a couple of questions for CaptureShop and Contax 645 gurus. My back is Sinarback 54M.
CAPTURE
1. How do you make Live Image possible in Contax 645? Tape mirror up, is it safe?
2. I don't see a difference on the image between Flash None and Flash Early. Please clarify?
3. Is the Flash setting for shoe flash or external studio strobe attached via small connector located on the left side of Contax 645?
4. Do you ever change anything in the Black Reference Control setting?
5. There is only one Standard 54M Flash profile. Are other profiles exist for 54M, how to install them?
PROCESS
1. Do you convert Adobe RGB working space to sRGB when editing images (for example, I export to TIF, then open in GIMP).
2. How CaptureShop Exposure Compensation setting affects Contax 645 Exposure Compensation?
3. What is Color Alchemist? When to change default settings?
4. Do you ever use Anti Moire and Noise Reduction settings?
EXPORT
1. Do you use Apply Unsharp Mask Settings From File when exporting files?
Thanks:thumbup:
CAPTURE
PROCESS
EXPORT
Thanks:thumbup:
