to having functional AF (with an appropriate camera) one day.Ah thanks, Vivek, may be one of these days....
And indeed the Jupiters!
Yeah, I'm always late you know ...Hmm. My order number was 597, placed 2/9. Shipment arrived 4/15
